Old 06-04-2019, 10:14 AM   #1
2017 19' International
Monrovia , California
Anderson WD Hitch Issues
With reference to the Feb 2019 Article in the Blue Beret: the article serves as an alert to the incompatibility of the Anderson hitch with the Attwood 88000 series couplers used on Airstream trailers. I addressed the issue by drilling and pinning the coupler to remove any coupler movement with inspect and replace the coupler latch as/if needed. Since the replacement parts are not currently available I may need a long term solution. I am asking how other Airstream owners using the Anderson Hitch are addressing this issue. (Please do not post your rant with Anderson on the defacement charges.)
Kay0 is offline   Reply With Quote
Old 06-04-2019, 10:23 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I think if you search for threads on Andersen hitches (note the “en” not “on” spelling) you will find some users who came up with solutions including welding a different coupler on the a-frame.
A rant-free good luck to you
Old 06-04-2019, 07:43 PM   #3
1987 34' Limited
Red Oak , Texas
I'm changing mine to a bulldog coupler
thomasg is offline   Reply With Quote
Old 06-04-2019, 08:45 PM   #4
2010 25' FB Flying Cloud
Davenport , Iowa
Bulldog coupler and Andersen hitch; that is what Oliver uses.
Airtandem is offline   Reply With Quote
Old 06-04-2019, 09:24 PM   #5
1987 34' Limited
Red Oak , Texas
I've never had a bulldog fail. I grew up in Davenport. Do miss Harris pizza
Old 06-05-2019, 10:50 AM   #6
Anna Maria , Florida
The Anderson Hitch has little to no WD attributes and zero sway control.
I did the entire factory recommended coupler replacement tack welding yadi, yada only to remove the entire garbage after a most harrowing white knuckle ride out west on I- 80 one day with heavy truck traffic and side winds.
The hitch has zero counter force to prevent sway .
Rolling down hill you better have your fingers on the trailer brakes.
Anyone interested can have it free. Its been collecting dust since 2015.
franklyfrank is offline   Reply With Quote
Old 06-05-2019, 11:34 AM   #7
2007 27' International CCD FB
San Diego , California
Sounds like a rant?
Let's just say it's the wrong WD hitch for your application, which needs more WD and sway control than the Anderson is capable of.
In the right application, I've had great success using an Anderson. Light weight, and easy.
I agree with others that a new a-frame coupler might be the right solution. They're fairly cheap. Just need a skilled welder to install which is easy for someone in that trade. May even want to get a longer one if you have a truck and get interference with the tailgate to tongue jack, and are using a drop hitch with longer projection than optimal.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 06-06-2019, 08:27 AM   #8
Originally Posted by pteck View Post
Sounds like a rant?
I did all that, only to end up having to torch it off ordering an original coupler and welding that back on. Not only that, I had to experiment myself to get it to work to have some WD out of it. The factory was totally clueless.
My application was on a 30' Air Stream International.
Old 06-06-2019, 08:39 AM   #9
dznf0g's Avatar
Oswego , Illinois
My only experience with this hitch is my personal applied tech knowledge (my profession), reading here, and installing and testing on my bro-in-laws 16' retro trailer. I am convinced that this hitch design works well up to maybe 5000 pounds. Above that and I believe it just won't work adequately, by its design.
-Rich-
Old 06-06-2019, 10:49 AM   #10
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
In consideration of the damage Andersen and family did to a national park, I would get rid a hitch I owned built by him. http://www.airforums.com/forums/f224...179854-11.html
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 06-23-2019, 09:52 AM   #11
2019 26' Flying Cloud
Summerfield , Florida
I use the Andersen Hitch with my 2019 Flying Cloud 26RB. Tow it with a 2018 Ford F-150 XLT. Though draw chain tension and correct ball height, I have the trailer and truck rails within one bubble. Turn the anti-sway off on the truck..as per Andersen. 7000K miles so far. Very pleased with comfortable ride and hitch sway control. No regrets.
Pubtym is offline   Reply With Quote
Old 06-23-2019, 10:29 AM   #12
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
I took note of your comment that Andersen says to turn off your truck's ESC so I looked it up. Here's what it says:
Using the WD Hitch with late model
vehicles that have electronic anti-sway
The Andersen WD Hitch features its own sway control system that is designed to auto-adjust to the load in
your trailer and prevent trailer sway when installed properly. Unfortunately, some newer electronic anti-sway
systems can misread the anti-sway efforts of the Andersen WD Hitch and the anti-sway system may actually
cause the trailer to sway as the two systems work against each other.
These potential issues typically occur with electronic anti-sway systems that are designed to detect trailer
sway and automatically use the vehicle brakes to help control the sway. Please note that this type of anti-sway
system is different from electronic traction control, which does not cause this type of problem. If you experience
this type of issue, you will need to turn off the electronic anti-sway in your vehicle in order to tow with the
Andersen WD Hitch.
This issue is most likely to occur in 2011 and newer truck models from Ford, GMC, Dodge, and Chevy. Refer
to your tow vehicle’s owners manual to determine if you have built-in electronic anti-sway and how to disable it
while using the Andersen WD Hitch to tow.
I would not turn off the ESC. I would ask for my money back on the hitch.
out of sight is offline   Reply With Quote
Old 06-23-2019, 12:48 PM   #13
Long Island , New York
Originally Posted by out of sight View Post
Unfortunately, some newer electronic anti-sway systems can misread the anti-sway efforts of the Andersen WD Hitch and the anti-sway system may actually cause the trailer to sway as the two systems work against each other.
FWIW this is why we got the new Reese WD hitch, without sway control, for our 2017 Ford Transit 350 TV with ESC.
Many new Airstream owners, with newer tow vehicles, may not be aware of this potential conflict between the two systems IMO.
Peter
FYI/FWIW
Old 06-24-2019, 06:16 AM   #14
Thanks. Like I said, 7K miles on last trip. Strong gusty cross winds with ESC off. Bumpy roads etc. I'll keep the hitch and turn the ESC off. It's hard to describe the comfortable ride and Anti-sway features of the hitch if you have not driven your rig with an Andersen. I have towed trailers with spring bars. OUCH! What a shake-up.
Anderson Hitch and Atwood Coupler Siegmann Hitches, Couplers & Balls 11 11-27-2016 11:28 AM
Used Anderson WD Hitch Secguru Airstream Classifieds 0 10-02-2014 09:58 AM
Anderson hitch coupler issue...... catsmith Towing, Tow Vehicles & Hitches 7 09-26-2014 08:01 AM
