Old 11-13-2014, 01:52 PM   #225
1974 Argosy 20
Kooskia , Idaho
The Andersen people at the factory in Idaho Falls ID actually took photos of the bolt pin arrangement I had when I visited them this summer and thought it was a very good solution to the slight potential problem with the Atwood 87xx hitch.
The chains used on the Andersen hitch are attached with solid chain link devices on the triangle plate which is pined to the bottom of the hitch ball assembly, and are bolted to the A frame of the trailer via the frame brackets. So the chains themselves become extra "safety chains" which have no play in them. One can argue probably 10 to 20 different ways that ANY WD hitch could become detached, given some very unusual circumstances. There is no evidence that the Andersen is any more prone to detachment than any other hitch.
A defective Atwood 87xx coupler which has been used on Airstreams for years and years has the same possibility of detachment, used with any other hitch, especially on a downhill run where the trailer is pushing the tow vehicle. Apparently Airstream does not find it to be a problem, as they are using the same coupler on all Airstreams built today.
There are lots of good WD hitches out there, if one does not like some aspect of one, then choose another. It is nice that we have a choice in this country.
Old 02-27-2015, 07:22 PM   #226
1998 30' Excella 1000
Livingston , Texas
I recently got an Anderson hitch. I did not care for the bright red color of the urethane springs. A little too loud for my taste. I figured paint would not be a good idea, with the compression/expansion that these springs go through. My solution was to recycle a failed rubber inner tube from a bicycle. When cut to length, it fit perfectly (see photo). While it probably will not last long in the sun, I'm not worried; I can make more than a dozen of these out of one inner tube (which was going into the trash anyway).
Siegmann is offline   Reply With Quote
Old 02-28-2015, 08:13 AM   #227
2013 25' Flying Cloud
san mateo , California
People are just smart, I'm loving that as I love my Andersen. It does provide some protection from weather, too. Thank you for sharing.
dmand001 is offline   Reply With Quote
Old 02-28-2015, 10:21 AM   #228
Livingston , Texas
Oh, forgot to mention, depending on the diameter of the inner tube, it can be a real struggle to slip it on over the spring. A little dish soap will work wonders.
Old 02-28-2015, 10:23 AM   #229
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Agree! Nice job Siegmann!
SteveSueMac is online now   Reply With Quote
Old 03-23-2015, 12:37 PM   #230
Livingston , Texas
I will not be towing with my new Andersen hitch until the end of the month, and have not yet replaced my Atwood coupler. But for those that are using their old Atwood with the Andersen hitch, I would like to repeat a tip offered quite a while ago, I believe by dmand001. As others have noted, when a ball is latched in the Atwood, it allows about a 1/4 inch up-down movement between the ball and the coupler. As I understand it, this can potentially cause the dreaded "shark fin" shear-off when underway. I stacked a few washers on top of the ball before inserting it into the coupler, as described by dmand001, and with a little experimentation with the number of washers, was able to get the ball snug, with no up-down free play. What equipment you choose to tow with is up to you, but I thought it was worthwhile to repeat this ingenious tip.
Old 03-23-2015, 12:57 PM   #231
Leavingtherut.com
TavnAsh's Avatar
2005 30' Safari
Key Largo , Florida
I bought an Anderson last summer for our 30 Bunkhouse, 7800 lbs. We tow with a 1 Ton flatbed weighing in at 9200 lbs empty, so I never really had a sway problem. However after installing the Anderson, I have been pleasantly surprised. The truck rides smoother, and I do notice a huge increase in predictability and tracking. I no longer need to adjust steering much for passing trucks.
First thing I did prior to installing the anderson was cut off the Atwood 82xx and install a Bulldog 15k collar lock, part number 028655. With hitch and welder, I have about $130 into the new hitch. Great setup, I recommend, and I am a lot more confident in the bulldog coupler then the old atwood. There is no way to close the bulldog collar if the hitch is not on the ball correctly. If it closes, it is secure and never coming off. Period. The collar automatically locks, and even if I forget the pin, it is positive force and wedges the whole thing shut. Not coming off.... Pics follow.
ID:	234808   Click image for larger version
ID:	234810   Click image for larger version
Finding our normal, one day at a time.
http://www.leavingtherut.com
TavnAsh is offline   Reply With Quote
Old 03-24-2015, 09:54 AM   #232
Did just that & was planning on welding the top part of the ball slightly to alleviate that gap preventing excessive bouncing to prevent the shearing-off dilemma. It was successful for me though short term only as traded the vintage and bought a newer TT. Just for peace of mind went w/ replacing coupler altogether w/ a quickbite. Andersen's been a pleasure & g'luck w/ your situation. Please post as it does show promise.
Old 03-24-2015, 09:58 AM   #233
Looks great.
Old 05-17-2017, 02:29 PM   #234
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
There are several threads on the Anderson Hitch, with at least one closed. So I just picked this one to see if there are any updates to the usage of the Anderson hitch over the past few years. I am considering switching from an Equalizer to the Anderson. Overall, I have been happy with the equalizer, but the cons include that it is not particularly easy to adjust and it is just plain heavy.
Any update comments would be appreciated, and I apologize if there is a newer thread on this.
Steamy1 is offline   Reply With Quote
Old 05-17-2017, 02:41 PM   #235
HowieE's Avatar
Princeton , New Jersey
Images: 12
The only legitimate argument against the use of the Andersen on an Airstream is the cheap coupler Airstream is using.
Having been an early user of the Andersen I did experience the coupler shark fin failure and replaced the coupler with a Shark Bite, no longer available. There are several other types of coupler, including some stronger Atwoods, if the fin were to become a problem.
Lippert Industries bought the Shark Bite to shelve it as it was competition to one of their products. Another short sighted idea of American corporate philosophy much like the demise of the Jordan brake controller, which I also still use.
Contributing factors to the failure are poor roads, I live n New Jersey, and a very heavy trailer, mine is a 34 fter.
All in all even if you do replace the coupler you are ahead in all areas of consideration.
2004 Excursion 4x4
Old 05-17-2017, 02:54 PM   #236
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
I have been using it for awhile now. Just got back from a beach trip couple weeks ago. Yes, the cheap Atwood couplers are a concern, whether you use an Anderson or not. When I replaced mine with a Quickbite, I found a crack underneath, that was just waiting to cause trouble. I think the Quickbite is still being sold. It is very secure and easier to hook up than a conventional coupler, making the Anderson/Quickbite combo so much easier than my old setup, with bars, etc. For smaller Streams, like our Bambis, I know of no better way to go.
I don't know if there are any updates to Anderson, but mine is still going strong, with no signs of wearing out.
Rich of SCal is offline   Reply With Quote
Old 05-17-2017, 04:59 PM   #237
Thank you for the responses!
na´ve question; what is the procedure for replacing the coupler? does it take a trailer shop to torch off the original and weld a new one on?
Old 05-17-2017, 07:07 PM   #238
2012 16' Sport
Yes. I was lucky, since I had a welder as a neighbor at the time. Any qualified welder should be able to do it, not just a trailer shop. I ordered my Quickbite online. It came with a collar that fit right over the A-frame. Took about half an hour, at most.
