Old 02-17-2014, 02:06 PM   #141
HowieE's Avatar
Princeton , New Jersey
Images: 12
HIHoAuRv
A very interesting post and an almost direct comparison to my 91 34fter. and Excursion diesel.
The things I see as different are the 100lbs. plus the Hensely adds to the tongue weight, the foot of leverage the extra length of the Hensley adds to the trailer tongue, the possible difference in the distances from the rear axle to the trailer ball, and possibly different capacity of the rear spring packs of the 2 trucks. While all of these would effect the lifting of the front axle I can't believe they would make that much difference.
It does make one thing clear here. Unless one goes for Overkill some strong do diligence, in finding others who are successfully using your combination, is required before selecting the Andersen.
2004 Excursion 4x4
Old 02-17-2014, 02:48 PM   #142
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
If you are reading this thread to help you determine whether or not you should buy an Andersen hitch, just keep in mind once you purchase and install the hitch, you own it.
Andersen nor the distributor will stand behind their guarantee and give you a refund if this hitch is incompatible with your equipment.
star kitty is offline   Reply With Quote
Old 02-18-2014, 05:14 AM   #143
Harlingen , Texas
When did this become a Hensely vs. Andersen contest? Nobody is suggesting that users switch hitches (say that three times really fast). The Andersen provides many benefits and great performance for lots of people. Is it for everyone? What is?
There is no "One size fits all" tow vehicle, trailer, or hitch. If you have an adequate tow vehicle in the first place, then the Andersen works well. If you need the maximum weight distribution with a fairly heavy trailer, then steel bars make better levers than the urethane bushings that the Andersen hitch uses. Really not that complicated.
This whole front axle weight restoration thing is really interesting. Why does my HD2500 with a gas engine and 500 pounds less weight on the front axle compared to the same model with a diesel manage to go down the highway straight as an arrow? Most, if not all, who complain of front end lightness are really feeling the effects of an overloaded rear suspension. If you tow enough miles with enough variety of equipment, you will know what I am talking about.
Rendrag is offline   Reply With Quote
Old 04-22-2014, 08:51 PM   #144
1973 31' Sovereign
Latrobe , Pennsylvania
Unless it is purchased via Amazon Prime....which is what I'm about to do. If the Andersen doesn't fit the bill, I'll return it and get a Reese Strait Line. BTW, I'm a Ford guy but this hitch is for the ML320CDI and a 31' Sov.
Whaddaya think, folks?
el_anesthete is offline   Reply With Quote
Old 04-22-2014, 09:28 PM   #145
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Read the thread, it can't distribute the weight you need with this setup. Save yourself the failed experiment I went through with the Andersen, and get yourself the Reese. Join the thousands who know it will work very well.
Doug and Cheryl
Old 04-23-2014, 07:08 AM   #146
Harlingen , Texas
doug, does this mean that you do not recommend the Andersen hitch? Perhaps you need to repeat it more often. (sarcasm intended)
Old 04-23-2014, 07:20 AM   #147
SteveH's Avatar
Common Sense , Texas
Doug has it right, the Andersen hitch works well with small, light tongue weight trailers, but has proven to not be able to distribute the tongue weight correctly of a 31 footer.
Regards,
Steve
Old 04-23-2014, 07:35 AM   #148
HowieE's Avatar
Images: 12
There are several streamers that do not recommend the Andersen hitch. However they are clearly in the minority when compared to those actually using the Andersen. If you have questions I would suggest you read this thread.
http://www.airforums.com/forums/f464...ead-92131.html
There are some TV Trailer combinations that the Andersen will not provide the results some think they need. Most of those requirement are based on Older interpretations of what a WD hitch was originally designed for, very lightly sprung TV. If your combination falls in the grouping I would not suggest you consider the Andersen. However if want a superior system you will find far more satisfied streamers than dissatisfied.
I will advise you that do to the mechanical design of the Andersen that you will eventually have to replace the coupler on the trailer. Even given this addition cost the resulting ride and overall convenience of operation is well worth it.
While I have no knowledge of an attempted return of an Andersen I can say they have a history of above average cooperation with customers to address issues from replacement of shanks that were the wrong size to incorporating design modifications that customers have suggested.
2004 Excursion 4x4
Old 04-23-2014, 08:34 AM   #149
1987 25' Sovereign
Oregon , Ohio
I have a 1987 25' Sovereign that has a tung weight of about 900 lbs.( 6000 lbs. X .15 ), This multiplier was given to me by the Jackson Center service manager. When I first installed the Andersen hitch and Quick Bite coupler my TV was a 2001 F150 Supercrew, I added helper springs and the combination worked wonderfully. I then bought a F250 supercab because of lower mileage and a very good price because it is two wheel drive. This truck also does a wonderful job of towing. I will add that on both I had a front 2" receiver hitch for a bike rack and two 26" Schwinns. This adds about 300 to 400 pounds at the front bumper. I would recommended the Andersen hitch when the TV is a beefed half ton truck, 3/4 ton truck or a beefed Excursion - Suburban type vehicle.
May also say that I agree with HowieE and his views about the Andersen Hitch!!!
msmcv51 is offline   Reply With Quote
Old 04-23-2014, 04:19 PM   #150
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, it is very true that Doug has repeated this comment/opinion/ or similar statements several times. And comments like your's [Rendag] has followed almost every time. Doug has experience with this brand hitch and has as much right to give his opinion, and as many times, as those who favor this brand hitch. Now pardon me while I go back to the Equal-I-zer thread.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 04-23-2014, 04:27 PM   #151
Harlingen , Texas
Do you have personal experience with the Andersen hitch? Doug did So have I and many other happy users. Sorry to distract you from the other forum.
Old 04-23-2014, 04:47 PM   #152
Salem , Oregon
Images: 18
Hi, NO! I don't, as a matter of fact, but at one time was interested in possibly changing from my Equal-I-zer brand hitch to an Andersen. So glad that I didn't. Nine years with one hitch, one trailer, and one tow vehicle and my trailer has only swayed violently out of control once in all of that time and in the many thousands of miles we have towed.***
*** My trailer was parked in my driveway during a 5.0 Earthquake.
2005 Safari 25-B
Old 04-23-2014, 06:55 PM   #153
Harlingen , Texas
Since you never towed with a Andersen hitch, then I agree that you have picked the best hitch for your application. I have towed with five tow vehicles, four hitches, and five travel trailers in the last nine years. Many who have actually used a Andersen hitch enjoy their benefits. Watch out for earthquakes, fast trains and the women on Bourbon Street. Enjoy your equalizer.
Old 04-23-2014, 07:11 PM   #154
1973 31' Sovereign
I see it as this:
If the Andersen can level the AS and the TV within 3/4" of an inch of each other, who cares about precise pounds of weight transferred? Mercedes has an amazing ESP system on top of robust turbodiesel power so all I'm concerned about is simply a level ride and anti-sway. FWIW, I'm tugging the AS around less than 100 miles at a time amongst rural hospital, leaving it parked for 3 months at a time then moving on to another place of work. I won't be cruising at 60 in the right hand lane on I-70 during my deferred vacation, getting blasted by big rigs day in/day out like other full timers who are poo-pooing the Andersen. I'll expect automatic entrance to pissing contests with the Ford/Chevy/Dodge contingent and their leaf-sprung, body-on-frame TVs, and I'm chuckling at the fun conversations we'll no doubt enjoy. I have a Ford F350 dually with a 460... and the MBZ is far more capable at most everything, apart from stacking a cord of firewood on the flatbed, or guzzling unleaded at 6mpg. The Ford does have broad shoulders.
So far, I haven't read proof of any correlation between actual pounds of weight distribution (as evidenced by weight tags) and actual happiness of Andersen users vs. other WD hitch users. Has there been a catastrophic porpoise/jackknife event with the MBZ/Andersen/AS combo yet? Is there a scale that will compute a happiness/logic coefficient that we can apply to different TV/TT combos? Using a CAT scale, how can we accurately measure happiness?
If the Andersen levels my rig within 3/4" and I find satisfaction in that balance, who gives a hoot? I just don't see why it won't perform for my intended flipper, er...porpoise, cough PURPOSE, as such. The rebuttals include "...it can't distribute the weight you need with this setup. Save yourself the failed experiment..." and "If your combination falls in the grouping I would not suggest you consider the Andersen. However if [sic] want a superior system you will find far more satisfied streamers than dissatisfied"
Talk about mixing the subjective with the unproven! Here's where we need the coefficient of happiness!
FWIW, an anecdotal towing tale, based purely on the subjective facts as my coral-like prefrontal cortex perceived them: the ML WITHOUT a WD hitch or anti-sway system, I tugged a 1982 Toyota Landcruiser along with an extra set of wheels/tires PLUS a complete 3F motor/transmission stowed aft of the 'cruiser, all loaded willy-nilly on a 24 foot, surge brake-equipped, double axle trailer (all told at least 7000lbs) from Denver to Ouray, traversing the 285 across South park with its insane head/crosswinds, followed by 9% Monarch pass up, over, and down the continental divide... then the smaller "hills" between Gunnison and Montrose, ending with a bonus slog up 3000' to Ouray, deep within the San Juans....without a single thought. No advanced towing gear on that trip, no white knuckles, no drama. What gives?
Tell me how a 6000 pound trailer with even the most rudimentary anti-sway WD hitch can't improve on that experience? I think the Andersen will do just fine. Who's reasonable and who's fanatical? The logic escapes me.
I'm ordering the Andersen from Amazon.com, installing it, and taking a ton of pictures with a measuring tape and level. Then, after all the facts are in, I'll express my feelings. I will then choose to pontificate.
One thing I know for sure, regardless of the outcome, I get free shipping back and forth with Amazon Prime...no questions asked.
