Old 04-07-2006, 09:13 PM   #1
1976 25' Tradewind
Tulsa , Oklahoma
About to tow my first Airstream - Which WD set up?
I just bought a 1976 25' Tradewind and plan to tow it with a 2002 Denali XL with a V-8. From all the sites I've visited, it sounds like a Reese W/D hitch system got the most votes. The trailer has a dry wt of 4110 lbs and hitch wt of 610 lbs. Is the 800 lb version of their system enough or should I go to the 1200 lb? Obviously I have a million more questions, but didn't want to flood this site all at once. Any thoughts out there?
H TWO is offline   Reply With Quote
Old 04-07-2006, 09:52 PM   #2
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
Welcome H TWO.
I have a 75 tradewind 25' (same weights as yours I think) and use the reese hitch with the 800 lb bars and dual cam type sway controller arms.
I've been using that hitch setup for almost 5000 miles now and I can tell you it works great for me.
FYI, I am towing with a 1/2 ton silverado
-T
Torii is offline   Reply With Quote
Old 04-07-2006, 10:00 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Though the GMC 1/2 ton has a softer suspension, I went with 800# bars at first and found it did a fairly good job. I bought some 600# bars on eBay for about $60. I think they may do a better job. Given that your hitch weight is less than 800#s, I'd also consider the 600# bars, particularly if you are using the dual cam sway control.
Old 04-07-2006, 11:03 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 is the same weight as yours. I have 750 lb. bars and they work great for me. Take some time and adjust them properly. They will be correct when the amount of drop is the same for the front and rear of your TV. Also make sure you get a quality brake controller. I have the Prodigy and it too works well for me.
Richard
Old 04-08-2006, 04:15 AM   #5
1976 25' Tradewind
Tulsa , Oklahoma
thanks guys. It sounds like I'm on the right page so far. I am getting the Prodigy brake control and the dual cam sway control.
Old 04-08-2006, 06:50 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums. My first trailer was a 25' 1975 Tradewind and we loved it. I pulled it with a 2001 F150 Ford, 4.6 liter Two wheel drive. We traveled everywhere with no problems. Go ahead and flood us with questions that is what we are here for.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 04-08-2006, 07:32 AM   #7
Darol Ingalls's Avatar
When you get your trailer ready to travel, find a scale and check the weight on the wheels of the trailer. I think you'll find that 4110 lbs is a daydream. My guess is that it will be closer to 5000 lbs.
Darol Ingalls is offline   Reply With Quote
Old 04-08-2006, 12:36 PM   #8
Davis's Avatar
1996 34' Excella
Americus , Georgia
Congrats on your purchase. I will agree with others that the 800 lb bars are strong enough and not get the 1200 lb. Also the reese dual cam setup is also a good choice .Your tow vehicle should do a good job for that trailer. I have used a Yukon XL with the 5.3 eng and it did well for me. Good luck. Davis
Davis is offline   Reply With Quote
Can I tow my airstream with my H2 vacaville1 Tow Vehicles 7 08-03-2008 11:20 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Need some advice on tow vehicle capacity newbullet Tow Vehicles 5 11-17-2007 06:35 AM
Airstream Tow Vehicle?? Ultradog Tow Vehicles 4 05-29-2006 03:18 PM
'78 Safari towed weight cdholt 1974 - 1979 Safari 3 08-25-2003 02:43 PM
