08-19-2013, 11:21 AM
#241
St. Catharines
, South Western Ontario
Originally Posted by Englishgirl
It's automatic with the option of switching to manual. It all seems to work well together.
Nice looking rig Englishgirl and those Volvo's are a rock solid vehicle. Bet it does work great as a TV, especially with the Can Am set up.
08-19-2013, 11:23 AM
#242
1984 34' International
Toronto
, Ontario
Originally Posted by Timofeevich
Englishgirl, nice setup indeed !
What is the GVWR and Hitch Weight of your 2000 Excella 31', by the way ?
If I am not mistaken, the maximum allowed weights for Volvo XC70 T6 AWD are 3970lb (1800kg) GVWR and 330lb (150kg) Hitch Weight.
For Volvo XC70 2.4D AWD they are 4630lb (2100kg) and 330lb (150kg) respectively.
Does the reinforcement of hitch by Can Am mean that you can legally exceed the maximum allowed GVWR as specified by Volvo ?
Looks to me like you might be comparing a European setup, without weight distribution, with a US or Canadian setup which includes weight distribution.
The Volvo has a total payload of approx. 1200 lbs, the tongue weight of the Excella is 690lbs. With a well set up hitch, this should leave Englishgirl with a margin of about 700lbs (my guess), ample for two adults, kids, gas and luggage.
To put this into perspective, a Toyota Tundra, which Toyota sells hard as a towing vehicle and gives a tow rating of 8,100lbs, has a total payload of 1365lbs - just above that of the Volvo and less than most modern minivans.
Rear gross axle weight rating of the Volvo (GAWR) is 2,646 lbs., the front is 2,800 lbs..
As far as I am aware, the GVWR as specified by Volvo carries no legal weight.
08-19-2013, 11:37 AM
#243
2012 25' Flying Cloud
Battle Lake
I'm enjoying the o.p.'s "What you tow with?" question. There's plenty of tow capability threads, even a few on Volvo's; let's not muck this one up asking the poster to defend his/her setup.
doug
08-19-2013, 07:15 PM
#244
EnglishGirl
2000 31' Excella
Milton
, Ontario
Thanks Doug!
08-20-2013, 02:05 AM
#245
1991 Excella 29' Polished
1991 29' Excella
Odessa
, Ukraine
Thanks Englishgirl, Andy and Doug !
08-20-2013, 05:47 AM
#246
EnglishGirl
2000 31' Excella
Milton
, Ontario
Yes apologies Thank you both Andy and Doug! I
09-03-2013, 04:21 PM
#247
2012 25' FB Eddie Bauer
Eugene
, Oregon
2012 Suburban 2500. It's got a 6.0 Gas engine w/ 3.73 gearing and a 6 speed transmission (all stuff folks here probably already know). The trailer is a 25' Eddie Bauer and they're linked together with a ProPride hitch which seriously saved my bacon about two weeks ago.
This setup has power and weight capacity to spare which is just how I like it. The Suburban also gets used with solo with studded tires on family ski trips in the winter.
09-03-2013, 06:01 PM
#248
2005 30' Safari
Houston Texas
Suburban K2500 8.1 liter, 4.10 gears...sweet towing!
09-03-2013, 06:04 PM
#249
2005 28' Safari S/O
Paradise
Tows like a dream....
...F250 6.0 Powerstroke Diesel and 28' Safari Slide. Plenty of toy capacity! Photo taken at the world's most beautiful dump station near Stanley, ID.
Steve
"THE OLDER I GET, THE BETTER I WAS"
10-09-2013, 07:59 AM
#250
one of those
2011 27 FB International
'03 F250 PSD
, Airstream summers, Catalac winters
This has really gotten my attention. I've been looking at Excursions, and Expeditions, because that's been what I thought I needed. Our trailer is about four feet shorter and so I would imagine a bit lighter, so if this works well for you, it might work well for us. If I can tow with something this size, suddenly free garage storage is available to me!
Have you towed at any altitude? All our Airstreaming is in the Rockies. How does this setup perform going up a mountain pass, assuming a nice smooth highway, not a rutted switchback. Say, from Denver to Eisenhower Pass on Interstate 70 kind of thing. How fast do you tow?
Is the hitch special, or would a Reese Dual Cam work too? I have one still in the box.
Thanks for any info.
10-09-2013, 11:47 AM
#251
one of those
'03 F250 PSD
Originally Posted by kscherzi
2013 27 FB towed by a 2003 Ford Expedition 5.4 liter V8. Note how the rear squats under the load. I took it up to Lake Tahoe day of this photo. Above 6,000' it barely held 40 mph up the grades floored. Drives fine otherwise.
Is there a differential gear option that would help that climb performance?
10-09-2013, 07:43 PM
#252
2004 30' Classic Slideout
Fenton
, Missouri
I'm not familiar with Fords, but higher ratios can always improve performance and raise towing limits. That's one of the reason I ordered a 4.10 axle with my GMC van. The offset is that axle will hurt solo gas mileage due to the engine running at higher rpm's.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-13-2013, 08:26 PM
#253
2017 25' International
Los Osos
Our 2013 Dodge RAM 1500 Outdoorsman 5.7L Hemi has towed our 2013 International 19 6000 miles over the past 5 months.
The RAM has plenty of power and can handle anything in the Cascades or Rockies. It will climb very steep grades at 65mph.....if you want to pay for the gas. Averages 12.5 mpg towing and gets 20 mpg highway w/o trailer.
So far...so good.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
10-13-2013, 09:48 PM
#254
2012 30' Flying Cloud
San Antonio
Pull a 2012 30 Flying Cloud with a 2012 Chevy 2500 4/4 crew cab 6.6 Duramax diesel. I'm on old, old, old Navy fighter pilot, so to me there is never any such thing as too much power. I have to check the rear view mirror to be sure the Airstream is still there
10-14-2013, 06:33 AM
#255
2009 27' FB Classic
Smithville
, New Jersey
Silverado 2500 duramax
Assateague, just before the shutdown.
10-14-2013, 07:12 AM
#256
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
They can tow something other than an Airstream.
10-14-2013, 08:00 AM
#257
San Antonio
Bob, tell me that's not yours! Is that one a 6 speed? You're going to kill yourself going that fast.
10-14-2013, 08:55 AM
#258
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
10-14-2013, 09:03 AM
#259
San Antonio
Oh yes, I know that picture. Lived in Buffalo many years--scuba dive the Niagara river many years. Daughter still lives there. Will give a shout next trip up to visit
#260
Salem
, Oregon
Hi, [not a boat person] how do you dyno a prop? Pictures?
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
