Old 10-17-2016, 03:43 PM   #1
2014 23' FB Flying Cloud
Park City , Utah
Adjusting Friction Sway Bar
I have a Curt Friction Anti Sway Bar I am trying to adjust. The instructions just say to "try it" on the factory setting for the lower tension bolt, and adjust in quarter turns. How do you 'test' it on the road? I wasn't having any sway issues, so how can I tell how tight to make it? I'm assuming that until it's needed, I won't even feel it back there, so I have no idea if it's tight enough or not.
It's on a FC 23 FB BTW.
Thanks for any input.
pcskier is offline   Reply With Quote
Old 10-17-2016, 08:45 PM   #2
1986 31' Sovereign
Miami , Florida
Install it and then turn the handle as tight as you can get it with one hand. Should be about right.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 10-17-2016, 09:23 PM   #3
Park City , Utah
But what about the bottom bolt?
Old 10-17-2016, 10:17 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I put a Curt on mine....That is basically how I set mine up. If I remember correctly, the bottom bolt is to tighten it up after the friction pad gets some wear on it.
CRH is offline   Reply With Quote
Old 10-18-2016, 07:21 AM   #5
Gainesville , Florida
If you feel you do not have enough sway control then Tighten the bolt a quarter turn and see how that works.
Old 10-18-2016, 08:26 AM   #6
SteveH's Avatar
Common Sense , Texas
When I used those, I found the more I tightened it, the better it worked, until the point that I could actually feel that it was there when driving. Then I would loosen it 1/4 turn.
YMMV.
Regards,
Steve
Old 10-18-2016, 12:21 PM   #7
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
never had to touch it
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 10-18-2016, 01:12 PM   #8
1979 30' Argosy
Everton , Arkansas
I have a Reese double sway control and I tighten both sides as tight as I can get it and back off 1/4 turn. It creaks and groans when I'm making slow parking lot turns but feel great when towing.
DEDUBE is offline   Reply With Quote
Friction Anti Sway Bar Supports Slip dbj216 Hitches, Couplers & Balls 27 09-27-2016 07:56 PM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 11:05 AM
Sway Control - Old friction vs: New leverage & friction A W Warn Hitches, Couplers & Balls 43 07-14-2011 05:46 AM
Adjusting Friction Sway Control Lumatic Hitches, Couplers & Balls 1 06-29-2010 08:24 AM
Reese friction anti-sway bar broke Phantom Hitches, Couplers & Balls 18 11-28-2009 11:02 AM
