Old 03-27-2016, 06:15 AM   #1
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Air Safe Hitches
Do any of you use an Air Safe Hitch, as I have been reading about on Airstream Addicts Facebook page? Comments?
http://airsafehitch.com/category/air...vers/class-vi/
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 03-27-2016, 06:26 AM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
When I'm searching on this forum, I tend to use the advanced search feature and search in the title area...
Hope this helps!
Bruce
http://www.airforums.com/forums/f238...le-146495.html
http://www.airforums.com/forums/f464...bo-114850.html
http://www.airforums.com/forums/f238...hes-89093.html
http://www.airforums.com/forums/f464...nce-91460.html
Bruce B is offline   Reply With Quote
Old 03-27-2016, 09:20 AM   #3
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
I use Airsafe with Equalizer weight distribution bars on 27 AS pulled by Chev HD2500. Love the easy set up. Hitch is an SOB to pick up as it is very heavy. Leave it on during summer so as not to have to take on and off.
Hiwheel Joe is offline   Reply With Quote
Old 03-27-2016, 09:25 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
IMHO.....it would be a bit of overkill with your softly sprung TV & 20' AS.
Get the WD & sway control set properly with a LEVEL rig and you should be fine.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-27-2016, 09:38 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
How much does the Airsafe hitch weigh? For those of us using tow vehicles with relatively low payload capacity, it might break the tow camel's back ;-)
Old 03-27-2016, 10:01 AM   #6
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I have a Safari Sport 17, like yours it's single axle & light weight..........I use this inexpensive & easy to set up device, seems to work fine...just load the AS carefully..........It's a lot easier than the Equalizer set-up on my FC28..................travel safe, Craig
Eaz-Lift 48380 Right Hand Passenger Side Sway Control Bar
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 03-27-2016, 10:10 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
An interesting mechanical concept but it leave a few questions.
It looks like, without significant modifications, that it will only work with the Equalizer WD system. I say this because any other hitch head would require welding and once welded there would be no head tilt adjustment.
it is not clear in the video if head tilt is available in the system filmed. A requirement for original setup and to correct for ware.
It is a shame that they had to voice the urban myth that a WD hitch transfer 1/3, 1/3, 1/3 of the weight. Using such a false statement cause one to maybe question some of their other statements.
2004 Excursion 4x4
Weigh Safe Trailer Hitches BoldAdventure Hitches, Couplers & Balls 2 02-12-2015 09:00 AM
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Air Safe hitches.... Silvertwinkie Towing, Tow Vehicles & Hitches 27 09-04-2014 05:44 PM
Gun/Valuables Safe - What safe is the best? BrandonJenna General Interior Topics 22 02-21-2013 12:24 PM
Air Safe Hitches loft47 Hitches, Couplers & Balls 4 04-22-2009 03:50 PM
