Old 05-21-2012, 06:30 PM   #1
2001 34' Excella
Edinburg , Texas
Air Safe Hitch Any Users Experience?
I am considering buy a Air Safe Hitch & using it with my Equalizer Hitch on my 34' 2001 Excella.
Has any one had any experience with the Air Safe Hitch?
jbailey01 is offline   Reply With Quote
Old 05-21-2012, 07:05 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
Siloam Springs , Arkansas
Welcome to the forums.
We have one. We like it. The items in the back of our 27 FB looked like it had been in a dryer after a day on the road.
The Air Safe helped soften things quite a bit.
Regards,
Jeff & Cindy
Remi & Hunter
'09 27FB Flying Cloud
WBCCI #7026 Air #17054
"Fus-A-Lodge II"
jdalrymple is online now   Reply With Quote
Old 05-21-2012, 07:23 PM   #3
Connellsville , Pennsylvania
I have used them in the past but sold the one I had with the last trailer. They really settle down the harsh ride. Well worth the investment, but relatively expensive for what they are.
Midnightmoon is offline   Reply With Quote
Old 05-21-2012, 07:41 PM   #4
1999 34' Excella
Troy , Texas
Airsafe ...yes
I purchased the airsafe VII...for my excella 34'...and use the equalizer weight distribution ...absolutely stopped 98% of the porposing...no sway...I don't worry about concrete highways and bridges anymore...I have used the airsafe approximately 16 months now...One of our unit members purchased one after viewing mine 4 months ago...he has only praise for the airsafe ...
excella99 is offline   Reply With Quote
Old 05-22-2012, 01:04 PM   #5
Airstreamer67's Avatar
My Class V AirSafe has served me well in the six years I've owned it. I tow with a heavily sprung pickup, and the AirSafe has stopped damage to my trailers. No more split skin, popped rivets or shaken-up contents. Just smooth sailing over the rough roads we travel.
Airstreamer67 is offline   Reply With Quote
Old 05-23-2012, 12:05 PM   #6
2001 34' Excella
Edinburg , Texas
Air safe V or VII
itch.
Did you need the VII? It appears to me from the specs that the AS V at 1400 lbs TW would be sufficient. allowing for the 25% red using the Equalizer WD hitch.
Thanks, Jim
Old 05-24-2012, 05:42 AM   #7
1999 34' Excella
Troy , Texas
jbaily01
You are absolutely right...the VII was overkill....the reason I purchased the VII...was that my TW was new...and it had the 2 1/2 inch receiver..
at the time I bought mine...there was not much information on the Airsafe hitch...I didn't want to buy the V at the time because I would have to use the 2" sleeve adaptor...I thought it may cause play in the hitch...so I spent more than I had too...my friend bought the V for his set-up 34' with equalizer and he is completely happy with it...any way you cut it...its a soft connection...great ride...and the trailer has a smooth ride...
Old 05-24-2012, 06:11 AM   #8
1999 34' Excella
Troy , Texas
The only drawback to the Airsafe in my opinion is the weight of the thing...so what I did was buy a motorcycle lift from harbor frieght..it works great..if you want pictures...email me at rgill@clearwire.net I will send you pictures...
Old 06-15-2012, 08:43 AM   #9
Chaplain Kent's Avatar
1994 30' Excella
Wauwatosa , Wisconsin
Went from the comfort of a Classic 280 MH to the harsh and bumpy ride of the trailer. The AirSafe has made the ride tolerable. Drawbacks are getting it adjusted correctly and sway. I have not solved the sway yet but need to before our next trip. Overall I would not tow withiout our AirSafe. Even over RR tracks you feel nothing in the TV. Added advantage is that the ttrailer is not bouncing around.
Chaplain Kent
1994 30' Excella 1000, Chummy III- Ford Excursion- 7.3 Turbo-diesel www.milwaukeervrental.com
Chaplain Kent is offline   Reply With Quote
Old 06-15-2012, 08:51 AM   #10
moderator
Airslide's Avatar
2001 30' Classic S/O
Novato , California
Images: 50
Send a message via Yahoo to Airslide
Love the Airsafe hitch. The tongue weight of our slideout would influence the truck greatly but now that energy is isolated to the workings of the hitch. I really like the concept but its weird to look in the rear view mirror and see the trailer moving independantly of the truck.
Vinnie
2011 Dodge Dually Crew
https://www.facebook.com/NvcmmAirstreamRepair
Airslide is offline   Reply With Quote
Old 06-18-2012, 01:28 PM   #11
Silver Otter's Avatar
1999 30' Excella 1000
Nellysford , Virginia
Send a message via AIM to Silver Otter
We have a Hensley Arrow WD system, and love it. Any opinions on using an Air Safe system combined with the Hensley?
Greg and Linda Heuer
'99 Excella 30 w/HAHA - The Silver Otter
'08 Chevy 2500HD 6.6 DuraMax w/MBRP dual pipes
TAC VA-18 | WBCCI 1927 - Unit 149 | AIR 53869
Canopener Site #144
http://www.linkedin.com/in/gheuer
Silver Otter is offline   Reply With Quote
Old 06-18-2012, 01:39 PM   #12
2012 23' Flying Cloud
Sacramento , California
I would add my voice to the positive chorus. I have used an airsafe V for two years on my 2010 Tundra and pulled a 2008 25' Classic and now my 2012 23' Flying Cloud. The airsafe dramatically reduces the hit your trailer takes from starts/stops, poor roads (all that CA has right now), and unexpected maneuvers.
Dillon2 is offline   Reply With Quote
Old 06-18-2012, 09:04 PM   #13
moderator
Airslide's Avatar
Novato , California
Images: 50
I agree that it certainly reduces the shock of the potholes and rough road but dont think the four links do anything but allow up and down movement. The stops and starts are probably not affected by the airsafe. I am a big fan too though
Vinnie
Old 06-21-2012, 11:49 AM   #14
2001 34' Excella
Edinburg , Texas
Well, I purchased the Air Safe & have installed it on my F350 also using the Equalizer 4 point W/D. I hitched to the 34' Excella & the level is perfect & the W/D bars look right.
We will be off next week to British Columbia from our present location on Cape Blanco OR,
so as soon as I have experience & an internet hookup I will report back.
Thanks again for all of the ideas & comments.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
