Old 09-09-2016, 06:54 PM   #141
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Originally Posted by MarkR View Post
2001 F150 SuperCrew
3.55 Differential
5.4L Engine
Hwy 5 / Flat Central Valley
60 - 65 mph
'60 Tradewind (most likely 4,500 lbs)
Drum Roll Please:
9.5 mpg . . . so sad
Ouch! I used to be able to coax my 2010 F 150, 5.4 with a six speed into the high 13's easily on flat roads... If I kept my foot out of it, that truck did fairly well.
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 09-09-2016, 10:06 PM   #142
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Maybe 9 years of technology "squoze" a little better mpg into the truck . . . I had O.D. turned off but the engine was at 2,500 rpms, so it wasn't screemin' . . . and I was mostly going 60 . . . If I turned O.D. on then the rpms would drop way down and then . . . "bog" . . . (because I didn't want to go any faster than mid 60's) . . . someone said to get a K & N Air Filter, that it might help . . . I haven't tried anything yet . . . maybe 3.73 ratio would hit the "sweet spot" . . . (not that I'd go through with swapping out the differential).
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-10-2016, 05:01 AM   #143
2014 27' Flying Cloud
Wenatchee , Washington
I had a '09 Dodge Ram 3500 6.7L Quad Cab SRW 4x4 prior to trading it in on my '12 Dodge Ram 6.7L Crew Cab SRW 4x4. While I never towed with the '09, the best mpg I ever got solo with it was 20 mpg. The best I've gotten solo with the '12 is only about 14 mpg. Same gears (3.73) only real difference (other than body style) was crew cab instead of quad cab. I kinda wish I'd quit while I was ahead.
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 09-11-2016, 05:44 AM   #144
2018 27' Flying Cloud
Originally Posted by switz View Post
I would see at least a 10% reduction in mpg for each five mile per increment in speed with my 2010 GoldWing motorcycle. Running 55 mph would see in the high 30s and the posted 80 mph on I-10 in West Texas would see mid 20s.
You also have to deal with the wind in west Texas. So not only do you have the increase in speed, but the wind which cuts into your mileage.
One other note depending on the elevation you will see a difference in your MPG. The higher the elevation, the better the fuel economy.
wbrisett is offline   Reply With Quote
Old 09-12-2016, 10:21 PM   #145
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I have an 08 Tundra 2wd with the 5.7L motor and 6 speed. It has the SR-5 package which means it also has the tow package. Motor and tranny are great. My 66 Tradewind weighs about 5,000 lb ready for camping and I get 13.5 mpg towing gently and 20 mpg solo highway. I am very satisfied.
Dan:
Old 09-12-2016, 11:09 PM   #146
1977 31' Sovereign
Sunset Valley , Texas
I get about 11 mpg whether towing the 20' Silverstreak, 31' Airstream or the 16' trailerCamera. 2014 Tundra TSS 4x4 5.7l. I almost exclusively use tow/haul mode for the torque and gear governance. Get about 18mpg when towing just air. But I can tow the space shuttle if needed
Iansk is offline   Reply With Quote
Old 09-13-2016, 12:20 AM   #147
2007 22' International CCD
He he. That Toyota Tundra is parked not far from the Space Shuttle it towed. I think Toyota gave it to the museum here in California.
It's good advertising, but I wouldn't want to buy it as a used vehicle. 😀😀😀
KE4GNK/AE
Old 09-13-2016, 09:19 AM   #148
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 11
You may enjoy this discussion on modeling towing an Airstream trailer:
http://ecomodder.com/forum/showthrea...ics-32325.html
The thread starts with:
I spent a week and a half playing around with Dr.Frank Buckley's drag data from the late 1970s 'Sedan/Airstream' wind tunnel study at The University of Maryland.
sgschwend is offline   Reply With Quote
Old 09-13-2016, 09:26 AM   #149
2016 19ft flying cloud
Spokane , Washington
2007 Tundra
We got 13.9 mpg on our maiden voyage pulling our brand new 2016 19 ft flying cloud ...pretty happy about that
Probably because I was afraid to go over 55
Spinonedad is offline   Reply With Quote
Old 09-13-2016, 09:51 AM   #150
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
2012 tundra pulling 2011 23FB. Just got back from Colorado trip. Averaged 11-12 mpg, and tried pretty hard to keep it under 70 mph. It's ok mileage, but with the fuel capacity I have, I don't go too far past 200 miles on a tank.
Married 39 years, ran out of gas one time with the family. I'm a lot more careful now.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 09-13-2016, 10:04 AM   #151
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
Port Townsend , Washington
Really interesting read!
NWGetaways is offline   Reply With Quote
Old 09-13-2016, 04:32 PM   #152
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It's an excellent site. "Aerohead" has guru status, well-earned.
What I should have added in my posts there is that,
- the highest absolute mpg for given TT will be due to TV spec.
- But, highest mpg among an otherwise identical group will be to the operator with the greatest motivation. In commercial driving this difference is just over 30% when all else is the same.
IOW, a lousy driver can defeat the best attributes of a well-designed combined rig.
And, what's possible for a given rig is almost never explored.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 09-13-2016, 04:53 PM   #153
2015 25' FB Flying Cloud
Sandy , Utah
I got 14.5 to 15 MPG with my wife's Audi Q7 TDI towing our 25FB then I discovered that we needed Generators, chairs, tables, BBQ, patio mat, outside beer cooler.........now I get 12 to 12.5 or so with a 2016 Silverado 1/2 ton Crew 4X4 with the 5.3. Live and learn.
rocco52 is offline   Reply With Quote
Old 09-13-2016, 05:12 PM   #154
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
.. all the number crunching will get you to the same conclusion- 12- 15 MPG is what you will likely get.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 11:57 PM
Best used TV for $10-20k for 10k# towing & mpg SierraSummit Towing, Tow Vehicles & Hitches 108 12-16-2013 03:41 PM
New BMW SAV TV- 20 mpg Towing? TouringDan Tow Vehicles 32 03-10-2013 09:32 AM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 09:13 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 03:35 PM
