Old 02-26-2013, 03:02 PM   #1
sandhill3000's Avatar
2013 19' International
Englewood , Florida
Andersen Hitch installation on a 2013 19' International Bambi?
Has anyone installed an Andersen W/D hitch on a late model 19' International Bambi? It looks as though the propane tank cover or gas line might be a problem or in the way.
Thanks...
sandhill3000 is offline   Reply With Quote
Old 02-26-2013, 05:55 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks...
I haven't but there are a couple threads here (search Andersen) that have details that might help. Good luck.
Old 02-26-2013, 07:48 PM   #3
Englewood , Florida
Yeah, I did that...all hundreds of pages. LOL
Old 02-26-2013, 08:09 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The gas line is flexible and can be bent out of the way of the bolts. If the tank cover can not be moved consider adding links to the chains to move the brackets reward using the links as in post 1415 of this thread
http://www.airforums.com/forums/f464...92131-102.html
2004 Excursion 4x4
Old 02-26-2013, 09:42 PM   #5
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
3 minutes per page = 5 hours of reading pleasure and lots of entertainment to say the least!
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-26-2013, 10:13 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
This my Andersen on our 25' Airstream, yours should be similar. The gas line is in the way, take loose the clamp and move it aside.
Follow the instructions. Through-bolt or weld the top side of the frame brackets to keep them from moving, and do not try to tension the chains unless the tongue jack is supporting tongue weight, then after tensioning raise the jack, as per instructions.
doug k
Old 02-27-2013, 05:06 AM   #7
Englewood , Florida
Thanks everybody. That information helps a lot.
The people on this forum are such a wonderful source of information. Maybe someday I'll know enough to contribute rather than just ask questions!
Old 03-08-2013, 07:50 PM   #8
Puyallup , Washington
doug k - shouldn't those safety chains be crossed over that bracket and short chain?
srpuywa is offline   Reply With Quote
Old 03-09-2013, 07:44 AM   #9
dkottum's Avatar
I don't think so, although I suppose they could be that way. The safety chains are there to keep the trailer attached, a backup in case something on the hitch breaks loose.
On my 2007 Airstream we would cross the chains to form a cradle to catch the tongue if it fell loose, on this new one the chains are attached at the same point on the tongue, so they cannot be crossed.
doug k
19' international
2008 Airstream International Ocean Breeze 19' Bambi Travel Trailer eBay Watch Airstreams on eBay 0 01-21-2012 12:20 PM
2010 Airstream 19 International Signature Bambi REPO eBay Watch Airstreams on eBay 0 01-17-2012 01:10 PM
2010 Airstream 19 International Signature Bambi REPO eBay Watch Airstreams on eBay 0 01-06-2012 07:40 AM
Rosco :: 2004 International CCD Bambi Grizzly6 Airstream Registry Discussions 0 08-19-2011 08:31 AM
2010 Airstream Bambi International eBay Watch Airstreams on eBay 0 01-31-2011 12:30 PM
