Old 06-28-2015, 01:41 PM   #15
Originally Posted by Steve340 View Post
I made a hard right turn in mine last weekend and ripped the outside jacket from the moulded plug end and lost my brake lights/turn signals and parking lights. The brakes still worked though (thicker wire). I now am replacing the entire cable with one that is a foot longer.
The umbilical cord is supposed to be 7 feet long.
If shorter than that, you can replace the 7 way cable in about 20 minutes.
Old 06-28-2015, 02:26 PM   #16
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
You ripped the cable out on a turn with a Hensley???
philipsinewe is offline   Reply With Quote
Old 06-29-2015, 12:08 PM   #17
Puyallup , Washington
I have a 2010 airstream 25FB. Is the end of the cord terminated under the front bed? It looks like it goes into the floor of the trailer on the right side.
Steve340 is offline   Reply With Quote
Old 06-29-2015, 02:45 PM   #18
The wires in the front should terminate within the underbelly, just behind the A-frame.
Look for a square plate that's about 8" x 8" or so. Remove it and you should see the wires as they are connected to those within the trailer.
30amp extension cord Pat Cassity Electrical - Systems, Generators, Batteries & Solar 7 08-13-2013 10:54 AM
Power Cord Extension? melbel Electrical - Systems, Generators, Batteries & Solar 8 10-06-2010 03:01 PM
Help with extension cord size bgarrison Electrical - Systems, Generators, Batteries & Solar 11 08-26-2007 08:54 PM
Extension cord to plug in trailer mandolindave Batteries, Univolts, Converters & Inverters 10 02-05-2005 05:36 PM
extension cord rated for 20 amps? Martha Electrical - Systems, Generators, Batteries & Solar 15 02-28-2003 03:00 PM
