Old 02-03-2013, 05:47 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
When at the scales
Right down the road from us is a grain elevator operation...they have great scales, actually there are two of these Scales...One, you must drive up a slight incline. And the other scale is flush with the ground. When we ever get around to weighing both the AS and the TV hooked together- along with the W dis. hooked up and going...what is the order of what is weighed first as you would pull across the scale? and so on.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-03-2013, 08:13 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Billy, I use my local CO-OP scales too. I disconnect and weigh the Airstream then the the truck. I do the truck just for the heck of it. I really see no reason to weigh the two hooked together....I wonder if there is a need. Now, I do use a small scale to get a tongue weight.....something I want to know. When are you moving to Kansas?
Old 02-03-2013, 08:32 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Billy,
To properly set-up the WD bars you will need a three platform scale.
TV steering axle
TV drive axle
Trlr axle
Cat scale
The definitive thread on the subject.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-03-2013, 08:48 AM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Get weight of trailer separate
Get the weight of the truck front axle
Then both
When hooked up with WD hitch repeat with
truck front axle
then both truck axles then the weight of the entire rig
subtract the weights and you have each axle weight hooked and unhooked.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-03-2013, 08:50 AM   #5
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
That makes sense. More involved than I would have figured.
Old 02-03-2013, 11:22 AM   #6
Connellsville , Pennsylvania
How To Weigh | CAT Scale
Midnightmoon is offline   Reply With Quote
Old 02-03-2013, 11:52 AM   #7
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Originally Posted by Midnightmoon View Post
Thanks - link is a good reference
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-05-2013, 06:29 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The scale readings I want is a baseline for future adjustments when necessary, thus:
1] TV alone (empty; only driver, full fuel and permanent stuff); and
1a] individual tire readings
2] TV alone, (loaded; all pax, plus gear for travel plus above); and
2a] individual tire readings
3] TT alone, (empty; full fresh water & propane plus permanent stuff); and
3a] individual tire readings
4] TT alone, (loaded; all gear & supplies for travel plus above); and
4a] individual tire readings
5] TV & TT hitched, but WD not applied; and,
5a] individual tire readings
6] TV & TT hitched, with WD applied
7] TV & TT hitched, WD applied, all tires on starboard; individual readings
8] TV & TT hitched, WD applied, all tires on port; individual readings.
Being exhaustive about WD actuation and tire pressure/load concerns.
One adds pax to 4 & 4a to learn what loads the parked TT undergoes: the load seen in the TV in 2 & 2a relate to tire load when TT parked. Etc. The "margin of reserve" (12-15% on TT tires), and being sure that no position on the TV is overloaded, plus that across-the-axle pressure is predicated on the tire with the highest load.
Since re-weighs are about one dollar at a CAT Scale, one can combine a good number of passes across the scale as convenient
Old 02-06-2013, 04:28 AM   #9
CapriRacer
CapriRacer's Avatar
I'm in the , US
RMA: Tire Service Professionals
You want Chpter 4 - RV Applications.
CapriRacer is offline   Reply With Quote
Old 02-06-2013, 04:56 AM   #10
1970 27' Overlander
There is a CAT scale about fifty-sixty miles south of me.
Old 02-06-2013, 05:01 AM   #11
1970 27' Overlander
The plot thickens...
What happened recently, is Big Hill Lake contacted me for a position. We shot up there yesterday to take a look. And to meet the personnel. We got the position but I still am processing paperwork and tests.
Old 02-06-2013, 06:54 AM   #12
1970 27' Overlander
The Cat scales cost ten dollars first time and then two dollars eveyrtime after that. So I figure we would pass through once and then pull to the side and make adjustments there- and then go through again till it's improved and fixed. So what you are saying is everything hooked up should weigh equal across the entire length of both truck and trailer.
Old 02-06-2013, 07:02 AM   #13
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by AIR-Quarius View Post
.... So what you are saying is everything hooked up should weigh equal across the entire length of both truck and trailer.
Ideally you should transfer the weight removed from the front axle when you drop the tongue onto the rear BACK TO the front axle with the WD setup...
Putting too much weight onto the front axle puts a tremendous strain on the hitch and the truck and trailer frame.
Make at least three adjustments to the tension bars in order to observe the effect.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-06-2013, 07:16 AM   #14
Thumbs up
Billy,
Great news with the Job!! Is it Art related?
Pictures worth a lot of werds.....
1st ticket...TV loaded for camping
2nd ticket...TV and AS loaded for camping, no weight distribution.
3rd ticket...TV and AS with WD set. Notice all but 100lbs of TV alone front axle weight has been distributed back to the steering axle.
Door Jam sticker with axle weight ratings.
ID:	178386   Click image for larger version
Name:	CAT Weights.jpeg
PFC
"Tahawus"
RLC
John Prine
