Old 09-19-2016, 09:45 AM   #169
mefly2's Avatar
2015 25' FB Eddie Bauer
14.6 @ ~55 with AS25EB and Chev 2500HD ...
Old 09-20-2016, 06:57 PM   #170
1995 34' Limited
Neosho , Missouri
16.5 running 60mph
Railroader is offline   Reply With Quote
Old 09-21-2016, 06:45 AM   #171
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by Railroader View Post
16.5 running 60mph
With what TV?
MICHAEL
Old 09-21-2016, 09:20 AM   #172
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Helpfull info to all as it relates:
Tow vehicle brand, model, year, engine,fuel,
4x4, rear end ratio, Tow package, etc..
Type of terrain (flat/mountains)
TV loaded weight
Trailer weight
mpg
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 09-22-2016, 06:48 AM   #173
Howell , Michigan
Ram 6.4L Hemi 3.73 vs 4.10
I have heard people say that the Ram 6.4L Hemi with the 4.10 rear end gets better gas millage than the 3.73 when not towing on highway because the MDS stays engaged longer with the 4.10. Anyone have any experience or thoughts on this. Having a hard time deciding on which rear end for a daily driver and towing a 26U. Can't justify the cost of the diesel.
jcrango is offline   Reply With Quote
Old 09-22-2016, 04:58 PM   #174
1995 34' Limited
Neosho , Missouri
16.5 running 60mph
Sorry, 2013 Chevy 2500 Z71 Duramax mostly flat roads.
Old 09-22-2016, 05:00 PM   #175
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Per your Vehicle Computer? Or at the pump with your calculator?
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-22-2016, 09:40 PM   #176
1995 34' Limited
Neosho , Missouri
I have checked it each way. Running solo it gets 19.7 mpg cruise set running down the interstate at 70-75. No chip just stock besides a K&N filter. I was pulling a smaller fiberglass Bigfoot trailer and the 34' Airstream pulls like a dream and doesn't catch as much wind.
Old 10-15-2016, 07:49 PM   #177
2016 30' International
Florence , Alabama
Got almost 13 today pulling my new International 30 going 70 most of the way. That's on the dash computer.
joshjack is offline   Reply With Quote
Old 10-15-2016, 09:42 PM   #178
2012 19' International
Southeastern MI , Michigan
9 mpg today. About 300 miles mostly 70 mph, flat ground in Michigan and Canada. Ford Superduty pulling a 19'.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 10-15-2016, 09:48 PM   #179
2014 25' FB International
airstream , zero
12.3 mpg from Fort Collins to Portland, Astoria, Grand Teton and back. Maximum 65 mph when towing, 3.55 gears.
Zeitlupe is offline   Reply With Quote
Old 10-15-2016, 10:02 PM   #180
Ravenna , Ohio
70 mph ! Trust you are not running ST type tires that have max speed rating of 65 mph.
Tireman9 is offline   Reply With Quote
Old 10-15-2016, 10:47 PM   #181
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
From Show Low, AZ to Paradise, TX (30 miles northwest of Dallas) about 820 miles, the numbers were about 11.5 mpg with a 2012 Ram 2500HD Cummins towing the 2014 Classic. Rig weight around 19,000 pounds. Posted speed limits or 65mph max. Michelin LT225/75R16/E LTX M/S2 tires on the trailer at 73 psi and the truck Michelin LT265/70/R17E tires were at 80 psi front and rear.
Old 10-15-2016, 10:48 PM   #182
2016 30' Classic
Sandpoint , Idaho
2015 Silverado Duramax w/50 gal aux. tank towing 2016 Classic. Just finished a 10,700 mile trip around the U.S. Averaged 13.6 mpg.
terryg is offline   Reply With Quote
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
Best used TV for $10-20k for 10k# towing & mpg SierraSummit Towing, Tow Vehicles & Hitches 108 12-16-2013 02:41 PM
New BMW SAV TV- 20 mpg Towing? TouringDan Tow Vehicles 32 03-10-2013 08:32 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
