Old 12-15-2010, 12:35 PM   #1
1963 22' Safari
sherman oaks , California
62 safari hitch and sway bar hook up
almost ready for the maiden voyage but I cant figure out this sway bar attachment. Do these sway bars simply attach by the chains to the AS frame and then put a cotter pin in the holes to hold them there? Seems a little lightweight to me...and what's the spring loaded contraption. A little advice from experienced Streamers and I'll catch on
Any thoughts?
ID:	117035   Click image for larger version
Name:	trailer hitch attchmnt.JPG
ID:	117037   Click image for larger version
ID:	117039   Click image for larger version
mmenchel is offline   Reply With Quote
Old 12-15-2010, 01:37 PM   #2
VIKING's Avatar
Boulder Creek , California
I would go hitch shopping. The swinging brackets that take up the slack in the chains and transfers weight to the front wheels appear to be missing from the Airstream A-frame.
The chains DO NOT go onto the studs that have the cotter pin holes in them, unless this is a very primitive hitch.
Maybe someone out there has this same one and can comment on it further...
Rich the Viking
VIKING is offline   Reply With Quote
Old 12-15-2010, 02:30 PM   #3
dznf0g's Avatar
Oswego , Illinois
Rich the Viking
I agree, I've never heard of this brand, it appears to be missing parts, and unless it's an optical illusion, it appears that spring bar has been over stressed and has taken a set. If it has, it should not be used.
Old 12-15-2010, 03:59 PM   #4
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
In addition to missing parts you don't know if the height of the hitch would be correct. I would also recommend hitch shopping.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Sway bar help for dummies patis Hitches, Couplers & Balls 23 03-22-2010 09:53 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 05:02 PM
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
