Old 05-19-2007, 12:07 PM   #1
2001 30' Excella
Houston , Texas
Why is GVWR less than GAWRs?
I'm looking at an 08 F250 with a GVWR of 10000 with a weight of 8179 (scale) leaving pax and cargo load of only 1821 (door sticker). Front GAWR is 6000# and rear GAWR is 6100#. Why is the GVWR so much less than the combined GAWR?
acbillard is offline   Reply With Quote
Old 05-19-2007, 12:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Because the parts are rated at more than the frame. Ford uses many of the same parts on both the F250 and F350, thus the capacity differential.
Also, technically, an F250 only needs a capacity of 1500 pounds to be considered a 3/4 ton truck, so anything over that is a bonus.
Old 05-19-2007, 01:10 PM   #3
2001 30' Excella
Houston , Texas
As far as I can find out, everything is the same on the 350 except for a slightly different rear axle and the springs. Would prefer not to go with a 350 mainly because I can't find the one I want on the ground. Thanks
Old 05-19-2007, 01:48 PM   #4
_
hi ac'
are you sure about that curb weight?
most of the 250s are under 7k with a payload of 3k....
is this truck modified, got a utility bed, camper shell or some other thing?
8100 lbs is about where the 450s and dualie 350s measure...
still the axle, wheel, tire capacity also must allow for towing parameters beyond the truck payload.
cheers
2air'
Old 05-19-2007, 01:59 PM   #5
_
here is the curb weights and max payload for each flavor of 250 list just below....
Base Curb Weight
F250 SRW 5675 6135 5925 6385 6050 6515 6100 6560 6225 6685
max payload
F250 SRW 3130 2860 3070 2810 3150 2880 3100 2830 3170 2910
cheers
2air'
Old 05-19-2007, 03:55 PM   #6
2001 30' Excella
Houston , Texas
I'm sure of the curb weight (weighed on a CAT scale).
I'm referring to an 08 F250 loaded King Ranch 4x4 on the dealer's lot. The payload is on a sticker on the door frame. After subtracting the sticker payload from the GVWR you get pretty much what I got by weighing the vehicle on the CAT scales.
Old 05-19-2007, 07:24 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
OUCH! Those things have really pigged up! My 96 Crew Cab dually runs the scales around 7200# or so...I have a factory GVW of 10,000# but the truck is actually capable of more I suspect that 12-13k# would be closer to reality.
Aaron
WBCCI #XXXX AIR #2495
GVWR Mysteries ljmiii Axles 7 05-21-2007 03:28 PM
GVWR Early Production 2005 30' Classic Ltd w/SO TomR Airstream Trailer Forums 8 10-18-2006 08:08 PM
16' Bambi - CSA and GVWR ljmiii 2005 and newer - Bambi all models 1 10-09-2006 02:53 PM
Difference between Dry Weight and GVWR wacnstac Towing, Tow Vehicles & Hitches 6 04-05-2006 07:29 PM
Help GVWR Bubbla Our Community 1 05-19-2003 07:56 AM
