Old 08-02-2018, 09:34 PM   #1
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
When a 3500 is not enough
My neighbor says his 06 3500HD Duramax overheats towing the grades so being a trucker he rigged his vintage Kenworth to tow his wife horse trailer, it has no air conditioning so now they overheat. LOL
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 08-02-2018, 10:23 PM   #2
2007 22' International CCD
Oooh. Wheres the like button. Talk about massive overkill!!!
Old 08-02-2018, 11:39 PM   #3
steverino's Avatar
2018 30' Classic
Ivins , Utah
Hmm it looks like the front fenders are a little high... perhaps some weight distribution is in order. What do you suggest - Equalizer or ProPride?
(ducks and runs for the door)
steverino is offline   Reply With Quote
Old 08-03-2018, 12:16 AM   #4
Long Island , New York
Seriously though, that truck's suspension was never designed for such a point load falling so far behind the rear axles! Looks like it is, what?, about 4' to 6' behind the mid-point between the two rear axles? What is the hitch weight of that 5th wheel setup, when loaded with horses?
Not overkill at all . . . but surely bad aiming!
Old 08-03-2018, 02:06 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, so replacing a 12 year old radiator, thermostat, or maybe a fan clutch isn't worth fixing the problem, so use the Kenworth. What happens when the Kenworth starts to have problems? Boeing 747???????
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-03-2018, 02:31 AM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I saw several 5th wheels pulled by semi rigs when I was in Texas. All of them had the tag axle removed and the frame shortened. I was told that the semi could be tagged as a private tow vehicle rather than a commercial tractor once the second axle was removed.
Seriously, horses are heavy and so are their trailers (2 to 3 inch thick plywood floor). 3500 is probably overloaded with a big horse trailer. But a Kenworth? Are the horses Clydesdales?
Old 08-03-2018, 05:17 AM   #7
Originally Posted by AlinCal View Post
. . . so being a trucker he rigged his vintage Kenworth to tow his wife horse trailer . . .
Er, how many horse wives does he have?
Old 08-03-2018, 08:41 AM   #8
AlinCal's Avatar
1991 25' Excella
Not actually hitched yet, just in vicinity.
06 has less than 10K mi. on it and is modified with larger exhaust and upgraded intake and turbo to try to fix the problem with no satisfaction.
Trust me if it could be fixed it would be.
They are Mules to be more accurate, but usually only one goes at a time.
Are you just working on your post count here?
Will Rogers
Alan
Old 08-03-2018, 08:44 AM   #9
AlinCal's Avatar
1991 25' Excella
If you look at the lowered rail you can see the kingpin is over the axles and as seen not yet hitched.
Will Rogers
Alan
Old 08-03-2018, 08:55 AM   #10
Thanks, sorry, I did not notice that!
Old 08-03-2018, 09:26 AM   #11
Mount Dora , Florida
I had an ‘05 Duramax, and of course I frequented the applicable forums for it.
Some D’Max trucks in that era had overheating problems, some did not. Mine did not. There were super duper aftermarket radiators available to help fix those that did.
I’m a little skeptical about the oversized intake, turbo, and exhaust fixing the overheating. Certainly you will be moving more air through the engine, but also making more power, and therefore heat, that the cooling system still won’t be able to handle.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 08-03-2018, 01:22 PM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by JMynes View Post
I had an 05 Duramax, and of course I frequented the applicable forums for it.
Some DMax trucks in that era had overheating problems, some did not. Mine did not. There were super duper aftermarket radiators available to help fix those that did.
Im a little skeptical about the oversized intake, turbo, and exhaust fixing the overheating. Certainly you will be moving more air through the engine, but also making more power, and therefore heat, that the cooling system still wont be able to handle.
........you are right on....maybe it also is chipped....I would like to drive it once...just back off on the grades...like driving a 280 cumalong...or 262...
Old 08-03-2018, 03:50 PM   #13
Argyle , Texas
We have owned a 2002 GMC, DuraMax, 1 ton, dually, bought new. We have pulled heavy equipment; a three horse trailer w/ living quarters, - loaded with 3 horses, etc. over all terrains without a heating issue. I would have done something like this in jest, but I would have that 2006 DuraMax iback in the dealership from where it was bought. This should not be happening.
Betty Farmer is offline   Reply With Quote
Old 08-03-2018, 04:30 PM   #14
AlinCal's Avatar
1991 25' Excella
Thanks for all the great replies, did not think this would have taken this tack and I'll let him know what you all think he should do.
I think he likes towing with the Kenworth though and it's just an excuse to do so.
If a hammer is good for the job a sledge hammer should work better.
Will Rogers
Alan
Insurance - When is enough enough Pop Rivet Insurance & Claims 6 06-27-2007 08:29 PM
Fridge not getting cold enough Dbartmann Refrigerators 7 06-13-2006 05:36 PM
not enough hot water from kitchen sink faucet codybear Fresh Water Systems 3 01-24-2006 11:20 PM
To many kids, not enough beds Big Family General Interior Topics 0 08-29-2003 01:52 PM
Not stable enough Kajendo On The Road... 11 07-22-2003 01:31 PM
