Old 06-08-2010, 05:38 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Exclamation YIKES! 97 F250 SHAKES! motorheads help me plz!
My 97 F250 PSD has taken to shaking like crap off and on. I suspect that it may be an issue of how the motor is (or isnt) mounted to the frame. Does this make sense and what should I look at to find the problem?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-08-2010, 06:12 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
More information
The reason I am inclined to think it may be the mounting rather than the running gear (for lack of better terms) is that the shakes seem to be linked to RPM rather than movement per se. It is more common up hill and under load. Down hill even towing the vibration-shaking goes away. If you slow way down and let the shaking stop, you can sometimes speed back up (if you avoid RPMs over 2500) without it shaking.
What other details are needed to diagnosis this?
Rodney
and the
My Blog
Old 06-08-2010, 06:33 PM   #3
1989 32' Excella
Limestone , Alabama
Some additional information that might help...
Is the truck 4 wheel drive?
Any recent changes such as: front end alignment, new shocks, new tires, or tire rotation?
How many miles on the truck?
Steve
war eagle is offline   Reply With Quote
Old 06-08-2010, 06:35 PM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Steve
2 wheel drive, no recent changes, about 200K miles. Standard transmission
Rodney
and the
My Blog
Old 06-08-2010, 06:41 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Sometimes a Ujoint will act like that,jack up one rear wheel,and see if you have play in the drive shaft,if is 4x4 jack up one of the front and try the same thing. Dave
easyride is offline   Reply With Quote
Old 06-08-2010, 07:00 PM   #6
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I'm not sure why that would be, the vibration remains constant (relative to RPM) and is not a clunk when engaged. What am I missing?
Rodney
and the
My Blog
Old 06-08-2010, 07:15 PM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Check your engine mounts, it sounds like one my be cracked or broken.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 06-08-2010, 07:16 PM   #8
tpi
Trabuco Canyon , California
If you hold the brake firmly and let out the clutch slowly (1st gear) does the engine lift excessively on the left side? That would be typical of bad engine mount-as that mount takes most of the torque. The other mount or the rear mount at transmission could also be broken.
tpi is offline   Reply With Quote
Old 06-08-2010, 07:17 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
How does one do that?
Rodney
and the
My Blog
Old 06-08-2010, 08:11 PM   #10
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Check for a possible clogged fuel injector - a rough running diesel can feel like the truck is shaking apart. I had a shot #8 cylinder injector - fuel economy went way down - sluggish starts - idled OK but at highway speeds I had a loss of performance. All three O-rings were burned through (?) and the injector was burnt. I change my fuel filters at 15-20K mile intervals. The fuel pump went out too. I had 150K miles on the truck. This is a 7.3PSD - I would not change the vehicle for a new one, "FLO" is a great truck.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-08-2010, 08:27 PM   #11
Central , Mississippi
I'm not convinced a ujoint IS the problem, but they are easy to eliminate...
Slack is one problem and can be found by wigglin, but look real close for rust on each cup seal...I had one cup full of needle bearings go dry, jam up and vibrate. The rusty dust coming from the cup seal was the giveaway.
One thing for sure...an ignored vibration has never fixed it's self for me...its always a clue that something is just gonna get worse...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-08-2010, 08:29 PM   #12
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by clancy_boy View Post
Check for a possible clogged fuel injector .
OK, not to be an obvious dunce, but how does one check for a clogged fuel injector?
Rodney
and the
My Blog
Old 06-08-2010, 08:57 PM   #13
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
When's the last time you had yer running gear balanced?
Seriously, my work truck (provided by the company, I do NOT own this truck) is a '98 E250 van, a bona fide piece of junk because of poor maintenance. Vibrates very badly around 45 to 50 MPH. The problems IS the tires. The tires are cheap "foreign made" tires that the company won't replace because they have too much tread left on them. Corporate idiots.
I personally own a '97 & '98 F150 that will vibrate very badly if the front brake disks warp (happened a couple of times thru the years). Any reason to believe that the rotors are warped?
I would think you could have the motor mounts inspected at a shop for little or nothing.
Interesting thread. I'll be following along.
www.nesa.org
Air No. 6427
Old 06-08-2010, 08:58 PM   #14
r carl's Avatar
Lin , Ne
Be in first gear with clutch in, emergency brake on, and with the heal of your right foot push the brake pedal down hard and with your toe press the throttle a little and with your left foot let up on the clutch until it puts a load on the engine, the drivers side of the engine will try to lift up. If the mount is broke it will lift up more than an inch. Some mounts nowdays are interlocking and wont let the engine come up far enough for the fan to hit the shroud.
PLEASE help me with towing needs -PLZ tempest2 Hitches, Couplers & Balls 5 06-05-2009 11:22 PM
Southern Cal is on FIRE!!! Plz help if you Can.... Tim Can Our Community 5 11-04-2007 05:09 PM
for all the motorheads out there Wayward Tow Vehicles 9 10-13-2007 10:00 PM
new member - 76 Caravanner info plz Longhorn57 Member Introductions 8 03-07-2006 08:41 PM
