Old 02-09-2009, 11:39 AM   #43
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Originally Posted by tmarquis View Post
Took the vin number called a ford dealer had them look up the factory specs....looks like it has a "Heavy Duty Tow Package" installed. It does have the 3.73 ratio. So i'm hoping that my tow rating is up to 9200 pounds.
Do I have the forums blessing!
Yes! Good choice...(I am GM to the bone, but my 2nd choice would be a Ford.)
AirStream=American Icon
Ford F150=American Icon
You dun'well.
Welome...you've made a safe and comfortable choice for pulling that size AS.
Now get out and start Streamin'
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 02-09-2009, 11:41 AM   #44
1987 32' Excella
Poplar Bluff , Missouri
tmarquis!!! get the vin number, have the dealer run it through the computer, they can or should be able to pull up the original assembly line specs and tell you if the tow package was factory installed or not. I did that on my 2008 Ram, and it was amazing how that clarified things last week. There is a difference in capacities between factory installed tow package, and those installed by the dealer or others.
Good luck!
Steven
StevenG is offline   Reply With Quote
Old 02-09-2009, 11:43 AM   #45
1987 32' Excella
Bless you my child! Trailer in good health! ;-)
Old 02-09-2009, 11:44 AM   #46
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
When you get an ok from BillTex you know you're doing well. He loves 3/4 ton trucks, but is smart enough to know your trailer doesn't need one. I wanted you to buy a Tundra (bias alert), but the Ford will work for you. Good work in checking all this out.
Now you can go camping. Oh, got a brake controller? A WD hitch? A whole bunch of other stuff you will be spending on in the next year (buying an RV makes you a one man stimulus package).
Gene
Old 02-09-2009, 12:38 PM   #47
2009 23' International
Boulder , Colorado
Yeah I think I'm going with the F150. I have 5 days to change my mind. I am a toyota fan as well. But I just haven't found one with a tow package. And the dealers are just one more level of BS i have to deal with. Carmax has made things easy.
And yeah maybe a refund is on they way with this stimuli package. I've heard its possible for autos.....maybe RV's as well?
tmarquis is offline   Reply With Quote
Old 02-09-2009, 12:50 PM   #48
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
My 2 cents, 2006 F150 a good choice , but I have a heavy Ford bias. Adios, John
Diesel1 is offline   Reply With Quote
Old 02-09-2009, 01:08 PM   #49
1 Rivet Short
1989 25' Excella
Isn't that an oxymoron?
Old 02-09-2009, 01:51 PM   #50
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
2006 F150 4X2 Crewcab with a 5.4l is rated for 9500 pounds if equipped with automatic and 3.73 axle ratio.
>>>>>>>>>Action
Old 02-10-2009, 09:14 AM   #51
wncol2004's Avatar
1953 25' Cruiser
Hopkinsville , Kentucky
Gotta watch out for those used vehicles at the dealers.
The salesman will look at the rear and if they see a hitch. They will assume it has a towing package and boast that even if the only part it has is just the hitch.
Towing packages include much more than just a receiver/hitch.
In the most extreme cases it includes, heavy duty alternator, heavy duty suspension, larger radiator, power steering fluid cooler, Engine oil cooler, Aux trans cooler, Heavy duty battery, 7 wire trailer connector, trailer brake controller wiring harness, heavy duty turn signals,...
In the least it will be a receiver, aux trans cooler,... But those are usually minivans.
For a pickup or larger SUV it includes the longer list of things.
Warren
1995 Ford Conversion F350 crew cab dually 7.3 liter diesel.
1953 Airstream Cruiser Travel trailer (The Runaway Sue)
Western KY
wncol2004 is offline   Reply With Quote
Old 02-11-2009, 08:01 AM   #52
Boulder , Colorado
thanks Warren I'll have my mechanic look over it. See if i can get some specifics
Old 03-09-2009, 12:20 PM   #53
5T5
2004 28' Classic
2006 22' International CCD
Saskatoon , Saskatchewan
Hi Tom,
I own a 22' Internationl CCD with a GVWR of 5600# and towed it with a 2007 Tacoma with a 4L V6 last summer through Wyoming and Montana and was not at all happy.
The Tacoma had a 5 speed automatic transmission which I generally had to run in fourth gear and could not use my cruise control even on flat roads as it would constantly want to downshift.(always hunting for a gear)
I believe that the suspension in the Tacoma was up to the task but that the engine and transmission were not able to handle this load.
I also concur with moosetags opinion.
Good Luck...Kim
5T5 is offline   Reply With Quote
Old 06-15-2009, 05:57 AM   #54
airperson
2006 25' Classic
Ft Worth , Texas
I am in somewhat the same boat.
Hi,
We have just bought an 06 classic. We would like to replace the truck but do not know which way to go. We would like to travel in the mountains. We would also like to get somewhat good fuel economy.
I know there are many tow vehicles out there used for towing, however I donít have a clue which way to go.
I do not want to rely on a truck salesperson that does not tow himself to guide my decision. I hope some of you folks that have the experience will share your wisdom.
airperson
Airperson is offline   Reply With Quote
Old 06-15-2009, 07:14 AM   #55
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Hi,
I know there are many tow vehicles out there used for towing, however I don’t have a clue which way to go.
airperson
In order to even begin helping, we need to know how long and how heavy your '06 Classic is.
Tow vehicle rogerdodger Tow Vehicles 32 05-24-2008 09:24 PM
New Tow Vehicle! CaddyGrn Off Topic Forum 13 02-11-2007 11:42 PM
new tow vehicle frederic.c01 Tow Vehicles 2 06-18-2006 12:56 AM
Tow Vehicle, should I? or Shouldn't I? Daisy2 Tow Vehicles 5 03-12-2006 02:31 PM
new tow vehicle whistler On The Road... 10 04-14-2004 07:07 PM
