Old 07-25-2008, 11:39 PM   #1
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
08 F250 HAHA and 08 27'FB CDD
Hi guys
Anyone have the same configuration?
08 F250 Crew cab short bed
HAHA
08 27'FB CDD
What size drop bar are you using? I'm using a 6"
What line is your tension bar set at? Currently between the top and middle line.
How many holes are showing at the bottom of the tension bar? Right now 3 holes.
Is your trailer and tow vehicle level with your settings? MIne is not!
Thanks!
Dennis
millvalleyca is offline   Reply With Quote
Old 07-26-2008, 12:18 AM   #2
_
millva...
is it a 4x4? that has an impact or receiver height and stinger length....
measure the distance from the ground up to the upper INSIDE of the receiver box...
that's the number used as the basis for stinger selection.
we discussed the issue of some of the newer tow vehicles being REALLY HIGH and needing longer stingers...
see the picture here that i took of a new f250 receiver height, and browse the thread...
http://www.airforums.com/forums/556451-post18.html
i think bambi_bandit had nearly the same set up as you.
he just upgrade to a new powerstroke, uses a haha and has a 27ccd...
http://www.airforums.com/forums/f463...cle-43167.html
so if he doesn't see this thread u might ping him...
cheers
2air'
Old 07-26-2008, 10:28 PM   #3
Hi 2air
Yes, it is a 4x4 and the upper inside when I measured it on "level ground" was 19".
I'm just trying to figure out if they sent me the right 6" bar....or are others using a 4" drop.
Dennis
Old 07-26-2008, 10:38 PM   #4
_
for some reason, i mistakenly though u had a 4
and wanted to trade for a 6.
my mistake.
IF you can get the trailer LEVEL then you've got the right bar.
so screw the jacks more and bring the spring bars UP...
if the trailer can be made LEVEL you will have confirmed it's the right bar.
is the hitch box really only 19 inches?
that seems low for a 2008 4x4, the ones i measured were much higher.
anyway pm bandit, it looks like he's got your combo...
cheers
2air'
Old 07-26-2008, 10:58 PM   #5
2air
I measured from ground to the top inside of the receiver and it's 19".
Do you know the height of the receiver for the HAHA?
One more bit of info ..... when I raise the trailer when hitched 2+ inches to level the trailer I've already loosened the tension bar.
Dennis
Old 07-26-2008, 11:13 PM   #6
_
height of haha box depends on jack adjustments, since even loose spring bars move it around!
it is the a/s ball/coupler height on the trailer when LEVEL that is used as a guide for stinger drop length selection.
this number is in the specs for your trailer, usually 18.75 inches on NON slide models, i think...
i understand u can level the trailer while HITCHED using the tongue jack....
and this will ALWAY reduce spring bar tension and raise the truck rear too...
that's not the sort of leveling i was referring to in the last post...
once connected AND the TONGUE jack is retracted UP,
use the HITCH screw jacks to get the trailer level...
go as far a necessary with the HITCH screw jacks to get level...
IF u can get the trailer LEVEL while connected USING THE HITCH SCREW JACKS/SPRING BARS,
then the 6 inch drop stinger bar is correct.
if at MAX hitch/screw jack tension, the trailer is still LOW at the nose, ya need a 4 inch bar.
capice?
cheers
2air'
Old 07-26-2008, 11:20 PM   #7
got it!
Next trip out I'll crank the puppy up and see what happens.
Dennis
Old 07-27-2008, 12:39 AM   #8
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Hi millvalleyca - Got your PM. I will get some photos.
I will say that the only difference in height between our trucks is that I have 20" wheels, and I don't even use a 6" shank. I think I use a 4" if I remember correctly.
What I do know is that when I am hooked up, I am dead on level in both the truck and trailer.
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 07-27-2008, 08:15 AM   #9
Images: 12
Damn... you gave me a good reason to bring Cosmo back home for a bath... I better hurry before it hits the 101 high today....
Anyways, below are my pics of the setup, both unhitched and hitched. I do have a 4" shank drop.
Note the fabricated clip I use to ensure that the jack does not unwind on me by itself....
Name:	P7273334 (Large).JPG
ID:	64529   Click image for larger version
Name:	P7273335 (Large).JPG
Name:	P7273336 (Large).JPG
ID:	64531   Click image for larger version
Name:	P7273337 (Large).JPG
Name:	P7273338 (Large).JPG
ID:	64533   Click image for larger version
Name:	P7273339 (Large).JPG
Name:	P7273340 (Large).JPG
ID:	64535   Click image for larger version
Name:	P7273341 (Large).JPG
Name:	P7273342 (Large).JPG
ID:	64537   Click image for larger version
Name:	P7273343 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-27-2008, 08:21 AM   #10
Images: 12
I'll try to show overall shots and shots with a small handheld level, both on the truck and the frame of the airstream....
Not an exact science with such a short level, but I'm pretty damn close to level on both the truck and trailer...
Nilesrob on this forum also has the same setup - 2008 F250 with 18" wheels 4x4 shortbed and 27FB Ocean Breeze. He carries a 45 gallon or so aux fuel tank in his bed, so it may seem slightly lower, but again, same setup with the 4" shank and hensley.
Hope this helps... who knows - someone may look at these pics and point out something I'm doing wrong that I didn't know about!
Name:	P7273344 (Large).JPG
ID:	64539   Click image for larger version
Name:	P7273345 (Large).JPG
Name:	P7273346 (Large).JPG
ID:	64541   Click image for larger version
Name:	P7273347 (Large).JPG
Name:	P7273348 (Large).JPG
ID:	64543   Click image for larger version
Name:	P7273349 (Large).JPG
Name:	P7273350 (Large).JPG
ID:	64545   Click image for larger version
Name:	P7273351 (Large).JPG
Name:	P7273352 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-27-2008, 09:56 AM   #11
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
You may want to drop your strut bar to the bottom hole on the frame bracket. An Airstream has what the haha company calls an A-style coupler and the bottom hole makes the strut the most level.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 07-27-2008, 10:49 AM   #12
Thanks Kevin for the great pics
I like your clip you made.
What size spring bars are you using....it doesn't look like mine and I'm using the 1,000 lb ( mine is flat at the end not bent like yours)
What is the height from ground to the top inside of the truck receiver box? I measure at 19"
Dennis
Old 07-27-2008, 11:18 AM   #13
Images: 12
Hi Sean,
Thanks for your advice. Once I get the rig out of my driveway and onto flat ground I'll give that shot.
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
Old 07-27-2008, 11:21 AM   #14
Images: 12
Red face
Dennis
Hi Dennis,
1000lb bars... See pic... I know that Hensley sources the bars from different vendors, so there is probably some variation on design, assuming it still meets the functional criteria.
The clips were designed by Roger Williams Airstream in Weatherford TX. They are great to prevent the jacks from backing up on you. You can call them to get them sent to you while your driving down the road. It's a cross between an aluminum bracket and a zip dee knob thingee... (I can't remember the zip dee part right now).
Name:	P7273353 (Large).JPG
Kevin & Prim Li
WBCCI # 6155
AIR # 6155
the ultimate haha users guide... 2airishuman Hitches, Couplers & Balls 824 09-16-2009 07:04 PM
2 TV's, one HAHA? boondockdad Hitches, Couplers & Balls 22 05-01-2008 12:58 PM
haha and reduced tire wear ??? Mike Lewis Tires 6 11-21-2007 09:16 PM
F250 5.4 Brad Hunt Tow Vehicles 10 10-03-2007 08:21 AM
not another new guy....haha zenith Member Introductions 8 02-17-2007 08:55 AM
