Old 06-18-2017, 04:26 PM   #1
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
which wire is the backup wire- rearexterior backup, stop turn light
i am installing the gramin backup camera ion my sport 22
i have the camera mounted wit 3m tape instead of drilling more holes.
the cable comes though above the bathroom sink shelf.
since the camera is wireless to the GPS, they suggest powering the wireless transmitter from the rear back up lights
when i pulled out the light there is a sealed unit with three wires white , back and red, i assume that
white is ground(-), red is positive(+) and black is the second positive(+).
which two can i use to power the wireless transmitter such that it gets engaged when i put the TV in reverse
waninae39 is offline   Reply With Quote
Old 06-18-2017, 07:21 PM   #2
2017 23' Flying Cloud
Bartlett , Tennessee
I didn't know the trailer had back up lights. My factory installed rear view camera is powered by the marker lights/tail lights. (I do have to turn on the tow vehicles marker lights to activate the camera.)
I bet your 3 wires are ground, marker lights/tail lights, and turn signal/brake lights.
Stick a pin or needle through each wire, turn on the marker lights, see which wire has power.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 06-18-2017, 08:02 PM   #3
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
ok tnx
i thought that all vehicles had BU lights, since the lamp assembly is all red i and i could not see any clear ones i wondered if it even had BU lights
I googled the part number
1T-L13R
i can find the product , but none have and wiring info
Old 06-18-2017, 08:33 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Easy answer:
Plug in the TV, flip the light switch(s), see what happens.
Old 06-18-2017, 09:31 PM   #5
What he needs to know is which wire powers the tail lights/marker lights. Merely seeing the lights come on won't tell him that.
Old 06-18-2017, 09:52 PM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Call the Airstream factory customer service desk and ask for the wiring schematic for your specific tailer (have the last six digits of the VIN ready).
Old 06-18-2017, 11:20 PM   #7
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
hi switz
i have the schematics. they dont help me with this problem
they only tell you the internal wires. They do not tell you much about the vendor items ie the external light or the vendor colors
the rear lights are sealed units and have three wires coming out, they are about 18" long and go into the inner shell. I cant reach my hand far enough or see through the insulation to see the wire junction connection.
i will have to test the power on trick and see which cable is power when the TV light go on..
Old 06-19-2017, 07:19 AM   #8
Half a Rivet Short
Hi
His multimeter or circuit tester will very much tell him *exactly* that.
Old 06-19-2017, 08:12 AM   #9
1977 31' Sovereign
2005 30' Safari
North Port , Florida
I don't think you'll find the bu wire in the trailer. Don't think Airstream runs them anymore. Generally the black wire on the light is running lights. I would probe the wire with a test light to verify. If you don't have a sharp test light probe the wire with a needle.
cliffcharb is offline   Reply With Quote
Old 06-19-2017, 08:48 AM   #10
Hi
With a sealed unit, how will he touch metal to test it? He can't get to the bulb base. He can't get to the wire connections. Unless he does like I suggested in the very first response?
Old 06-19-2017, 02:20 PM   #11
1959 24' Tradewind
Twin Falls , Idaho
AC/DC Voltage tester
You should be able to use one of these I think.
http://www.sears.com/craftsman-volta...p-03482174000P
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 06-19-2017, 02:44 PM   #12
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
those units only detect AC power. the tail lights are DC
Old 06-19-2017, 03:47 PM   #13
Boxite's Avatar
2008 22' Sport
Waninae39... my little 22' Sport electrical schematic shows that the BU wiring is BLACK. Now to clarify... my Sport did not have BU lights...they had only running lights and tail/turn lights. And the FIXTURE for the lights came from an outside vendor to Airstream and that vendor had 6-inch long white, black, and red wire pigtails on their fixtures.... So my point is you cannot utilize the color-codes found on the fixtures to determine what Airstream used to supply power to them. (Normally, yellow, green, brown and white are what are used to supply pwr to running and tail/turn lights..... so you need to find the AIRSTREAM HARNESS wire which is used to feed BU lights.)
To further add to your dilemma... Airstream likely did not connect the "tail lamp harness" all the way forward to the umbilical-connection. Not only that.... but the universal color used by umbilical mfr's is YELLOW for BU power.
Therefore, in MY trailer, in order for me to add BU lights... I had to open up the cabinetry in the bath to access the BLACK wire AS has in the "taillight harness" ....and connect it to my own wire (I chose black for "consistency... and I had to run my own wire beneath the toilet, thru the wardrobe-basement, behind the galley area, beneath the forward bed, and connect it to the M-3 connector at the front of the trailer just inside the wall/beneath the bed....and be certain to connect it to the terminal which also connected to the YELLOW-UMBILICAL wire!
Now, ....look at your schematic again and find out which color was used...and is likely dangling around unconnected to anything at all in the rear-wall of your trailer.... AS intended for BU light circuits.
Good luck.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 06-19-2017, 10:20 PM   #14
2004 22' Safari
Albuquerque , New Mexico
The larger picture only shows AC but the words say the pair detects both. Anyone trying to work electrical should really invest in a meter. You can even get them free at times at Harbor Freight with a purchase.
Silver.Sanctuary is offline   Reply With Quote
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 06:05 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 03:01 PM
'65 Globetrotter led brake/stop/turn tail light kennyp315 Lights - Interior & Exterior 3 12-06-2008 08:10 AM
4-Inch 10-LED stop turn tail light ($11) COUPON** Wabbiteer Electrical - Systems, Generators, Batteries & Solar 1 07-20-2006 10:27 AM
Stop,Turn,Tail LED PROBLEM Wardinbb Lights - Interior & Exterior 5 09-17-2004 01:52 PM
