Old 05-10-2007, 01:00 PM   #1
The Aluminum Falcon
Al Falcon's Avatar
1973 31' Sovereign
Thousand Oaks , California
6pin on truck / 7pin on airstream
Greetings all,
I have a F-250 with the six pin hook up and a '73 Sovereign with a seven pin hook up. I called the dealer and was told the best solution was to have a seven pin hook up installed in my truck. ($150.00 to $200.00 installed) and that he knew of no adapters that "go that way" I wonder if anyone here has a less expensive solution to this dilemma. I can't be the first or only one to have this situation arise. Thanks and as always...
May the force be with you!
The Aluminum Falcon
(but you can call me Al)
Al Falcon is offline   Reply With Quote
Old 05-10-2007, 01:45 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
It depends on the truck, but you might be able to find one in a junk yard. Get the part number from Ford (if possible) and call around. My Fords are plug and play--no modifications needed to main wire harness if you need a different type of connector.
www.nesa.org
Air No. 6427
Old 05-10-2007, 02:30 PM   #3
Radman's Avatar
1972 27' Overlander
Monterey Bay , California
Images: 129
I wired my Ford to the 72 Overlander cause I had nearly the same issues. You'll need to trace all p/u wires and identify then, the same to the t/t. Some kind of pig-tail set up should work and not cost an arm and a leg. Make notes on what wire is what and take your time. Find a local r.v. vendor and run it by them. I trust they run across this sort of thing all the time. Remember this is not rocket science as my Dad used to say "any trained monkey can do it". And I did. Good luck.
Radman is offline   Reply With Quote
Old 05-10-2007, 03:19 PM   #4
7xp
1978 31' Excella 500
Santa Maria , California
Al Falcon
Here is a site showing the different pinouts for different connectors Trailer Wiring If I recall right, Airstream has used different pinouts for different years for the 7 pin connector as posted on this forum (tried to do a search, but couldn't find it). You can pick up a cheap circiut tester at any automotive store. If you buy a 7 pin connector, make sure it matches the one on the trailer, some are round pin and some are blade type. Just run the 7th wire of the proper gauge and your good to go. I hope someone will post the pinouts for the different year Airstreams. Good luck. "Mac"
7xp is offline   Reply With Quote
Old 05-10-2007, 07:15 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I believe there is a factory plug in the rear under the truck bed. There was in mine. You can get a 7 pin with the male plug from an auto parts store. If worse come to worse just cut the plugs off and wire direct. The wire colors are universal on the 7 pin. The Ford wiring is a little different. Still a quick 1 hour job. The guy who quoted you $150 has his wires crossed, and you should cross him off too!
Old 05-10-2007, 10:06 PM   #6
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
If I read everything correctly, you did not say what year your tow vehicle was.
I had a similar problem with my 2006 Ford F-250 Superduty diesel tow vehicle package and my 1968 Airstream Tradewind wiring harness.
The F-250 has a "by function" 7 pin diagram printed on the protective lid of the hitch plug-in cover.
Do not try to match Fords color wiring harness to an airstream colored wiring harness, they most likely will not match.
Instead, match the functions by pin placement, recognizing that there is a mirror difference between the tow vehicle and the trailer.
I.E. if you look at the tow vehicle recepticale, pin 3 will mate with pin 7 on the trailer plug.
KeithC is offline   Reply With Quote
Old 05-10-2007, 10:07 PM   #7
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
correction..pin 6
Old 05-10-2007, 10:54 PM   #8
funchucky1's Avatar
Riverhead , New York
Easier solution...
I had the same problem with my first tow vehicle. I just changed the plug on the trailer to the six-pin that plugged into my truck.
The plug was about 8 bucks at Walmart.
Sure, the six-pin plug doesn't have back-up lights.
-Chuck
funchucky1 is offline   Reply With Quote
Old 05-11-2007, 05:18 AM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
A '73 Sovereign probably has backup lights if it's anything like my Argosy. Consider that no Airstreams have them any more. Big loss? Probably not.
Nice link 7xp. Airstream FAQs have a variety of diagrams covering the years: Airstream :: Customer Services. Realize of course that the current plug "to 2002" runs right up to the present day -- shows how Jackson Center is concentrating on building Airstreams. Be cautious for mirror imaging and get the truck and trailer ends lined up right. Yep Radman, I've made a pretty good trained monkey too!
5 meter Langford Nahanni
Old 05-11-2007, 05:47 AM   #10
Got gandkids?
You can probably find the correct wiring diagram for your camper here (from the Airstream site): Airstream :: Customer Services
My camper didn't have an umbilical cord with it, so I bought one from NAPA that had one end "pig-tailed" so it could be wired in any order. Just another possibility.
www.nesa.org
Air No. 6427
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 07:35 AM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
