Old 12-27-2013, 08:33 AM   #29
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Walk Arounds
This is not our first hitch failure. One year ago or so, the welds on our hitch head broke on one side leaving the hitch head hanging on the shaft by one side. I know, someone right now is saying, "what the heck is that guy doing to his hitches?" I don't know. I am conservative, drive slow, and check my gear. Bad luck? I don't know. But, since the broken head, my wife has been obsessive about "weld checks". We don't roll until she has inspected all the hitch welds. I love her enthusiasm, and as people have mentioned, inspection is your best friend.
mstephens is offline   Reply With Quote
Old 12-27-2013, 08:47 AM   #30
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by mstephens View Post
... I know, someone right now is saying, "what the heck is that guy doing to his hitches?" I don't know. I am conservative, drive slow, and check my gear. Bad luck? I don't know.
well...have you balanced your running gear?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-27-2013, 08:51 AM   #31
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Funny Bob, maybe it's our aircraft maintenance background. I use small "Remove Before Flight" keychain fobs I found at an Air Force base to remind me to remove X-Chocks and raise stabilizers.
Doug and Cheryl
Old 12-27-2013, 09:09 AM   #32
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I find on 'Cloudsplitter' the red ribbon hanging from the entrance steps, awning support arms & open windows has reduced head bumps & CG embarrassment greatly.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 12-27-2013, 09:43 AM   #33
mstephens's Avatar
Hmmmm?
I don't know what I don't know!
Old 12-27-2013, 09:51 AM   #34
mstephens's Avatar
We have a pretty good "pre roll routine." I go outside and do the hookups, wife is inside and does all the putaways and securing, antennas, vents and whatever. When done, she comes out and we hookup. Then I go in the car and check all the gauges and tire pressures in TV/TT, and she does another walk around that includes the light check, and mirror adjustments. In the beginning, we had all this on a written check list. We quickly learned it and we haven't been using the written one, which is a mistake. I think we will go back to the written one just to be sure we aren't becoming sloppy.
Old 12-27-2013, 10:07 AM   #35
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Hmmmm?
There is a forum member that attributes anything that goes wrong on an Airstream to unbalanced running gear.
Old 12-27-2013, 10:37 AM   #36
urnmor's Avatar
Berlin , Maryland
Glad you are safe and than you for the information
urnmor is offline   Reply With Quote
Old 12-27-2013, 10:50 AM   #37
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Walk Arounds
Wow! You've had this happen twice?!! I do give our hitch an inspection at every hookup, but I would never expect a failure like this (I'm usually making sure none of the bolts are working loose). Thanks for the warning post, and glad you are all safe. That really is something to see it hanging on a thread like that! I guess you can hope the chains would have done their job, but nobody wants to test it. Hopefully this will be your second AND LAST failure
Stephanie
Old 12-27-2013, 11:35 AM   #38
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
BAD moderator! BAD!
/hangs head in shame
Air:291
Wbcci: 3752
'73 Safari 23'
Old 12-27-2013, 03:23 PM   #39
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If we do anything unusual, I wrap the seat belt around the steering wheel to jog my memory that I need to do something over and above the usual checks
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 12-27-2013, 03:42 PM   #40
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Yes that's good but very unsafe if you drive away with it still over the steering wheel, you can't steer that way!🙌
Old 12-27-2013, 05:20 PM   #41
mstephens's Avatar
Right. Loose bolts, unclipped key pins and the like. Most people wouldn't think they have to also inspect welds before leaving. I never did until I had the first hitch fail on 4 welds. Keep an eye on everything.
Old 12-27-2013, 07:47 PM   #42
Well Preserved
1993 21' Sovereign
BAD moderator! BAD!
You are merely following my bad example...
