Old 04-16-2004, 08:48 AM   #1
Arr, we captain our ship!
Xray's Avatar
Santa Fe , New Mexico
Images: 44
Anyone have a pic of the Toronado using WD?
Back in the late 60's or early 70's EAZ-Lift or Reese did an advertisement using a couple of Olds Toronados towing some boats using weight distribution where the back wheels of the Toronados were taken off. I know some of you remember this because I did a search on the forums and saw it discussed.
Does anybody have a copy of the advertisement they could post here? I would love to share it with another forum.
Thanks in advance,
X
Xray is offline   Reply With Quote
Old 12-29-2012, 01:37 PM   #2
Road Ruler's Avatar
Images: 38
Sure! They used a conventional WDH to do this test.
It does show the effectiveness of the weight distributing feature of this connection system.
Name:	olds trailer 015.JPG
Old 12-29-2012, 03:29 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
9 years later, we have our answer...
Old 12-29-2012, 03:49 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Ha!Ha!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-30-2012, 10:51 AM   #5
Road Ruler's Avatar
Images: 38
..... ya I know it is a little late to the gate. LOL
Also found some more info on the original FWD Olds Toronado.
The FWD system used in the cars, although fresh to the industry was so HD it was used in the GM built motorhomes.
Name:	GM olds Chassis.jpg.jpg
Old 12-30-2012, 11:34 AM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
RE: Tornado Drivetrain and GMC Motorhome
My research indicates that the motor, transmission/transaxle is virtually identical to what was utilized in the 1970-1978 Oldsmobile Tornado/Cadillac Eldorado (so far as I am aware the factory only utilized the Oldsmobile 455 V8 in the GMC Motorhomes). The motorhome use much heavier torsion bars in the front suspension . . . have been trying to locate a source for these as I would like to find out whether they could be retrofitted to my Eldorado as its originals are sagging and don't have any adjustment left for vertical lift. Believe it or not, my research also indicates that the final drive ratio in the GMC motorhomes was 3.07 . . . it still seems that a 3.07 final drive would provide less than good performance . . . I know the 2.70 final drive in my Cadillac stuggles on hills with my '64 Overlander (6,100 pounds loaded for travel).
Kevin
P.S.: My research indicates that there were very few changes to the basic transmission/transaxle from its introduction in 1966 through its discontinuance in 1978. It seems that the final drive wa 3.07 for 1966-1973 and 2.70 from 1973-1978.
Kevin D. Allen
AIR #827
Old 12-30-2012, 11:44 AM   #7
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
It Was Done with the Chevrolet Citation as Well
I am not certain what year the advertisement appeared in trailering publications, but one of the Class III trailer hitch manufacturers had an advertisement illustrating a Chevrolet Citation towing a trailer with its rear wheels removed. I believe that the advertisement appeared in 1978 but could have been as late as 1980.
Kevin
P.S.: Found the Photo -- it is dated 1980:
Kevin D. Allen
AIR #827
Old 12-30-2012, 12:29 PM   #8
Road Ruler's Avatar
Images: 38
Thnxs for the info Kevin. If you look close at the GM motorhome chassis pic you can see that it still has the 5 bolt front axles. It seems to me I have seen a photo of one with eight. They may have upgraded the front axles in the later years.
Old 12-30-2012, 08:36 PM   #9
1972 Travelux Princess 25
Cobourg , Ontario
I remember the original ad from the 60s. There was an article about it in a magazine, they said they tightened the anti sway good and tight and the whole rig drove around as one. I don't know if they took it on the road but they did drive it around and photograph it.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 12-31-2012, 01:42 PM   #10
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Wheel/Axle on GMC Motorhomes
Greetings Road Ruler!
I think that you are correct. My suspicion is that they found it difficult to find 15" tires with sufficient weight carrying capacity, and those Tornado/Eldorado wheels are a known design issue as they can be easily bent by just barely rubbing a curb . . . one of the most difficult parts to find when refurbishing a 1966-1978 Eldorado/Tornado is a set of five OEM wheels that aren't bent or otherwise out-of-true . . . . I looked for four years and had to give up and have six of the best salvage yard wheels that I could find restored to a degree of trueness that the tires wouldn't prematurely wear on my Tornado.
Kevin
Kevin D. Allen
AIR #827
'80 Caravelle Whisperwoman1 1980 Caravelle 10 09-22-2013 07:51 PM
'62 Overlander pic Paul Mayeux 1960 - 1964 Overlander 20 08-30-2007 09:18 PM
Hello to all here is a PIC of my '68 GT Jim Clark 1965 - 1969 Globetrotter 8 08-12-2007 07:27 PM
For those who havn't seen this pic qqq Forum Admin, News and Member Account Info 6 11-10-2003 07:15 PM
Highest WBCCI Number? Pick Our Community 8 01-22-2003 10:44 AM
