Old 07-28-2008, 11:05 AM   #15
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
Woops I already have a 4"
Silly me.....I called the HAHA company today and was told I have a 4" drop (measured from the top to the top of the bottom bar).
I guess the only alternative is to crank it up the next time out and see if the trailer levels itself.
The guy I talked to said not to worry about the truck and just the trailer.
"Just look for the ride you like" (after adjusting the spring bars) and if it's still unleveled then maybe change the 4" for a 2" drop bar. (no one ever suggested a 2" on the forum)
Being a newbie...to me the drive was just fine (1,000 miles each way to the Grand Canyon and back) but when I stopped for fuel/eats I noticed the forward slant.
Thanks!
Dennis
millvalleyca is offline   Reply With Quote
Old 07-28-2008, 11:41 AM   #16
_
Originally Posted by millvalleyca View Post
Silly me.....I called the HAHA company today and was told I have a 4" drop...
Originally Posted by 2air'
...for some reason, i mistakenly though u had a 4
if the trailer can be made LEVEL you will have confirmed it's the right bar...
i towed ya so...
based on the pic u put in the haha thread, it looked like 4.
get the trailer level has been the mantra all along...
but DON'T "not worry' about the truck.
AXEL weights matter too...
cheers
2air'
Old 07-29-2008, 09:56 AM   #17
Hensley Ron's Avatar
Oxford , Michigan
I towed ya so? I like it. You must have talked to G-rod (Jarrod the exhalted haha tech). I think we talked about the jack holes on the other forum. You won't notice a difference between 2 and 3 holes showing, but always best to go with the manual. I've towed three different trailers with four different vehicles with my haha. I've expereminted with 2 holes, 3 holes, and everything in between (just kidding, please don't drill a 2 1/2 hole). It really makes little difference in the ride or the leveling of truck or trailer. In some cases, though, using the wrong hole may make it difficult to allign the head.
Ron Estrada
Hensley Mfg., Inc.
www.NoSway.com
Hensley Ron is offline   Reply With Quote
Old 07-30-2008, 01:49 PM   #18
FB Storage
Hi guys
Do you think storing too much in the FB outer storage has anything to do with me being unleveled?
The storage unit is under the bed and accessed right behind the tongue jack.
I'm gonna weigh what I have in there (chairs/table/hammock) I'm guessing 100 or so pounds of stuff.
Does it make any difference if I transfer some of the heavier items to the truck bed?
Just wondering
Dennis
Old 07-30-2008, 02:00 PM   #19
_
millva...
it really depends on the actual TONGUE weight,
along with the proper jack tension and stinger drop.
IF the tongue mass is >1000lbs there could be issues using 1000 lb spring bars.
as my unit's tongue mass went over 1200 lbs, the lesser spring bars were no longer adequate 4 weight distribution...
but your tongue mass should be under 1k lbs.
so IF/when u weigh the trailer and tv axles, don't forget to get a tongue weight too...
moving gear from the trailer to the truck bed does put that load directly over the tv axles...
but lightening the trailer tongue (below 10%) can affect handling negatively.
it's all related and adjusting one thing impacts everything else...
this is one of the reasons to have a BIG tow beast with extra capacity,
and why trying to limit loads to 80% of a given rating is a good thing.
cheers
2air'
Old 07-30-2008, 07:50 PM   #20
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Hi guys
Dennis, I think you'd have a hard time recognizing the difference with moving only 100lbs from under the bed to the bed of the truck.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 08-04-2008, 06:07 PM   #21
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Strut location changed
Originally Posted by Sean Woodruff View Post
You may want to drop your strut bar to the bottom hole on the frame bracket. An Airstream has what the haha company calls an A-style coupler and the bottom hole makes the strut the most level.
Hi Sean,
Per your advice, while waiting at the dealer for them to troubleshoot my Dometic fridge, I did go ahead and drop the strut bar to the bottom hole.
I was careful to count the exact # of rotations on the strut bar "nut" when I loosened them to ensure I put it back the same way.
When my Hensley was installed, it turned out that the mounts were slightly different lengths (22" road/driver side and 22 3/8" passenger/road side) causing some issue that I can't remember anymore.
So they compensated for this by having one strut bar longer than the other and they told me that if I ever needed to remove the strut bar to count the exact # of turns on the nut and put it back the same...
I have not tried hooking up and pulling with it since the change this afternoon, but the Colorado trip will be on Wednesday.
I figure if it starts feeling funny I'll go back to the 2nd hole...
Not sure what ride difference or other difference to expect on the bottom hole.
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 08-04-2008, 07:12 PM   #22
ProPride, Inc.
Hi Kevin,
You won't notice any difference in the holes. The bottom hole just makes the strut more level and puts the load more down the shaft of the strut.
That is exactly the way to install the strut bars when your frame brackets are positioned differently from the center of the ball. The strut has plenty of adjustment to handle that and squares the main head up to the front of the trailer. This allows the links to run parallel and in the direction of travel.
Sounds like you are dialed in.
ProPride Hitch
Grand Blanc, MI
Tu ne cede malis
Old 08-27-2008, 11:07 AM   #23
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I had a issue close to yours, The problem is You probably dont need weight distribution hitch. The local camper place told me buy the lightest bars and just make them taunt. Plus Ford trucks come with a rake on them, so when they are level that means they have a load. I think it is a 1 inch differnce between back and front
mustang is offline   Reply With Quote
the ultimate haha users guide... 2airishuman Hitches, Couplers & Balls 824 09-16-2009 07:04 PM
2 TV's, one HAHA? boondockdad Hitches, Couplers & Balls 22 05-01-2008 12:58 PM
haha and reduced tire wear ??? Mike Lewis Tires 6 11-21-2007 09:16 PM
F250 5.4 Brad Hunt Tow Vehicles 10 10-03-2007 08:21 AM
not another new guy....haha zenith Member Introductions 8 02-17-2007 08:55 AM
