Old 06-19-2007, 03:52 PM   #57
ROBERT CROSS
"The Frantic Banana"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 41
Downshifting
ROBERT:
I'm with you Robert, downshift when necessary, and try to keep the tranny temp below 190. No tow/haul 0n the 95 Suburban.......Bob...
KEEP STREAM'N
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 06-19-2007, 05:03 PM   #58
AgZep
Profile:  2005 28' International CCD
Las Cruces , New Mexico
We've done about 2,000 miles in the last two weeks. Our trailer is a 28' CCD, loaded pretty light at the moment. Our TV is a 2001 Chevy 2500HD with the 8.1 gas engine and Allison transmission.
We've been getting around 11 mpg, generally at 55 mph. We did a couple of stints at 60 mph, and a few where we slowed a bit due to construction. No noticable mileage difference in either case. I suspect the increased aero drag from going faster might be offset by the engine breathing a bit more efficiently at the wider throttle opening.
At 55 mph in T/H, the Allison will not switch down to overdrive. Once we go a little over 60, it will. So I just take it out of T/H when I'm cruising in a flat area, which will cause a shift into overdrive, then immediately turn T/H back on. That gives me the brake assist if I ever need it, without forcing the engine up 600 rpm needlessly while cruising.
I think a lot of this discussion proves that different transmissions are programmed differently, and that gas engines benefit somewhat less from brake assist than diesels.
Our truck also seems pretty insensitive to weight and speed when it comes to mileage. The best I've ever done while not towing was 17, but I typically get 13 or so.
I might have rather had a diesel in the first place, but we got our truck used from my brother in law who lives in Wyoming. At his altitude, and with the wildly variable weather out there, diesels are sometimes a problem. When we get our next truck, it will probably be a diesel (GM stopped making gas/Allison trucks anyway).
AgZep is offline   Reply With Quote
Old 06-20-2007, 08:16 AM   #59
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Hi Ag,
This is odd; typically normally aspirated (most gasoline powered truck engines on the market today) engines do poorly at higher elevation. Turbocharged (most diesel engines on the US market today) are not prone to performance loss at elevation.
Anyway, every time I am out towing with the Allison, I am just amazed at its performance. I have owned many trucks over the years (this is my first diesel) and regardless of what engine they have had, there is nothing like this Allison (that I have driven). I can’t imagine a better tool for towing. The rock solid shift patterns, engine braking, and reliability make me feel like I am driving a locomotive-towing is a pleasure with this combo; solid, stable, plenty of juice for hills, passing, etc. It is a good feeling to know when you hitch up and head out that you have such a platform to haul your family, and stuff!
You do have a point about different trannies and rear end ratios, and their effect on performance. When I am towing (62-63mph) I can pop it in/out of TH and the tach does not change at all (mpg constant also). This is a D/A with the standard 3.73:1 rear end and 6 spd Ally.
Bill
Life is Good-Camping all around New England
Good people drink good beer-Hunter S Thompson
BillTex is offline   Reply With Quote
Old 07-25-2007, 11:51 AM   #60
Streamer1
Profile:  2007 25' International CCD
Arlington , Virginia
We drive an F250 PSD and use the "Tow-Haul" mode whenever we tow (and don't forget to press the button). Probably would not be a bad idea for the pickup manufacturers to have an "idiot" light (what's one more light?) that recognizes that a trailer is attached and would ask you if you would like to utilize "Tow-Haul" mode at this time.
Streamer1 is offline   Reply With Quote
Old 07-25-2007, 12:05 PM   #61
Anon
Profile:
Originally Posted by Ken J
On my Avalanche the only thing tow/haul does it extend the shift times - I does not keep it out of overdrive. I also tow in 3rd rather than drive - my transmission place showed me the clutches in the transmission and after seeing how small the overdrive clutch is, I never tow in overdrive. Chevy says you can tow in o/d, but their warranty is only 36000 miles - if you keep the truck for the long haul, you will wear out the transmission
Ken J.
Same with my Safari. It just moves the shift points to allow for pulling a heavier load. In turn, this saves on the tranny.
Anon is offline   Reply With Quote
Old 07-25-2007, 12:23 PM   #62
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Greetings Tom-
This subject has been discussed many times here on the forum. Use the search function and you will see a ton of advice. But while I am here, We always have the Tow Mode engaged and Overdirve off when towing. It is in your truck for a reason and hence you should use it.
Rick
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is online now   Reply With Quote
Old 07-25-2007, 12:36 PM   #63
Sky
Sky's Avatar
Profile:  Sum Wear , Ohio
Oh poppycock. The search function on this site is worthless, but someone here told me about using google's search engine to search the airforums.com site. The google search syntax is:
xxxx site:airforums.com
where xxx is what you are searching for.
There you will find tons of advice.
"Some people walk in the rain, others just get wet" - Roger Miller
Remembering games and daisy chains and laughs" - Roger Waters
Hubba - 2006 2500HD DMax............Bubba - 2007 30' Classic w/ Hensley
Sky is offline   Reply With Quote
Old 07-25-2007, 12:39 PM   #64
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I agree because I often forget until we are under way and I don't think it is a good idea to press it while moving. It may not hurt it, but I think it best to be stopped, if not in park, when you engage the tow/haul mode.
I may have mentioned this already, but I wish the tow/haul reminder light were blue or green or some other color besides yellow. It makes me think something has gone wrong when I see it out of the corner of my eye. To me yellow and red are warning colors not reminder colors.
Family of Disney Fanatics
WBCCI# 4821
Old 07-25-2007, 01:37 PM   #65
bobkelly
bobkelly's Avatar
Profile:  2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Reading the glove box manual helped me understand when to use TH.
The GMC Denali has an autoride system that varies the shock absorber valving to suit road conditions. The TH mode recalibrates this system for firmer damping. Therefore, I use TH w/o the trailer when traveling tight mountain roads. Gives it damping more like the great Z-71 suspension system which is only available on the 5.3 Tahoe/Yukon and not the 6.0 Denali Yukon.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 07-25-2007, 02:21 PM   #66
Kevbo10
Profile:  2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Surprised...
Originally Posted by Silvertwinkie
I have a 3/4 ton Burb too and use tow/haul when on the road towing all the time. I have yet to see and RPM increase due to tow haul on flat land at 55mph or faster. I do note that it shifts later and can hold the RPMs while in the lower gears, say 2nd, but after 40mph, it shifts to the next gear, then the final OD gear. What tow/haul does is keep the trans from overshifting when you come to smaller hills, etc. FWIW, I have 4.10s in the back.
mr winkie,
i'm surprised you find time to drag an airstream. i thought posting while driving was not encouraged or worse...
kevin
Kevbo10 is offline   Reply With Quote
Old 07-25-2007, 02:45 PM   #67
byamcaravanner
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
I agree... Sky's method produces MUCH better results!
Thanks!
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
How to get Tow/Haul on an F-150 SilverCabin Tow Vehicles 10 03-08-2007 08:43 AM
Heat pump switched on in AC mode Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-22-2005 09:09 PM
Problem with Hybrid display mode... malconium Forum How-To's & Support 1 07-21-2004 06:58 PM
Banks PowerPack for 7.4L Chevy LTD93 1969 Overlander 6 09-24-2002 06:53 PM
