Old 08-23-2013, 08:41 PM   #29
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I've got another 250 miles towing today with the Master stainless steel pin and no obvious bends or wear. Maybe I had junk steel shank pins that bent. I hate thinking about my 8000 pound trailer and my 8000 pound truck connected with a piece of junk steel 5/8" diameter pin, even if it is in sheer. Because of all the slop, it sees bending loads too.
Thanks for your suggestion Robert. And the Anderson aluminum sleeve idea looks promising too for eliminating some of the slop between receiver and 2" Propride.
We are parked along the Columbia River in Boardman, OR. Pretty river, but the terrain not so much. Hot, windy, barren.
The Propride pulls the Airstream nicely. It is a very nice hitch.
David
Old 08-23-2013, 11:00 PM   #30
mefly2's Avatar
2015 25' FB Eddie Bauer
That does not look like a receiver shank pin ... we used pins like that on our snow plow. Try a new "hardened" pin and see if that takes care of the problem. A welder can put a bead on your oval hole and then you can round it with a file (likely it will be too hard to drill after welding). But you will still need to address the "slop" in adapter to receiver fit. Drill a small secondary hole to fit a locating bolt to keep your adapter in position if you don't want to have it welded in place...do you really need the larger capacity (pintle, or...)?
Old 08-24-2013, 01:20 AM   #31
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by dbj216 View Post
I want to tow safely. I need to find a solution to all the stress I see on my shank pin. If I am the only guy in the world with bent shank pins, then I need to find the cause and correct it. I was hoping someone else had already solved this problem
David
Hi, I bought my new trailer in Oregon and towed it home to Southern California. On this one way trip home my Master-Lock shank lock was bent. I decided that the reason it was bent was because it was a dual purpose lock with a sleeve on a 1/2" shaft to make it fit a 5/8" hole. I replaced it with a one piece solid 5/8" lock and have been OK for almost nine years now. Not related to your story, but you aren't the only one with a bent hitch pin/lock.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-24-2013, 04:56 AM   #32
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
I'm hitching up for a 4 week trip out west. I noticed my shank pin was quite bent. I'm concerned.
I have a new F350 Super Duty and a new ProPride hitch. I have towed about 3000 miles with this set up and like it. I have the 1400 lbs weight distribution bars cranked up 7" measured from the base of the BAL jacks. My fender well measurements and weight scale readings are reasonable.
The direction of the bend is verticle based on the way I position my shank pin. It is as if there is a huge upward force on the shank pin causing it to bend.
The F350s come with a Cat V hitch receiver and a sleeve reducing it from 2.5 inches down to the 2 inch Cat IV. The sleeve has a 11/16 by 7/8 oval hole in it meaning the 9/16 diameter shank pin does not touch the sleeve. So the weight distribution force is supported by the outer holes in the hitch receiver.
I don't like the oval hole in the Ford sleeve reducer. It creates a 2.5 inch distance between support areas for the shank pin. I wonder if anyone else has discovered this unusual wear?
David
To reduce the slop using the Ford reducer with my factory class V hitch (2011 F-250) I wrapped a piece of black duct tape around the reducer. Since then it has fit snug with no slop.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 08-24-2013, 08:18 PM   #33
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Missoula is a very nice city. The KOA there is awsome. The Lolo canyon wildfile is not so neat. We had to tow around the fire as hiway 12 was closed. All of our towing so far has been into a strong west headwind. My luck. Averaging 12 mpg.
Doing some checking I find 1020 low carbon steel yield stress is 50,000 lbs. Assuming the 5/8 (.625) diameter pin is supported only by the Ford receiver holes, it would take only a 2000 pound load applied to the center of it to deflect the pin spanning 2.5 inches. I believe the deflection is happening while the hitch assembly rotates, or twists when I go up an entrance ramp, say to a fuel station. The only thing stopping the rotation is the pin due to all the slop in the assembly (big holes = .050 slop, large clearances in the reducer sleeve = .140 slop.) I find the pin is bent upward according to how I install the pin in my hitch. The loaded spring bars keeps the pin from changing position after I hitch up.
Certainly angle rotation, and pulling from a stop, or pulling up a hill puts a big load on the shank pin. Low grade steel and lots of slop caused my pin to bend. The new Master stainless steel pin after 900 miles of towing is straight. I think straight is better than bent!
Cold rolled steel is 90,000 psi, and hardened steel is 200,000 psi yield stress. These are much stronger materials than 1020 hot rolled at 50,000 psi. Better steel makes a much stronger pin. When I get home I'm going to buy the strongest pin I can find, or I'm going to make one.
We are camped in the Columbia River Gorge. Cascade mountains are beautiful. Mayibe Mt. Hood tomorrow.
David
Old 08-24-2013, 09:09 PM   #34
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sounds strange, but I would prefer a bent pin over apparent shear as "hardened" can be "brittle... A softer pin can take a few deflections. The harder pin, if brittle, may appear to have sheared.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-27-2013, 09:06 PM   #35
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I examined the stainless steel shank pin tonight and it is starting to bend. I'll post a picture tomorrow.
The draw bar fits sloppy in the receiver. I can wiggle it in all directions, and the shank pin is what stops the wiggle. I pull with a no sway type hitch with 1400 pound bars. There is a bunch of lift through the receiver. The pin is bent in the upward direction based on how I install the pin in the receiver. The stainless steel pin is the 3rd one displaying deflection in abouit 7000 miles of towing.
Something bad is going on.
David
Old 08-27-2013, 09:46 PM   #36
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
David
I had a lot of slop & movement in my receiver setup (2010 Ford F150).
I ordered one of these Hitch Rider clamps & things seem much more solid now:
http://www.hitchrider.com/nowobble.htm
I wasn't seeing the draw pin bend but the noise & banging over bumps etc was quite concerning. All that is history now.
- evan
eheffa is offline   Reply With Quote
Old 08-28-2013, 07:50 PM   #37
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well, after about 1000 miles of towing, my stainless steel shank pin has deflected some. I thought it may be stronger, but not enough.
I see some displaced metal on my reducer sleeve. One side had the wear on the upper part of the hole, and the other side has the wear on the bottom side of the hole. This indicates the forces are a torsional load somewhere. I know my hitch is sloppy in the receiver and when I twist, the pin stops the movement.
I'm going shopping for a grade 8 bolt. It will be about 3 times as strong as the low carbon steel pin. It will transfer these forces to some other weak spot in the hitch.
We are in Ft Stevens State Park on the northwest Oregon coast. Beautiful here. I'm the only Airstream out of 200 campsites.
David
Here is a picture of the stainless steel shank pin showing deflection.
Name:	1308 Bent Stainless Steel Pin.jpg
Old 08-29-2013, 04:56 AM   #38
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
David,
Why not concentrate on the slop along with the pin?
I think if you "tighten-up", it will help with the pin deflection and the receiver hole elongation.
IMO... The sleeve should not have the oval hole.
The locking pin in post #28 has shown no deflection or ware in seven years of towing both the AS & boat trailer.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-29-2013, 07:36 AM   #39
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the reply Robert. I'm in a State Park and away from my garage. And I'm sure my garage is limited compared to yours. I don't weld. I will try to get some shim stock and a grade 8 bolt today. And I will continue to shop for higher quality, tighter fitting reducer sleeve.
David
Old 08-29-2013, 07:52 AM   #40
Thumbs up
My garage is a mess....
ID:	194444   Click image for larger version
PFC
"Tahawus"
RLC
John Prine
Old 08-29-2013, 08:34 AM   #41
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
This is a shot in the dark, but could there be unusual drag pulling back on the trailer that your new F350 hardly notices, such as trailer brakes partially engaged, or wheel bearings too tight?
Or are you getting a "Hensley Bump", from he brake controller not high enough setting? Thereby banging into the pin at each stop.
Wondering if we're overlooking another factor, while looking only at the pin and receiver.
doug
Old 08-29-2013, 08:48 AM   #42
dznf0g's Avatar
Oswego , Illinois
Here is what I would check. But first, is it bending vertically or laterally in relation to your insertion? If vertically, here is my thought. Although I haven't examined a Ford receiver that closely.
I don't think the oval hole in the sleeve is the issue. GM's is oval as well. It should just "float" in there, taking up clearances.
I believe an upward bend indicates, when WD is applied, that the pin is being used as a load bearing "Fulcrum".
It has been my experience that the shank should bear the load of WD at the top of the mouth of the receiver AND at the bottom front (front orientation to front of TV) of the receiver. The pin should float (although there is always some forces applied to it) and not be bearing the WD load.
The causes might be:
1) So much slop between the receiver and sleeve and shank that the the front bottom of the shank can't bottom out on the front inner surface of the receiver until some deformation of the pin occurs.
2) I have seen some receivers that have a very short throat from the pin location to the front end of the receiver tube. Same effect on the pin.
3) the distance from the pin hole to the front of the shank itself is short and has the same effect on the pin load.
4) a combination of all or some of the above.
Hope that makes sense.
-Rich-
