Old 09-01-2010, 07:53 AM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Anti Sway Hitch?
Can you buy an anti sway system that is not part of a WD system? With my rig I don't feel I need the weight distribution system and have the ability to adjust the suspension on the TV to make the hitch height correct, but would like to have an anti sway system, just in case.
Old 09-01-2010, 08:04 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Don't be so quick to discard the weight distribution function. Even though you are able to adjust your tow vehicle's suspension to level the trailer, not transferring some of the tongue weight load to the front axle of the tow vehicle can be dangerous. Insufficient weight on the front axle of the tow vehicle can cause reduced responsiveness of the tow vehicle's steering and braking functions.
Brian
SuEllyn & Brian McCabe
Old 09-01-2010, 08:33 AM   #3
_
Originally Posted by TG Twinkie View Post
Can you buy an anti sway system that is not part of a WD system? ...
yes
the PP or pull rite or old orange blob.
even the ancient friction adjustable OUTRIGGER sway dampeners qualify.
but the ancient systems are not really very good at sway elimination.
________
IF the underlying question is...
are there ANTIsway hitches that don't RELY on the w/d bar TENSION for 'antisway'...?
the top choice is clearly a PP.
the w/d is a totally separate function on the pp,
than the inherent sway ELIMINATING design of the 4 bar/pivot point projection.
so the w/d bars can be tensioned JUST ENOUGH to keep the hitch head upright/level...
but without transferring w/d forces into the tow vehicle.
u can read about this here, or on their website or in the sticky thread under hitches...
http://www.airforums.com/forums/f464...ide-57179.html
now, having answered the question, without regard for PROPER rig setup,
i agree with moose' that being SURE the front/steering axle is properly loaded for control is important.
that might require SOME w/d tension and clearly should include WEIGHing the rig and each axle...
before and after hitchin' up the trailer.
cheers
2air'
Old 09-01-2010, 11:27 AM   #4
Rockville Centre , New York
2005 internationa 28 ft how can i ben the propane lines to put on dual cam sway contro on ?l
Josie28 is offline   Reply With Quote
Old 09-01-2010, 11:32 AM   #5
_
Originally Posted by Josie28 View Post
...how can i...l
read some of these threads in the hitch section....
http://www.airforums.com/forums/f464...-up-43568.html
http://www.airforums.com/forums/f232...tly-33350.html
http://www.airforums.com/forums/f232...use-28204.html
there are many other references to repositioning the lp lines for almost ALL brands of hitch'n gizmos.
cheers
2air'
Old 09-01-2010, 11:35 AM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Josie, I went back to the edge of the trailer and cut the copper line and went from there with a flexible rubber hose to the regulator.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 09-06-2010, 09:03 AM   #7
Airstreamer67's Avatar
TG Twinkie, the answer to your question is yes, there is such an anti-sway system that has been successfully used for 50 years or more and is still an excellent choice. At least, it has been for me.
Take a look on ebay or at Harbor Freight and you can find friction anti-sway bars for about $50 each. I've been using this type of anti-sway system for the past 35 years from coast-to-coast without the least hint of a sway event. I currently use two of them (total cost about $100) on my 27-foot trailer because the manufacturer recommends the use of two, one on each side of the A-frame, for trailers over 25 feet long.
I am fortunate to be able to say that I've got the resources to afford the $3000 anti-sway systems. Only, I never, ever have been in a situation that my present system did not work extremely well. I will add that I always make sure that my tow vehicle and trailer are well-matched so that even without an anti-sway system hooked-up, there is no sway under normal towing conditions. My friction anti-sway bars are for unusual conditions, and I've never felt the need for anything else.
Airstreamer67 is offline   Reply With Quote
Old 09-06-2010, 07:05 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Airstreamer 67
Thanks, my rig is very well matched. I too am looking for something that will help in one of those unusual situations.
Old 09-06-2010, 07:24 PM   #9
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Make/model of tow vehicle?
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 09-06-2010, 08:28 PM   #10
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
I too did not need the weight distribution with my F150 and 71 Caravel.
But, with the single axle I wanted some sway control, so I opted for the the Reese trunnion bar with sway control. I have some weight distrubution adjustment available as well as friction sway control. Easy setup and its a snap to hookup and unhitch. I have gone on several long trips since I installed it and the truck and trailer ride like a matched pair going down the highway. Before I installed it I had some single axle sway when traveling on single lane highways. If anyone has driven in WV on a highway like WV Rt 9 you know what I'm talking about. You can meet yourself going around some of the curves. I didn't want the expense and overkill of the trunnion and cam sway controls so this worked out great!
Here's the link to the Cequent- Reese webpage for this type of control.
Weight Distribution - Reese
BTW, I think its a stock item at Camping World.
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 09-07-2010, 08:33 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It's a '98
My TV is a '98 Dodge 3/4 ton extended cab pickup with full length box. The truck weighs 5900# with a full tank of gas and nothing in the box. The total weight of the rig ready to go is 11,400#, so it's a well balanced setup. The truck is only 3 feet shorter than the trailer. I also have air bladders on the rear axle, which I only have to inflate slightly to make the trailer ride level, it's kind like an air ride system for the whole rig.
Not using anti sway bars aaumpine Hitches, Couplers & Balls 60 08-05-2009 05:58 AM
Anti-sway Devices MURPHY4385 Hitches, Couplers & Balls 7 05-21-2007 12:48 PM
Friction Anti-sway on '65 Caravel PoconoAir Hitches, Couplers & Balls 5 05-01-2007 05:21 PM
Anti sway on a 16' Bambi Gnostic Hitches, Couplers & Balls 40 06-10-2006 08:39 PM
Best combo WD anti-sway hitch wacnstac Hitches, Couplers & Balls 6 03-03-2006 02:59 PM
