Old 06-24-2015, 10:30 AM   #1
Lexington , Kentucky
7-way Cord Extension for Hensley Hitch
I have just purchased a Hensley hitch and will be installing it on our new 30' Classic when it arrives in August. Terry from Hensley said I might need to extend the trailer's 7-way cord to allow for the extra space between the tow vehicle and trailer. For those of you with Hensley hitches, is this true, and if so, did you just add a 7-way extension cord? I found a 4 ft. extension that I could use, but I don't particularly like that idea and wondered if there are better ways to handle this issue. If that is the best fix, how did you position the female end of the 7-way extension to not hang in mid-air? I worry that the extra connection could cause problems (easily come loose, etc.) Any suggestions?
wlanford is offline   Reply With Quote
Old 06-24-2015, 10:43 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I use an extension with my ProPride. I'll try to show a pic of this soon but I've got a Velcro cord wrap attached to the female end of the extension so when I connect the trailer to it, I can wrap the Velcro strip around the entire assembly and it's rock solid. 3rd season with this and no problems. Good luck!
Old 06-24-2015, 10:49 AM   #3
2016 30' Classic
Erie , Colorado
ProPride extension. Works fine.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 06-24-2015, 10:54 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I did not need an extension with our 25' Classic. I just loosened the clamps that secure it to the frame, pulled about 6" thru and had plenty of slack......
This is how I route it...
Long before getting the Hensley, on the way home from picking-up the Classic as a matter of fact, the 7-way came loose and ground itself flat.....hence the zip-tie you see securing it now. Not Hensley related.
Old 06-24-2015, 11:48 AM   #5
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Not needed for my ProPride/30 Classic. But that extension has come in handy a couple of other times.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 06-24-2015, 12:31 PM   #6
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I did the same as Robert Cross - there was plenty of slack available.
When I repainted around the tongue and front frame I decided to add a 7 way junction box next to the spare tire. This is just in case the cord accidentally gets destroyed going down the road I can replace the cord in just a few minutes with common hand tools and a pocket knife. Adding the junction box gave me even more cord slack to work with.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 06-24-2015, 07:04 PM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I bought an extension kit from Pro Pride for my Hensley when I bought an adjustable stinger. This will do until I have a new one made up and installed.
Old 06-24-2015, 07:21 PM   #8
W , New England
Here's a pic of the unconnected extension and then the connected extension.
Name:	ImageUploadedByAirstream Forums1435195258.341137.jpg
Name:	ImageUploadedByAirstream Forums1435195275.381625.jpg
Old 06-24-2015, 08:14 PM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
No extension needed with ours, plenty of slack.
Doug and Cheryl
Old 06-24-2015, 08:19 PM   #10
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
Very unlikely you will need one. Keep in mind the trailer is the farthest away from the tow vehicle when it is straight, the trailer moves toward the TV in turns, so you need VERY little if any slack.
philipsinewe is offline   Reply With Quote
Old 06-25-2015, 11:30 AM   #11
2018 33' Classic
Newport , Pennsylvania
I am pulling my 2015 30 ft classic with a gmc denali 3500 and a Hensley and not 7 way extension is required
thanks
earl
EarlM is offline   Reply With Quote
Old 06-25-2015, 11:57 AM   #12
2011 30' Flying Cloud
Arvada , Colorado
I do not need the extension with our Hensley and 30' FC. My Silverado 2500 HD is new (to us) so I when I first hooked it up I did a full left and full right turn in the parking lot and all seemed fine in terms of cord length.
Jack46 is offline   Reply With Quote
Old 06-25-2015, 12:39 PM   #13
Racine , Wisconsin
I purchased my extension from Hensley when I purchased the hitch. It's two feet long and I need it.
Kilroy is offline   Reply With Quote
Old 06-28-2015, 01:26 PM   #14
Puyallup , Washington
I made a hard right turn in mine last weekend and ripped the outside jacket from the moulded plug end and lost my brake lights/turn signals and parking lights. The brakes still worked though (thicker wire). I now am replacing the entire cable with one that is a foot longer.
Steve340 is offline   Reply With Quote
30amp extension cord Pat Cassity Electrical - Systems, Generators, Batteries & Solar 7 08-13-2013 10:54 AM
Power Cord Extension? melbel Electrical - Systems, Generators, Batteries & Solar 8 10-06-2010 03:01 PM
Help with extension cord size bgarrison Electrical - Systems, Generators, Batteries & Solar 11 08-26-2007 08:54 PM
Extension cord to plug in trailer mandolindave Batteries, Univolts, Converters & Inverters 10 02-05-2005 05:36 PM
extension cord rated for 20 amps? Martha Electrical - Systems, Generators, Batteries & Solar 15 02-28-2003 03:00 PM
