Originally Posted by SilverToy
... Are you having 2nd thoughts on the addition of the mor-ryde or is it a timing issue?...
hi silvertoy...
it has been a timing issue mostly.
i'm traveling so much and yet have not been near an installer often...
and don't plan to do it myself, even though it's pretty easy to change out the rear shackle.
i recently ADDED another leaf to the 250 stack and am breaking it in now...
morryde pros:
-it's part of the suspension NOT part of the hitch/receiver/tongue
-always active
-truck ride improved even when NOT towing
-works with any hitch and w/d system
-models available for many vehicles
-the ride qualities of 'rubber' like henschens/dexter axles
-no adjustments based on tongue mass changes (no bladder to inflate)
-dampens 'harshness' without affecting load carrying capacity
-since it is a shackle replacement it's hidden from sticky fingers/eyes
morryde cons:
-the rubber section needs to be replaced occcasionally (3-7 year cycle)
-may need a new stinger with different drop
-limited dealer network
the air-ride won't work with a hensley without a specially fabricated stinger, and there is NO WAY i'd give up the haha...
don't forget to include the cost of a class 5 receiver with the air-ryde...
the air-ride moves the ball/tongue back/away from the axle another 10-12 inches...
so sway control systems are negatively effected. this may not be an issue with 1 ton or dually rigs...
it is readily visible to all so it must be locked or removed/hidden when not in use.
i think both approaches are worthy...
i've ridden in a 1 ton dually with the morryde and it is a significant improvement...
really the bed/rear end was very smooth, like butter!
cheers
2air'
