Old 03-26-2011, 07:40 PM   #1
Lucky Dog's Avatar
2014 25' FB Flying Cloud
Down the Shore , New Jersey
Adjusted the ball and hitch today
Getting ready for our first trip with the Silverado 2500 Duramax/Allison TV. Original hitch and ball height was set up by the AS dealer for our F-150 so after reading as many posts on the subject as I could, my son and I spent some time today adjusting the ball and hitch for the Chevy. I think I have it about as good as I can get it with the amount of experience I have. Am using the Reese WD and dual cam set up and the 800 lb trunnion bars. Without being able to get to scales yet, I think it is looking pretty good. I'm using 6 links on the chains as 5 jacked the rear up without too much difference to the front. I am thinking that is because of the big diesel sitiing up on the front axles of the truck. 6 links kept everything about the same with out too much stress on the bars.
Will try and post pictures in here; maybe some of you can give it an eyeball and let me know what you think. Trailer is a 23' Flying Cloud with lounge. Specs say max 6000# and a 750# tongue weight. For reference, there is about 7" inches clearance from the bottom of the hitch shank to the ground. Thanks for the help.
Rich
WBCCI #1512
2014 25FB Flying Cloud
2006 Chevy Silverado 2500 Duramax/Allison
Lucky Dog is offline   Reply With Quote
Old 03-26-2011, 07:43 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Sounds good... but you know we love pictures.
Hit the scales to be sure.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 03-26-2011, 07:43 PM   #3
Lucky Dog's Avatar
I don't think the pictures made it, will re-size and try again.
Rich
WBCCI #1512
Old 03-26-2011, 08:13 PM   #4
Lucky Dog's Avatar
OK, lets try for some pictures again.
ID:	125424   Click image for larger version
Rich
WBCCI #1512
Old 03-26-2011, 08:22 PM   #5
moderator
Airslide's Avatar
Wilton , California
Images: 50
The only problem I see is that the bars may make contact with driveways and such. You might consider the angle of the hitch and tip it a bit more. This will allow the bars to be a bit more horizontal when under load and a bit more ground clearance when out on the road. There are several threads here to better describe this. The overall setup looks level and a nice overall outfit.
Vinnie
Old 03-26-2011, 08:38 PM   #6
Lucky Dog's Avatar
I will re-check the distance from the ends of the spring bars to the ground before hooking up the trailer and perhaps tilt the ball head a notch (forward, toward the tailgate I assume you mean). Thanks, I appreciate the help.
Rich
WBCCI #1512
Old 03-26-2011, 08:46 PM   #7
A perfect setup with Reese bars and their sway control, is to have 5 links "under stress".
Your bars are too close to the ground.
Old 03-26-2011, 08:47 PM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Heres a picture of mine. Its a bit different because Im using an airsafe hitch and have round bars vs trunnian style. Even with my bars like this I still make contact once in a while.
Vinnie
Old 03-26-2011, 09:40 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Lucky Dog. Other than what has already been said, I have two things to add. If you are actually towing like this [or maybe just testing] I would install a lock or pin in the coupler latch. And when you are happy with your adjustments, I would cut off the excess on the bottom of your shank. I cut one hole off of mine.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-26-2011, 09:45 PM   #10
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thats a good point Bob. When you slam down on that you know it! and too often the chains find their way under it and grind away on the street.
Old 03-27-2011, 06:34 AM   #11
Lucky Dog's Avatar
Thanks for the replies. Yes, I do usually have a lock in the coupler and thought about cutting the last inch or so off of the shank. It bottomed as I was putting the AS back up into the driveway when we were done for the day. I will remeasure, adjust and get back to 5 links on the set up as Andy suggested. Vinnie, I can see how your bars are more parallel to the ground. Thanks again for the help. I appreciate it.
Rich
WBCCI #1512
Old 03-30-2011, 05:59 AM   #12
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Andy, since I am usually on the slow bus when it comes to visualizing what people write, I assume you mean that the fifth link from the cam/saddle should be hooked, correct? TIA.
kry226 is offline   Reply With Quote
Old 03-30-2011, 06:27 AM   #13
Correct.
How many chain links are under stress is important.
How many links hang loose, means nothing, since sometimes there are more links to the complete chain on one side than the other side.
Therefore counting the number of links under stress is very important as well as directing a person attention to any twist that might be accidentially put in the chain, which decreases it's length, which would place a different load on the torsion bars from one side to the other.
Andy 10.3
Old 03-30-2011, 06:37 AM   #14
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
One other comment: I'd re-route your breakaway switch cable ... it looks to me as if the breakaway chains are going to rub on / interfere with that cable. You don't want the cable to get tangled in the chains and then accidentally have the cable pulled. It also appears to be hooked right to the hitch receiver ... and if the hitch should fail completely and fall off, is there a chance that it would go sliding down the road with the trailer for a while, resulting in a non-activation of the trailer brakes? I don't know the answer, but I always attach mine (using a carabiner) to something other than the hitch receiver itself.
Perhaps others with more experience can comment on whether I'm just paranoid ... well, even if I am ...
AirsDream is offline   Reply With Quote
Tundra w/ Equalizer Hitch Booger12 Hitches, Couplers & Balls 11 03-01-2011 11:42 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
Rough casting hitch "friction" points dznf0g Hitches, Couplers & Balls 2 01-31-2011 04:55 PM
Ball height measurement from 200 miles away Section8 Hitches, Couplers & Balls 8 01-20-2011 08:12 PM
How and When to Measure Hitch Height lcurrie Hitches, Couplers & Balls 9 12-30-2010 01:59 PM
