Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 05-30-2007, 02:55 PM   #1
Dan S
Dan S's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Normandy Park , Washington
Adjustable hitch by Masterlock
I purchased an adjustable tow hitch that can raise or drop about six inches in either direction. It can be adjusted while hooked up to the tug by using a standated ratchet, no need to unhook , adjust, hook up...etc.
While it is adjustable via a spring I'm questioning how sturdy it is. It's rated to 5000lbs and a tongue weight of 500 lbs.
Anyone seen these?
Dan
Dan S is offline   Reply With Quote
Old 05-30-2007, 06:51 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Either direction?
Originally Posted by Dan S
... Anyone seen these?
One foot total? Sounds kinda hard to believe.
Got any pictures to post?
Tom
Old 05-30-2007, 07:23 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I found this at the web site;
It should work fine for a drop on and go type setup, but it has no weight distribution or anti sway capabilities.
Richard
Charter Member Four Corners Unit
Old 05-30-2007, 07:50 PM   #4
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
I had that hitch - it folded like a beer can in a rear end tap from a Mitsubishi PofS that hit me at a stop sign. Caved the hood and cracked the intake of the PofS and the guy took off for about 3 miles until the intake debris ate the engine up.
In short - I would not trust it to its max load - granted an accident was not in its design engineering load but it was folded in ways I thought were impossible. I do have 4 trailers all with different drops - I wanted an adjustable hitch for the yard hauls for moving the trailers around. It worked great for that.
Mike
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 05-31-2007, 09:41 PM   #5
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
New Replacement Hitch
This is what I have now - about 6 inch drop and flip it over you have 6 inchs up for a travel of about 12 inches TOTAL. Very well built.
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Hensley Arrow Hitch Les Hitches 10 02-28-2007 09:59 PM
Hitch problem wyhjr Hitches 8 07-22-2002 06:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 04:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 06:44 PM
Hitch height Chuck Hitches 9 06-09-2002 11:32 AM
