Old 10-16-2011, 07:50 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
2" coupler to 2 5/8
My 1966 AS has a 2" ball on the weight distributing hitch end, and I wonder what I need to do to fit a 2 5/8? I know I can change the ball but what of the coupler side?
It tows fine, just thinking it would be better with the larger ball set up.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-16-2011, 07:58 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
A 2 5/16 coupler is needed for the new ball.
Bill
Just my personal opinion
Old 10-16-2011, 08:10 PM   #3
rideair's Avatar
ALANSD,
The 2" ball has worked well for over 45 years, I say keep it. I think you will also find it is made with better metal than anything you can replace it with today anyway.
I've pulled my 1966 Overlander from FL to MO to NH with never a problem using the original 2".
Paul Waddell
rideair is offline   Reply With Quote
Old 10-17-2011, 12:25 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Cool Paul thanks.. I am ok with that idea.
AIR #005
retired!
Old 10-17-2011, 12:35 PM   #5
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
This Is No Arbitrary Modification...
... as Paul has already suggested, you should just let it be, unless you see some cracking or other indications of metal fatigue.
But if you must remove and replace the coupler, it would be good to upgrade to 2 5/16"
Make sure you are dealing with a certified welder as it involves cutting the old coupler off and welding the new one on.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-17-2011, 12:59 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I changed a trailer coupler from 2 inch to 2 5/16 many years ago. There is nothing wrong with the 2 inch coupler. I did it so that the two trailers I had would be compatible.
Now I just keep 2 different heads around. I would not change it again unless I was replacing a defective coupler. Then I would go 2 5/16 for better compatibility with todays trailers.
I did build a utility trailer with 2 5/16 because a lot fewer people will try to borrow it
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Sewer Hose & Coupler wlanford Waste Systems, Tanks & Totes 85 05-24-2016 08:20 PM
Coupler issue. GT1963 Hitches, Couplers & Balls 3 06-02-2011 05:15 AM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
New coupler Althea68 Hitches, Couplers & Balls 5 02-01-2011 12:27 PM
