Old 10-16-2016, 04:34 AM   #183
2012 19' International
Southeastern MI , Michigan
Originally Posted by Tireman9 View Post
70 mph ! Trust you are not running ST type tires that have max speed rating of 65 mph.
Nope, my tires are rated for the speed and load. All brand new Michelins on the TT and TV. (In Canada I obeyed the local speed limits, about 65 mph on the highway).
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 10-16-2016, 08:17 AM   #184
Louie De's Avatar
2000 34' Excella
Goodyear , and Denver, Colorado
In May I traveled from Goodyear, AZ (17 miles west of Phoenix) to Denver, CO, 900 miles by all Interstate. Then in late September returned going through the CO mountains over several Mt. Passes like Wolf Creek (about 11,000') with a short side trip to Farminington, NM FMCA Rally. About the same number of miles. I pulled with a 2015 HD 3/4T GMC Duramax with a loaded bed & 34' 2000 A/S Excella weighing approx. 11,000 lbs. Speed ranged between 60 & 65 MPH with target MPH at 62. Although, the dash MPH for both trip legs said I averaged 46MPH. Tires were 15" Maxxis at 60 lbs. (should have been at 65lbs). High cross winds on first leg of trip & normal weather on return. Using a Pro Pride Hitch 1400 lb bars. which is worth every penny . 2 passengers & all of what Mama could carry back & forth!! Temperatures ranged from 26* to 95 *. MPG, surprisingly on both legs of the trip, was 13.2. This truck is a Beast. There seems like nothing it can't haul. Hope this helps .TerryG above I believe was right on with his Duramax MPG.
Louie De is offline   Reply With Quote
Old 10-25-2016, 01:49 PM   #185
2016 27' Flying Cloud
Quebec , Quebec
Images: 8
Originally Posted by NWGetaways View Post
I know there are way too many variables to make this a scientific study - big trailer, little trailer, flat ground, Rocky Mountains, but...
What kind of mileage do you get while towing?
I'll start. My Honda Ridgeline, towing a 19' Bambi or 22FB Sport, typically gets about 14 MPG while towing. Sometimes it dips down to 12, and I did hit 15 once on a short flatland excursion.
I tow an AS 27FB which weight in travelling configuration 7200 pounds. The TV is a 2500 HD Denali with Duramax engine. Driving at 60-65 mph with the empty truck I do 20 mpg. The truck only loaded (1000 pounds) with a fiberglass box (fibrobec-spacecap-wild) and 2 kayaks I do 15 mpg and adding the AS I do 12.7 mpg. I am very happy with this set-up. It is better than any 1500 with gas engine. Once I did a run at 70-75 and fuel consumption reach 10 mpg. With a full tank of diesel, 35 gallons, driving at 60-65 I do 400 miles or 7 hours. That is enough for a nice day. I try to refuel when unhook. I saw to many accident at gas station.
Toutsi 1957 is offline   Reply With Quote
Old 10-25-2016, 02:00 PM   #186
Quebec , Quebec
Images: 8
Originally Posted by Crabpot View Post
25-ft EB last fall with Titan - 8700 miles VA to Co to UT to WY to BC and back to VA lot of high mountain passes - 10.5mpg.....just traded in for a 2016 Chevy 2500 Diesel....Hopefully will jump up to 15 to 18mpg on upcoming trip.
I have a Denali Duramax. Towing a loaded 27FB, I do 12-13 mpg at 60-65.
Old 10-25-2016, 02:08 PM   #187
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Yesterday we towed our Airstream 258 miles in quiet, warm weather, mostly interstate and equal amounts of long up and down grade at 63-65 mph. I thought we might be close to 20 mpg for the day, settled for 19.2.
Doug and Cheryl
Old 11-02-2016, 04:01 PM   #188
2016 30' Classic
Houston , Texas
Just concluded our first big trip - 4000 miles Houston to North Rim of Grand Canyon / southern AZ / Big Bend NP Texas. 12.4 miles per gallon.
dhroberts is offline   Reply With Quote
Old 11-26-2016, 11:45 AM   #189
#22
2016 28' Pendleton
Riverview , Florida
I get between 10.5 and 13 hand calculated with my fully loaded 27fb and a bunch of stuff in my truck. 2016 F150 with 3.5 EB. Tows fine and I am happy, I do miss the stopping power of my F350 but I am happier overall with the half ton.
No.15 is offline   Reply With Quote
Old 11-29-2016, 07:02 AM   #190
2016 30' International
Florence , Alabama
We went to the Smokey's and back for Thanksgiving. Mostly around 55mph because of the curvy roads, stayed off the interstates completely on the way home because of traffic; got just under 14MPG.
joshjack is offline   Reply With Quote
Old 11-29-2016, 08:45 AM   #191
2010 25' FB Flying Cloud
Tulsa , Oklahoma
2015 Ram 1500 5.7 Hemi 3.21 gears pulling relatively empty 2011 23D on relatively level highway with little wind at 60-65 mph = 12-13 mpg.
rlhendren is offline   Reply With Quote
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
Best used TV for $10-20k for 10k# towing & mpg SierraSummit Towing, Tow Vehicles & Hitches 108 12-16-2013 02:41 PM
New BMW SAV TV- 20 mpg Towing? TouringDan Tow Vehicles 32 03-10-2013 08:32 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
