Old 11-20-2009, 01:55 PM   #1
Profile:  muskegon , Michigan
Yukon Denali AWD
I have not seen this vehicle discussed in much detail, after searching.
I am trying to decide Denali or Burb 2500.
I know the 2500 is the choice for most here.
Even though this is a 1/2 ton it is quite a different vehicle than
an 1/2 ton Burb. - 403HP and AWD
More torque than the 2500.
I just really like the ride (unloaded), AWD, and looks.
Planning on towing a 28 CCD.
It seems it has plenty of power 403HP vs 366 for the 2500.
Am I correct in thinking this would be in between the 1/2 and 3/4 ton given the HP and Torque ratings?
1414lake is offline   Reply With Quote
Old 11-20-2009, 02:22 PM   #2
2airishuman's Avatar
Profile:
hi lake, welcome
3 D threads...
Can My Sierra Denali Handle a 30' Classic SO
Towing with a Escalade ESV or a Yukon XL Denali
31' Excella 500 with GMC Denali TV ??
and 60 more with references to the D...
http://www.airforums.com/forums/sear...archid=1609023
so sort out the numbers and read some, from the users AND switchers.
the concern with the 1/2 ton (or any suv/big trayla combo) is...
PAYLOAD (gvwr-curbweight+options)=the LOAD that can be placed ON/in the den/burb.
hp/torque are fine (even less would be ok IF u don't mind climbing slowly) but TOWING options/bits are important.
Originally Posted by 1414lake View Post
Couple questions:
-Will the air ride system work well with an equalizing hitch?
-Will the AWD be a good thing or bad for towing?
-yes (but there are threads that contradict this, based on ancient notions and gear)
-yes (and it's full time AWD not 4x4, a good distinction )
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 11-20-2009, 02:34 PM   #3
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As far as the half ton Denali goes, there are several issues to consider. You didn't say if your Denali is the Yukon size or the Yukon XL size. The longer wheel base is an advantage when towing a heavy trailer. Does the Denali have a transmission fluid cooler? This is a big plus when towing heavy. Also check the Denali's tires to make sure that they are LT's with load range D or E. If they are load range C's, you should probably replace them before pulling a trailer that heavy.
We have a 2005 Safari 25FB, named Lucy. Lucy weighs 7400# ready to travel. We have pulled her over 50,000 miles and have spent over 500 nights in her in the past 3 1/2 years. We pull Lucy with a Suburban 2500 that does have Auto Ride (self leveling) and have not had any problems using a Hensley hitch system. There are some members here that feel that the Auto Ride is not conducive to trailering, but it seems to work well for us. I don't believe that the AWD should cause any problems when towing.
We have pulled Lucy with our 2004 Chevrolet Tahoe 1/2 ton. It did OK, but the 3/4 Suburban does quite a bit better.
It sounds like you already have the Denali and should give it a try and see if you are satisfied with the towing experience.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 11-20-2009, 06:46 PM   #4
Profile:  1971 25' Caravanner
scappoose , Oregon
Welcome to the Airstream forum. Just about any question you may have can be answered by many members, who have long experence with anything connected with Airstreams.
rangebowdrie is offline   Reply With Quote
Pulling a 2007 25ft Safari with a Yukon Denali? scottr 2007 Safari 3 05-23-2009 01:15 AM
31' Excella 500 with GMC Denali TV ?? DesertRat Tow Vehicles 14 05-17-2007 10:59 PM
Towing with a Escalade ESV or a Yukon XL Denali Rosie39j Tow Vehicles 24 03-08-2006 09:40 PM
'67 Overlander and '03 Yukon... JMGAZ Tow Vehicles 26 07-13-2005 07:10 PM
Can My Sierra Denali Handle a 30' Classic SO Big Dee Tow Vehicles 74 02-26-2004 02:15 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
