05-19-2013, 06:07 AM
2005 19' Safari
ishpeming
, Michigan
Another newbie wb / sway control ???
My new Reese spring / trunnion bars (600#) just arrived and am hoping to get it installed before the rain comes. While reading the install instructions for the dual cam sway control I noticed they are designed for use on frames with a maximum width of 2". If one side is open, i.e. C channel, you must install a reinforcing plate in the open side. Must this be metal and welded on? Can it be a hardwood block and inserted into the open channel? Not quite sure what to do. Thanks all...... Woody
ewood29289@aol.com
05-19-2013, 06:12 AM
Retired.
, At Large
It should not be wood, and it does not need to be welded.
05-19-2013, 07:34 AM
2005 19' Safari
ishpeming
, Michigan
Huh?
Jim, not sure what you mean. Are you saying just to slide a metal plate into the channel? If so what will hole it in place? If it is only secured by the two big U bolts, will it not slide around or out if not welded or tacked? Maybe I just can't see the forest for the trees? Thanks, Woody
05-23-2013, 10:04 PM
1999 34' Excella
Hillsboro
Woody, the plates, if installed to match the c channel, will be held with sufficient pressure by the U bolts.
Install, then carefully mark upper and lower positions and watch for movement. If they move, you should have them 'tack welded' in place or otherwise secure them to the mount point.
Peace and Blessings..
Channing
WBCCI# 30676
05-24-2013, 06:28 AM
2005 19' Safari
ishpeming
, Michigan
Plates
Hi Channing
Thanks for the reply. After looking at this issue from several different angles I've decided to go ahead and have the plates welded in. If the frame should ever torque I think it better in the long run to have had them properly secured in the first place. Anything worth doing is worth overdoing....... :>)
05-25-2013, 06:58 PM
1999 34' Excella
Hillsboro
Originally Posted by amazingwoody
Hi Channing
That would be my plan too!
Channing
WBCCI# 30676
05-25-2013, 07:07 PM
1993 34' Excella
York
, South Carolina
Hi Channing
Yep, why do it when you can over do it, right??!!!
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
05-25-2013, 07:47 PM
1999 34' Excella
Hillsboro
Yup... The BFH is always within reach... That is how I got nicknamed Thor.
Channing
WBCCI# 30676
