Old 09-24-2015, 03:08 PM   #1
2016 25' Flying Cloud
Hillsboro , Oregon
Anderson Weight Distribution Anti-Sway Hitch
We are brand new to towing an Airstream trailer. Previously owned an Itasca 33' Suncruiser Motor Home. We towed our Honda CRV behind the motor home.
The Anderson No Sway Weight Distribution Hitch looks like it will provide the stability and Weight Distribution we need for towing our 2016 Flying Cloud. The hitch seems simple to install and set-up plus it is much ligther than the other available products. We will be towing our new trailer with a 2015 F150 Lariat 2.7l Eco Boast supercab with the 155.9" wheelbase, auto tow brake controler and factory installed sway bars are part of the basic towing package from Ford.
Comments and suggestions on what the most appropriate No Sway Weight Distribution Hitches would be appreciated as well as any negatives on using the Anderson vs. the new Blue Ox system which is much heavier and more complex.
Thanks in advance for your suggestions and comments.
vuch is offline   Reply With Quote
Old 09-24-2015, 03:57 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome, it has all been beat to death here.
http://www.airforums.com/forums/f464...ead-92131.html
MICHAEL
Old 09-24-2015, 06:56 PM   #3
Mrjkq's Avatar
Venice , Florida
No negative stuff on the Anderson just a comment on my setup. I tow with a RAM 1500 similar to your ford ( same only different) & use the Equalizer 4 point WD Hitch. We are returning to our home tomorrow after a 15 day trip into the Smoky Mountains & Nashville (seen Blake Shelton at the Opry). In MHO it's the easiest most effective hitch for this tow combination. I pull at 65 MPH up & down hills, on the straight away & no sway, no steering corrections, no problems, just smooth going.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 09-24-2015, 06:59 PM   #4
1987 25' Sovereign
Oregon , Ohio
I found that our previous truck, F150 super crew liked the Andersen a whole lot more once I installed a pair of helper springs. That said will the 2.7 Eco boost be enough power for your trailer once it is loaded. What rear end gear is in the truck?
msmcv51 is offline   Reply With Quote
Old 09-24-2015, 07:27 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I used one for several months and consider it a bad idea poorly developed. Troublesome. Parts wear prematurely (grease helps). The friction material squeezes out of the hitch over time. It cannot nearly distribute the tongue weight of a 25' Airstream because the mechanical leverage is not there. There is almost no flexibility when the chains are attached and drawn tight.
Andersen warns it cannot be used with the Airstream coupler, you must cut it off and weld on a comparable coupler; a few users have come up with jerry rigs. The risk of a disconnected Airstream was the last straw for us, we got rid of it.
Doug and Cheryl
Old 09-25-2015, 11:27 AM   #6
2015 16' Sport
Jacksonville , Florida
Got It & Works great
No complaints at all. Easy to hook up & feels great on the road.
Mageliza is offline   Reply With Quote
Old 09-25-2015, 12:05 PM   #7
Hillsboro , Oregon
Thanks for all your comments on the Andersen. 2.7 Eco Boost puts out 375lbs of torque more than enough power and it has the 3.31 electronic locking rear axle. Also has the additional springs.. My biggest concern is the ability of the Anderson Hitch to push the load forward over the front axle. Sway control should not be a big issue despite the lighter weight of the truck. This is a two wheel drive not 4 so less weight on the front end. Thanks again.
Old 09-25-2015, 12:16 PM   #8
2007 27' International CCD FB
San Diego , California
I've used it and it is great. Supremely stable with absolutely no hint of sway. Rides great with no porpoising. Easy to use.
It's perfect so long as you're not trying to transfer significant weight to the front axle. The people that are experiencing issues are using it outside of it's intended parameters (meaning trying to shift too much weight to the front axle). This will only prematurely wear the friction material at the ball, the chain donut springs, and risk detachment at the coupler.
pteck is offline   Reply With Quote
Old 09-26-2015, 12:03 PM   #9
2015 28' International
Savannah , Georgia
I Tow a 28 foot international with my VW TDI, remember to buy a good grease gun and grease it every 500 miles or so. We've had it for over two years and love it.
sws323tt is offline   Reply With Quote
Old 09-26-2015, 01:13 PM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure what you are greasing. I have used the Andersen for 3 years and there is no place on the hitch that requires or wants greasing.
The ball does not move in the coupler so no need there. If installed correctly the chains are in line with the hangers so no need there. The only other moving part is the sway control material in the ball shank so no need there.
I have considered putting paraffin wax between the chain nut and washer, on my daughter's trailer, to reduce the effort when she is tightening the chains but since I never release the chains I keep forgetting to do that on her rig.
I jack the combination up to the point that the chains have relaxed while hitching and unhitching. I made a modification to the ball shank, installed a 5/16 roll pin, to keep the shank from coming out while jacking the combination up. Thus I never need or use the wrench on the chains. Andersen has adopted that idea and now puts a C ring on the shank.
Name:	Roll pin in.jpg
2004 Excursion 4x4
Old 09-27-2015, 09:36 AM   #11
Savannah , Georgia
Sorry I was using Hensley, which needs greasing every 500 miles
Old 09-27-2015, 12:01 PM   #12
Portland , Oregon
Wow, that seems like a pain to grease every day or every other day when traveling.
2015 Nash 24M
2014 Tundra DC Limited TRD (Sold)
2016 Ram 3500 CTD SRW CC
Blue Ox SwayPro
Still looking at Airstreams....
MacPDX is offline   Reply With Quote
Old 09-27-2015, 12:24 PM   #13
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
From my experience the Anderson has very little weight transfer capability. It is only done by compression on the plastic bushings. If you compress them too much it "locks" up the functionality and makes everything worse. You will also lose the anti-sway function at this point. Buy a better better WD and anti-sway. I used mine once and immediately sold it to a pop- up owner.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 09-27-2015, 12:51 PM   #14
HowieE's Avatar
Images: 12
Some of what you say may even be correct.
Yes you can over tighten the bushings, factory stated limit is 3/8 of an in.
However if you did over tighten them it would have no effect on the sway control. That is a function of the chains and angle plate moving the ball shank against the brake material.
Over tightening, by those attempting to transfer move weight to the front axe of the TV, has resulted in COLD FLOW of the brake material. Not an unexpected result for going beyond the manufactures instructions.
Not sure what you mean by Locks up functionality. It could result in the bushings exploding and thus such a loss.
I am not sure why there are a few so adamantly against the Andersen but it is clear their numbers are increasing fewer than those that are satisfied. I am sure there are those that have had bad experiences with every other hitch system. Whether that be the cumbersome and time consuming aspects of the Ha Ha type system, the miss-design of the Reese Straight Line System that results in the yokes failing on a tight turn, or the limits of curtain maneuvers. They are free, as I have stated such problems resulting from experience in the past, to post such comments as a limitation but do not support a complete condemnation.
2004 Excursion 4x4
anti-sway/weight distribution questions quincy799 Towing, Tow Vehicles & Hitches 24 09-12-2014 08:59 PM
Weight distribution & anti-sway hitches - What changed from the "old days"? Phoenix Towing, Tow Vehicles & Hitches 14 09-10-2014 05:50 PM
Weight Distributing / Anti-sway Hitch fmacmaster Hitches, Couplers & Balls 104 10-18-2013 01:38 PM
