does this tank have baffles in it to kep the fuel from sloshing from side to side? quite a bit of weight transfer with a half tank going around curves without them.
I don't know. I'll need to ask my "people" (my husband).
Anyway, at this point we have not noticed any issues with the TVs handling due to the extra weight we are lugging around (and I don't mean the weight we have gained over the years, I mean the TVs weight).
__________________ Michelle & Leon
WBCCI # 7032 Region 1, New England Unit
Looking for a WBCCI Unit filled with fun loving folks to camp and travel with in the New England area? Well, you've just found it:
Second reason is in event of Gulf Coast hurricane evacuation. I'm estimating 3-5 mpg in stop/go traffic, and that 60 gals means I can make at least 150-250 miles before needing fuel.
Right - Being prepared for a local or national emergency is the other reason we invested in an extended fuel tank too.
MYBOYBURT, I love the tank. Wish I had one like it for those Alaska long range to the arctic circle trips.
One thing you mentioned and I am probably redundent in my comments here, is that you only use the rig for your AS puller. REMEMBER, fuel deterioates rather quickly. The suggested storage time for diesel fuel is ONLY 90 days maximum and it starts to deteriorate at 30 days according to refinery information I read. But the big thing is diesel draws water like a sponge. I am only mentioning this because I got the idea you rig might set for exstended periods of time. Just my two cents worth, I am sure you'r knew these things but some folks don't.
I have a friend who is a fruit rancher. He has a duramax and before that had a power stroke. He got rid of the power stroke cause it never would run right according to Him. Well,,, His duramax never does run right either. He buys his farm diesel and stores it in a 2,000 gallon tank. Gets it cheap and keep it too long....the only thing that will burn it is His 30 year old diesel John Deere...but you can't tell him that. He thinks the motors just won't run right...lol... refuses to admit its because of year old diesel.
Thanks for the advice. Good news is our TV is out and about nearly every weekend from mid March until Thanksgiving weekend due to our being wicked active in the New England Unit of the WBCCI. We've already filled this beast twice since we purchased the extended tank system.
But, that's what it's all about (isn't it?). We LOVE to camp and travel with our Airstream and the extended tank just allows us a bit more freedom.
I had a 50 gal. in-bed-tank added a couple of years ago when the price of fuel was getting into the mid $2.00 range, oh for the good ole' days! You are really going to like the range and the fact that you aren't maneuvering around small gas stations all the time. You can somewhat 'shop' for prices. As far as weight goes the 600 or so pounds that 75 gals. adds (approx. 8lbs./gal.) will be noticeable, I can feel the difference on my 3/4 ton Ford with the extra 50 gals., but the gross weight figures when fully fueled and loaded are still below manufacturers max. You might want to check that on a CAT scale.
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
On Monday I ordered the 30 gal. across the bed tank from Transfer Flow (TF) along with the Camper Shell Fill. Just got off the phone with the trucking company and it will be delivered to my home on Friday. I figure that will give me a total of 64 gallons when all topped off. Ah, another project for me to fool with.
All of you that write in these threads are causing me to do things that I normally wouldn't do. And, I thank you!
Michelle & Leon,
My father used this type of tank for years with their 5th wheel because they traveled from Michigan to Texas and back every year. Dad did this to keep them away from some of the stations that watered their fuel or had dirty fuel, it also allowed the pick and choose on price. Dad had the manual switch because he would run the truck off that tank and kept the stock tank as a researve.
As far as when to fill that would depend mostly on where you was going, if you are traveling from a high price area to a low, only carry enough to get into that area then tank up, such as from the north to the south, currently diesel here is running around 3.95-4.05 gallon.
As far as the weight issue you shouldn't have to worry about anything except in a emergency stop, Diesel weighs in at 7 pounds per gallon, if you have baffles in the tank you should not have to worry about sloshing effect causing problems with a 1/2 tank.
That's a really cool setup. Nice piece of mind when your in the middle of no where! Since this thread first started, diesel has gone from about $4.19 to $4.70 here in Tampa. Ridiculous. The crooks are the ones wearing ties.
Michelle & Leon,
My father used this type of tank for years with their 5th wheel because they traveled from Michigan to Texas and back every year. Dad did this to keep them away from some of the stations that watered their fuel or had dirty fuel, it also allowed the pick and choose on price. Dad had the manual switch because he would run the truck off that tank and kept the stock tank as a reserve.
Great info about your Dad's setup, thanks!
We do have baffles in the extended tank (my husband confirmed this for me). He just filled the beast today at $4.66 per gallon. We needed 84.4 gallons which cost us $393.00.
We are now cutting back on non Airstream / travel purchases (like going out to dinner or buying electronics) so that we have the $$$ to purchase the fuel we need to continue our Airstream lifestyle. I read and hear on the news that this is the way it's going to be (meaning wicked high fuel costs). Man, not a good thing if true.
You know that is a pretty good idea on the cutting back, our A/S is at AS/JC being worked on and we will be getting it back in May 09, and are really looking forward to spending most of our time in it, working our way into full time. When I gave the fuel prices I had not checked them in 3 or 4 days, was out yesterday to go for training and diesel prices was 4.45 to 4.60 per gallon.
The truck I have now is not as good as I need so I will be purchase new sometime between Oct 08 and May 09, will have the added tanks as well and the tank I will get from the local farm supply unless I decide to have one custom made, most likely diesel, Have to have something that can pull the A/S and I can load my HD Ultra in the back.
Good luck on your travels, maybe we will see ya in the future.
Mark
Just a little extra feed back. I installed my 30 gal Transferflow cross the bed tank over a weekend. The system works flawlessly.
I also installed the Traks II system that keeps track of the fuel in the aux. tank and the OE tank and automaticly starts the pump and transfers the fuel when it is needed to keep both tanks at about the same level. The whole system including the 30 gals. of fuel weighs in at 329#'s.
The instructions are pretty clear and come with drawings that help a lot. As long as you take your time and don't rush the project I think most people who do minor mechanical stuff can do this install. You will need a helper get the tank in place and to hold the bolt heads on the inside of the bed while you are under the bed tighting the nuts. Since I needed to move the tank often before final bolt down, I slid it around on a piece of old carpet so not to scratch the bed. The Traks II part is a mini computer in the display unit. In order to mount it in the center of my dash in front of a cubby hole required me to snap out some of the dash and console panels to run the wires and make it easier to drill the hole in the back of the cubby hole for the wires to pass thru. Also you have to drill a few holes in the bed floor to anchor the tank and in the side of the bed for hoses and electrical wires, and I needed one for wiring under the carpet on the driverside floor. When all done I cut my Bed RuG to fit around the tank and had some similar material from another truck Bed Rug and used those pieces to cover the outside of the tank. Best thing is that this tank only takes up 11 inches of the length of the 8 ft. bed. The tank itself measures only 9 inches wide.
See ya at the pumps, but not quite as often.
I don't know about elsewhere, but in Canada Diesel is about 15 cents/litre cheaper at truck stops. The thing is the truck stop nozzles are like three times the diameter of the regular gas station nozzles. So if you have a filler that can take the bigger nozzle you can save a lot.
The filler thru the camper shell to the tank is the same size as the oem on the truck. I suppose if that was a problem a larger one could be used in it's place. I don't have any plans to change it at present as most truck stops here have pumps up front for diesel pick ups and cars and the prices are the same, the nozzles are smaller too.
Thanks for the heads up, I enjoy traveling and camping in "The Great White North", and will probably head up that way again if these fuel prices ease a little.
P.S. TransferFlow sells 2 different fill ports. I'm not sure but I think they both use the same fill cap so are probably the same size dia. for the fill nozzle. The only difference I can see is the size of the outer flange. But I might be wrong. Look at their site to make sure, or call them, if you are thinking about getting a tank.
Reason: Added more info
Probably isn't noticeable, Rodney. Most of us with diesel-engined trucks (well, at least with a Cummins under the hood) find that it is wind resistance, not the weight of the trailer or the bed load that is truly noticeable on most roads, with most loads, under most conditions.
A lot of start and stop, a lot of steep hills at slow speeds, all these would change the equation.
On my truck, with a 2,300-lb rated payload, an additional 800-lbs in the the bed [600# fuel/150# tank] is almost un-noticeable solo.
The truck would settle on the springs a touch, and I'd have to re-adjust the rearview mirrors somewhat. The "boulevard ride" would be improved a little. What would be noticeable would be braking into a corner too late, the body lean would be more pronounced; thus I'd be approaching more turns and corners even slower than my current slow style of driving.
The changed center of gravity is the real concern.
With a 1,000-lb tongue load from the trailer, a 300# bed topper, (a proposed additional 800# of tank/fuel) and a few hundred pounds of stuff, I would be near or at payload maximum. And I'd be more concerned about the axle maximum not being exceeded than the bed load. A Dodge, at least, is not undersprung/softly-sprung like the competition.
Once underway, on level roadway, the fuel mileage -- solo -- would be the same. I wouldn't expect it to change by much the towing mileage on most roads.
With the truck at maximum, and the desire to stay out of turbo boost pressure and keep low exhaust gas temps, I'd just be slower to accelerate, and sooner on the downshifts to slow.
Wind resistance is the measureable, noticeable change in fuel mileage.
