Old 03-22-2014, 02:48 PM   #1
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Any issues swapping out hitch types?
All,
I am looking at a used airstream to purchase and current owner drilled three holes into the frame to support a Pro Series friction WD sway control hitch. If I purchased, I would like to change it over to a Reese dual cam or Propride series. Can folk offer me any gotchas or concerns I ought to have - am I stuck instead with the current hitch type or facing a replacement of that section of the frame to support a new drill pattern?
Cheers,
Ian Poulin
Richmond Va
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 03-22-2014, 02:55 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
You should not have any problems with any hitch you want. If the holes show put a bolt in them for cosmetic purposes
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-22-2014, 03:11 PM   #3
IanPoulin's Avatar
Aldie , Virginia
So adding additional hole patterns ought not have frame structural implications in that section?
Old 03-22-2014, 03:51 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If you use a ProPride you will not have to drill any holes in the frame.
Doug and Cheryl
Old 03-26-2014, 05:39 AM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
My Reese doesn't have any holes in the frame, either. I don't have the dual cam sway control, but I thought that bracket was pressure fit, too, not drilled (I could be wrong, though).
Obviously if you start getting too many holes at some point you'll lose structural integrity, but one or two isn't going to matter unless they're really large or dangerously placed. And keep in mind the holes from your current hitch are ALREADY in your frame, and if it weakened the frame it would have done so when they were drilled, not when you remove the hitch.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-26-2014, 06:50 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Equal-i-zer has no holes in the frame.
EazLift has no holes for the weight distributing hitch, but has 6 very small holes for the anti-sway, which would most likely line up/work with any brand anti-sway as it is just a metal plate with a small ball on it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-27-2014, 10:45 AM   #7
IanPoulin's Avatar
Aldie , Virginia
Skater -- yeah the Reese dual cam requires hole drilles; and that concern with fatigue is the basis for my question. I guess I could reach out to the Reese folk directly and see if their mount pattern is the same (likely not) or close - or their suggestion.... this may tip the bar and push me towards propride in the longer run.
Old 03-27-2014, 12:26 PM   #8
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
A welder could fill in the holes and restore the strength of the frame, if it's an issue.
Old 04-02-2014, 05:42 AM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Interesting, thanks. My trailer had a dual-cam installed at one point; I can clearly see where the bolts for it were. I remember thinking that it looked like they cut the bolts for it off level with the frame, but that doesn't make much sense. Someone probably welded up the holes.
I need to repaint our tongue, so I'll have to take a closer look when I do that.
Airstream Life back issues 2004-2009 Stefrobrts Airstream Classifieds 1 02-22-2014 07:11 PM
Equal-i-zer Hitch storage at home idmtman Hitches, Couplers & Balls 5 08-20-2011 04:49 PM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
What are tradeoffs in extreme rise/drop hitch heights? amm3824 Hitches, Couplers & Balls 1 03-29-2011 07:56 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
