05-28-2013, 01:06 PM
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village
, Arkansas
AirSafe Hitch and Rock Tamers
Has anyone used Rock Tamers with their AirSafe Hitch? The one I ordered did not have sufficient room to install the Rock Tamer bracket, although the Equalizer draw bar did.
I would appreciate any help.
Rick
05-28-2013, 02:50 PM
2006 22' International CCD
1957 26' Overlander
Plymouth
05-28-2013, 02:54 PM
1957 26' Overlander
Plymouth
Not sure if my reply with photo worked. Ill try when I get home. What you do is remove the mud flap holder from the yoke and bolt it to
the Airsafe hitch
05-28-2013, 03:02 PM
2010 27' FB Classic
N/A
It all depends on how the receiver and hitch come together and how much room is left. I have both (rock tamers & airsafe) and mine worked as is, no modifing needed.
BradS has a nice solution if a mod is required.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
05-28-2013, 03:38 PM
1957 26' Overlander
Plymouth
Hi again. Sorry the text didnt come through. I purchased a couple of 5/8" bolts and nuts and mounted the Mud flap holder right to the Airsafe.
05-28-2013, 03:50 PM
Hot Springs Village
, Arkansas
Thanks for the quick reply. Did you drill a hole in the AirSafe bracket, or was there one already there?
Rick
05-28-2013, 04:43 PM
1957 26' Overlander
Plymouth
Hi Rick The hole was there, no modifications and I love the setup. I pull a 22' CCD with a one ton Dodge and the trailer rides very smooth.
05-28-2013, 05:45 PM
Hot Springs Village
, Arkansas
Thanks, Brad. Great pictures. Now that I looked at the Class IV hitches, I see a hole where you mounted yours. The Class V hitch does not have a hole there.
We tow a EB 25 foot A/S so we opted for the Class V. But, they do have a Class V with a longer insert, (shank). It is two inches longer so I hope this does not present another problem
Rick
05-29-2013, 08:57 AM
Contributing Member
Austin (Hays County)
I did the same as Brad when I had an AirSafe. Worked great. I now have a ProPride and installed flaps on the truck.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
08-27-2014, 06:08 PM
2005 31' Classic
Gretna
, Nebraska
Air Safe Hitch
I have known about these for a couple years, but recently I had an incident which resulted in some separation of the frame and body of my 31' Classic. I think it happened crossing an intersection where there was quite a drop on the descending side of the intersection. Now I have an appointment with the factory for repairs.
I don't know if this hitch box would have prevented it or not.
Comments?
Dwight
08-27-2014, 06:33 PM
1981 31' Excella II
New Market
, Alabama
Newer trailers are weaker and don't have steel hold down plates in the front and rear. They also have fewer rivets.
Perry
08-28-2014, 06:38 AM
2014 30' Flying Cloud
Hilliard
Does a airsafe work with the equalizer hitch. How do they bolt together. I have equalizer now.
Rod
08-28-2014, 06:44 AM
1972 25' Tradewind
Hopkins
The AirSafe can be purchased with a ball mount adapter or a weight distribution (equalizer) adapter. I just bought mine with the ball mount to start. Will decide if I need the wd later. The adapters are only about $100...so not a big deal.
08-28-2014, 06:55 AM
Francisco
, Indiana
I did the same as BradS. Mine had the holes just bolted it up.
Really like the flaps and the AirSafe hitch.
Hickory
08-28-2014, 07:22 PM
1963 19' Globetrotter
Orion
Just did the Equalizer/ Airsafe set up . You have to get the Airsafe WD bracket and then attach the Equalizer head to it. My Rock Tamers won't fit on it but the bolt on idea should work fine.
08-28-2014, 07:44 PM
Hot Springs Village
, Arkansas
If you get the longer shank from Airsafe, there is enough space to accomodate the Rock Tamers.
Rick
08-28-2014, 08:15 PM
1948 22' Liner
1989 34' Limited
long beach
, Mississippi
This might be a stupid question but How is the air safe with equalizer in comparison to a hensley hitch ?
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
08-29-2014, 12:46 PM
Orion
Did not know they offered a longer shank .When I ordered mine no mention was made about that.
08-29-2014, 02:24 PM
1996 34' Excella
Elberta
, Alabama
I've had my AirSafe for four years and nearly 100K miles. It's easier to hook up,
The trailer rides better. My setup is with the Reese Dual Cam, but Equalizer
concept is the same.
Plus it weighs a lot less.
Larry C
08-29-2014, 03:51 PM
Hot Springs Village
, Arkansas
63air, when I ordered mine they had a Class V with a 2 inch longer shank.
Rick
