Old 07-29-2003, 08:07 AM   #1
bob.rita's Avatar
Question wheel chair setup in GVWR
OK, I have been reading this forum and I am still confused. We have a 31' Sovreign with a tow weight of 6500lbs/ 5400dry, at least according to the manual. I use a wheel chair and still drive so I want my chair with me when we travel. Setup for chair, lift etc approx. 400lbs and will be in rear of van.
We are looking at a used 7.8l diesel van as a tow vehicle. Do I subtract the weight of our AS from the GVWR of the van as stated on rear bumper of van then subtract the chair setup from it to find a safe tow limit for all???
OR>>>
Do I add chair setup plus AS at 6500lbs plus van weight to see if it exceeds GVWR as stated on bumper panel???
bob.rita is offline   Reply With Quote
Old 07-29-2003, 09:27 AM   #2
Rick's73's Avatar
van size
what size of van? Ford/GM 150/250/350? Technically GVWR includes bodies on board also.
I have a 27' overlander (4400 dry, 6800GVWR), my w/c lift etc. is on the side door of my van. I have a Ford E-150 with a 5.4L gas job.
If I truly am at 6800 trailer weight loaded (which i highly doubt), I would be over. But my van pulls it no problem. An equalizer/weight distribution hitch would give you less hitch weight.
Rick
Rick's73 is offline   Reply With Quote
Old 07-29-2003, 10:26 AM   #3
LOST , Hawaii
Either way you will get the same number. Adding the total weight of the van, lift, and trailer should give you a weight below the GVW, this difference is the weight you have for passengers and gear.
If you subtract the weight of the van, trailer and lift from the GVW it should give you the same weight for passengers and gear.
John
74Argosy24MH is offline   Reply With Quote
Old 08-02-2003, 10:19 AM   #4
bob.rita's Avatar
Re: van size
I have a 27' overlander (4400 dry, 6800GVWR), my w/c lift etc. is on the side door of my van. I have a Ford E-150 with a 5.4L .
Rick
Ok, found van with lift already installed but GVWR is only 9600lbs. This is a large van Ford F350, engine 7.3l diesel. I think this will do the trick...do they even make bigger engines???
If I subtract 6500lbs from 9600lbs as shown on spec plate I am only left with 3100lbs and this just seems too little for weight of van with chair and lift. Am I doing something wrong????
Thanks for your reply nice to know other wheelies are AS folks too.
RITA <G>
Old 08-02-2003, 11:18 AM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Confusion
I think you are confusing GVWR and GCWR.
GCWR is the total of the van and trailer. i.e. Gross COMBINED Weight Rating.
GVWR is just the max weight of the van with all contents including hitch weight.
You have to stay within both limits, but I'll bet that GCWR will be a lot higher than 9600# on a diesel F350. Probably more like 12,500#.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
**Broken Wheel Well** Silvertwinky Wheel Wells 8 05-26-2006 02:57 PM
Wheel well body repairs zazus62 Wheel Wells 2 12-08-2003 02:54 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Wheel lockup erstrong Brakes & Brake Controllers 2 10-07-2003 12:52 AM
need to replace the wheel...are there jacking points? 60traveler Jacks, Stabilizers, Lifting and Leveling 1 06-25-2003 03:05 PM
