Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 01-27-2004, 09:54 AM   #1
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
1st Timer A/S: Tow-Hitch Question
We are going to pick up our Safari-25 this week and I have a question about weight-dist. &/or sway-cntl. set-ups. I have done a lot of towing but never an A/S before. I'm told (by a salesperson!) the A/S tows better than anything else, especially in crosswinds.
We tow with an '03 F-250 7.3l diesel. Do I need/want either a weight-dist. hitch or a sway cntl. set-up??.
RivetED is offline   Reply With Quote
Old 01-27-2004, 10:07 AM   #2
Big Dee
Big Dee's Avatar
Profile:  2004 30' Classic
San Jose , California
Images: 24
I currently tow my 25' Safari with a WD hitch with friction sway and I have NEVER had a problem. Plus it is still a heavy load so my truck appreiciated the WD hitch.
If you lived in Nor Cal, I'd say drop by and I would give you the one I am using now. I am upgrading to a Hensley hitch with my new 30' Classic. But Texas is a little toooo far....
"It's the journey."
NorCal Spring Rally, Casini Ranch, April 10-12 2009
NorCal Summer Cararally, Lassen to Lava Beds, August 5-9 2009
Click here for rally info.
NorCal Fall Rally, Jackson Rancheria, October 2-4 2009
Come rally with us.
Big Dee is offline   Reply With Quote
Old 01-27-2004, 10:08 AM   #3
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Look at the sticker on the aft-facing portion of your factory hitch receiver. It's too cold for me to go look at mine right now, but if IIRC, its maximum is 500 lbs tongue weight and 5,000 pound trailer weight without a weight distributing hitch. If that's the case, yes, you need weight-distributing for the 25' Safari.
Have you ever watched cops in a much lighter Crown Vic turn a much larger, heavier vehicle sideways by giving them a push on the rear bumper? Yes, you need sway control.
Lower, rounded Airstreams are a little less susceptible to crosswinds, but like any trailer, they can sway. Bigger, heavier trucks are less likely to be affected by sway, but they certainly can be.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 01-27-2004, 10:10 AM   #4
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Absolutely
A WD hitch is minimum.
A sway bar is highly recommended.
There are a few to choose from.
The most common and probably affordable is the Reese Dual cam.
A high ended WD hitch is an Hensley Arrow which many swear by and most AS dealers sell this with their new AS's
Another brand that I am a fan of is the Equal I Zer. Easy to use with minimal parts
Blue OX I believe makes one
You can learn much on this forum about Hitches, simply search WD Hitch
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 01-27-2004, 05:34 PM   #5
RivetED
RivetED's Avatar
Hillsboro , Texas
My search produced a vast amount of data, opinions, brands, & etc. I feel I'm on info-overload!. I've viewed the sites of the top 3 brand-names mentioned. It looks like the Equal-i-zer seems to fit the 'best for the buck', but ...??
Old 01-27-2004, 09:10 PM   #6
ajjohnsons
Profile:
Ed&Deb,
I have an 03' Safari 25', and I tow with a E250 Ford van. I recomend the Reese Dual Cam. IMO for this trailer,this setup offers the best performance for a modest price. If money is no object buy a Hensley. Best of Luck with your new Trailer. .......Al
ajjohnsons is offline   Reply With Quote
