Old 11-03-2007, 07:45 AM   #15
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm with most of what has been suggested here.
Do you need weight distribution, most likely not, but at 24', the better choice for sway control, (which you do need) is not friction based, so if you go that route, you'll wind up with weight distribution anyway. If not, then you'll be going friction sway and for that length, I think that wouldn't be such a hot idea. If you take the suggestion to go with a cam type sway control, then go with the smallest bars you can (around 600lbs). Hensley, though excellent, is really way overkill for something like this. Can't hurt, but it's thousands of dollars vs, maybe $300-$500 on the high end for something robust enough for your needs. I use the Reese DualCamHP system towing a 25' Safari GVWR of 6300lbs, which I don't think you are near in terms of weight. If money is no object, and it makes you feel better, you won't go wrong with a Hensley.
I agree the truck could pull even larger and heavier, to me that is not the issue.
Brake controller is a must and is most likely required by law in most states.
Outside of these that have already been discussed, go get it and have some fun with it, but be safe.
Old 11-03-2007, 08:50 AM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Laws exist requiring breakaway brakes on any trailer by weight. I've seen the state lists and 1500-2000# is usually the point at which functioning breakaway brakes are required. This does require a battery in the trailer for them to activate.
There is no way to get around towing with functional trailer brakes (harness in TV for brake controller, a brake controller, and a 7-pin umbilical plug at the rear of the TV).
5 meter Langford Nahanni
Old 11-03-2007, 10:22 AM   #17
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Adjustment!
Originally Posted by mrmossyone
I did have a brake controller installed before I left MI.
I did notice a lot more brake dust on my front wheels than I have noticed before and wondered if this is normal when towing a heavy load( it was a fairly long trip 1500 miles there and back). Thanks for all the advice and well wishes.
Sounds to me like the Argosy is not braking its own weight. If you still have the prodigy guide it runs though the setup process. It took a few trips before I was able to dial in my trailers.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-03-2007, 12:04 PM   #18
Road Ruler's Avatar
Images: 38
Originally Posted by Marshall
You should have no problem until you have a problem, then you have a problem.
Agree Re WDH! When the time comes to need it is the time you wish you had it, and by then it is too late. Consider being proactive.
Tow Vehicle-2011 GMC Yukon Denali-FC 23/25FB BMay Tow Vehicles 10 04-09-2011 10:24 AM
Need help to tow 31' land yacht in town (portland, or) pdx437 Our Community 4 03-06-2011 02:13 PM
1500 or 2500 HD? alp6783 Tow Vehicles 39 02-18-2011 10:25 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
New Tow Vehicle - 2010 Dodge 2500 sgray Tow Vehicles 13 01-11-2011 07:41 AM
