Old 02-20-2012, 02:19 PM   #1
2012 dodge 4x4 diesel
1975 Argosy 22
Truckee , California
Airsafe hitches? Yikes, please help this Argosy gal out!
wow, just when I thought I was getting the hang of being an rv'r after 8 years. I've been informed I should get an Airsafe hitch before I knock more things out of shape on my argosy. Had no idea such a thing exisited, or that I was causing so much distress with my stiff vehicle.
I have read many of your posts about it, thank you all so much as its very informative. They are all a few years old, so maybe someone out here has some new advise for me. I pull with a dodge 2500 cummins, 4x4. I spoke to lloyd today at Airsafe and he said a class 5 would be good.
Any comments before I make this very pricey purchase? and do most keep it on the receiver, even when they aren't pulling (assuming locked)? It looks pretty big, I would hate to rear end someone backing in to a parallel parking spot. If I already have a ball on my hitch, I could just have that one put on the Airsafe, and would just have to get that plate?
comments, anyone? is there an aftermarket version yet?
Cheers,
Argosybanker gal
gypsybanker is offline   Reply With Quote
Old 02-20-2012, 02:23 PM   #2
dznf0g's Avatar
Oswego , Illinois
Do you have access to a lighter TV? 2500 (especially) Dodge is extremely beefy for a 22'er. What kind of WD are you running?
-Rich-
Old 02-20-2012, 02:41 PM   #3
1975 Argosy 22
I have no plans on getting rid of my TV right now. I've had it since 2004 and have been very happy. I do also have a 31ft 5th wheel thats really heavy. I do not have special WD system, just the hitch that the trailer came with......
Old 02-20-2012, 02:47 PM   #4
dznf0g's Avatar
Oswego , Illinois
So you're not running any WD???? If you really have issues caused by lack of "suppleness" at the ball, an Airsafe may be your only solution.
-Rich-
Old 02-20-2012, 02:55 PM   #5
1975 Argosy 22
Yeah, thats what I'm trying to find out. I had a newer box trailer the first 6 years pulling, and maybe that was built for a wider selection of TV's. Thanks!
Old 02-20-2012, 03:00 PM   #6
dznf0g's Avatar
Oswego , Illinois
What, exactly, have you seen with your Argosy that drives you to a softer hitch setup? Pictures?
-Rich-
Old 02-20-2012, 03:06 PM   #7
1975 Argosy 22
I took it to an airstream restoration guy yesterday, and he told me I might want to look in to it. And explained why I had lost so many rivets popped out, a new leak on a window, a slight mishape in the stream of riveted area thats below the fresh water tank intake in front, a portion of the underpanel falling off, some shelving becoming loose, Hard to say whats to blame for the different items.
Old 02-20-2012, 03:13 PM   #8
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I'm particularly liking this version, kind of stealth to.
Airbag Hitch
truckasaurus is offline   Reply With Quote
Old 02-20-2012, 03:14 PM   #9
dznf0g's Avatar
Oswego , Illinois
Where are the popped rivets? Are you sure your axle(s) are healthy?
-Rich-
Old 02-20-2012, 03:23 PM   #10
2010 25' FB Flying Cloud
Davenport , Iowa
you mentioned about leaving the hitch on; some states are outlawing such a practice.
hefty fines.
Airtandem is offline   Reply With Quote
Old 02-20-2012, 03:41 PM   #11
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I pull a 22' CCD with the Dodge Cummins 3500. The truck is over rated and I feel very comfortable in it. The truck has the power I need, Im real fond of passing on a long uphill climb and I can pretty well plan on stopping when I want
I use an Airsafe hitch and I love it. My trailer has a very soft ride because of the hitch. I wouldnt be without it. When Im doing a lot of traveling its on the back of the truck. Its heavy but it is manageable. I fashioned a handle that makes moving it a lot easier. I would not be without it!!!
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-20-2012, 03:57 PM   #12
1975 Argosy 22
@ Brads, do you have the class 4 or calss 5 airsafe?
@rivetmaster, my axels are being replaced next month. rivets have popped out around the door, which is now a little bent outwards on the top and bottom of the right side of the door. rivets have popped out on the bottom front and bottom rear. The rivets holding the trim in the rear popped out so the trim came loose.
Old 02-20-2012, 04:06 PM   #13
1975 Argosy 22
Truckasauras, that airbag hitch looks a little too hefty for me. thanks though!
Old 02-20-2012, 04:13 PM   #14
dznf0g's Avatar
Oswego , Illinois
Not sure if you're addressing me with the "rivetmaster" thing. I only get that 'cause I talk too much...OK? That being said, with the all over rivet popping, IMHO, your issue is more axle than hitch.
If I were you, I'd replace the axles, replace the rivets and watch things closely for awhile.
Then decide whether to spend the $$ on the airsafe.
-Rich-
Does anyone know this awning/Airstream owner? Shirlee Law Awnings 13 06-30-2015 05:14 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
Airsafe hitches? Yikes, please help this Argosy gal out! gypsybanker Hitches, Couplers & Balls 39 02-27-2012 06:32 PM
Need someone to make curtains-Help! jack SF Upholstery, Blinds, Walls & Interior Finishes 5 02-21-2012 10:43 PM
1977 Argosy Airstream trailer 24' eBay Watch Airstreams on eBay 0 02-20-2012 12:40 PM
