Old 09-10-2016, 11:14 AM   #85
Rivets?
nvestysly's Avatar
1992 29' Excella
Van By The River , Georgia
Been a while since I've posted here. Can't recall quite what I've been doing for the past several months but I'm sure there were some repairs/modifications in there somewhere.
I recently noticed a coolant leak on our 2005 Suburban. It was pretty obvious the leak was coming from the water pump so I ordered a replacement part. It occurred to me there might be other problems since the vehicle is 11 years old and has just over 100k miles.
During the water pump installation I noticed coolant residue on the tank portion of the radiator - looks like I need to replace that too! I'll take some pictures when I perform the work on the radiator.
For now, here's a picture of the water pump. It's old-school cast iron so it's heavier than it looks!
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 09-10-2016, 11:28 AM   #86
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . put Flowmaster cat back exhaust & K & N filter on my new Eco-blahblah F150. . . not as loud as the Heartthrob I put on my '11. . . saw 21 mpg coming downhill from the high country Monday (sans AS). . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-12-2016, 11:16 AM   #87
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I performed a scheduled emissions service on the truck at 67,500 miles. Cleaned the egr valve, egr cross over, egr cooler, intake butterfly and MAF sensor. I had a bottle of the Mopar soot cleaner and I also used some heavy duty simple green cleaner. Simple green works wonders on soot!
As part of this maintenance the crankcase vent filter gets replaced too. The job involves taking apart quite a few things, a special wrench or two and some new cuss words. I did it over the course of a few evenings after work. Cost was ~$125 in parts. I have heard the dealer charges $600 and up for the service but there is multiple hours involved in the doing the project correctly.
I also decided to throw a transmission, transfercase and brake fluid change in while I had time.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-22-2016, 11:26 AM   #88
Rivets?
nvestysly's Avatar
1992 29' Excella
Looking back through this thread I see lots of DIYers in this group.
My latest repair was replacing the rear differential pinion seal on our 2005 K2500 Suburban. This should have been a two hour job based on the same task I performed on our 1996 C2500 Suburban.
However the puller I used for the job didn't work (the thread on the shaft galled) so a trip to the hardware store as well as some fiddling around... and this job took nearly six hours! Consequently, I didn't take many pictures.
Name:	ImageUploadedByAirstream Forums1482430893.691125.jpg
Universal joint disconnected with tape around the bearing caps so they don't fall off.
Name:	ImageUploadedByAirstream Forums1482430977.097694.jpg
1-1/2" nut on pinion yoke.
Name:	ImageUploadedByAirstream Forums1482431036.937499.jpg
Puller in position to remove yoke. Note the marks on the end of the threaded portion of shaft to ensure the yoke and the nut are re-installed in the same orientation
Lucius and Danielle
Old 12-31-2016, 07:13 AM   #89
crispyboy's Avatar
1994 30' Excella
I have done a few pinion seals, what fun it can be rolling around under a vehicle. I am currently putting front and rear control arms (upper and lower) on my wife grand Cherokee. It is also needs a rusty brake line replaced. Then it's on to my econobox Honda Civic for brakes. I also worked on the washing machine this week. The fun never stops in our house. Too top all that off we had to put down our 16 year old border collie last night..... I feel like I have a black cloud hovering us this past month.
WBCCI # 3072
Old 01-01-2017, 06:34 AM   #90
2012 19' International
Southeastern MI , Michigan
I applied Fluidfilm undercoating to the underside of the truck in the fall. Rolled underneath to check and touch up any spots. Also pulled the interior trim and applied Waxoyl to all the interior body panels. I've used this stuff for years. It does an amazing job preventing rust. You do have to reapply periodically. I buy the gallon size and use undercoating wands to reach enclosed sections of the underbody, frame, and box.
2012 Serenity 19
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 02-16-2017, 12:14 PM   #91
Rivets?
nvestysly's Avatar
1992 29' Excella
What would I do with my time if we didn't own a 21 year old tow vehicle? I guess I'd buy a 12 year old tow vehicle!
Even the newer (12 y.o.) Suburban we own needs repairs now and then. At 117,500 +/- miles the check engine light came on the orher day. The local parts store checked the code and found the driver side upstream oxygen sensor was faulty. I decided to purchase two upstream sensors and replace both the driver and passenger side.
The sensors were easy to access, not too difficult to remove, and less than one hour later the Suburban was running fine and the check engine light cleared itself.
Name:	ImageUploadedByAirstream Forums1487272137.369993.jpg
Name:	ImageUploadedByAirstream Forums1487272159.234756.jpg
Cost of repair: <$200 and 1 hour of time
Dealership estimate: around $400 including labor, plus I would have spent 3 or more hours waiting in the "lounge" in their service department.
I've seen a signature here on Air Forums that indicates if women don't find you handsome they should at least find you handy. I think that's attributed to Red Green. So maybe I'm at least handy!
Lucius and Danielle
Old 02-16-2017, 12:25 PM   #92
Kevin245's Avatar
New number 4 cop, fresh set of plugs, and a new fuel filter. 271,000 miles.
Eleanor Roosevelt
Old 02-16-2017, 02:35 PM   #93
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The center console armrest cover was coming apart in my 2007 Tundra.
The lid new from Toyota is over $500.
Maybe I could get it covered at an upholstery shop for much less than that.
What I did: I ordered a $25 slip cover from Amazon to hide the peeling material on the console lid.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-16-2017, 03:40 PM   #94
1999 30' Excella 1000
Brookeville , Maryland
Attachment 279945
Attachment 279946
Great pictures nvestysly. I replaced 3 sensors on my 2006 Dodge Ram. They sell them at auto parts stores for $ 40.00 ea. Bought special sockets for them, ended up using a pipe wrench. Since I'm very handy, that must mean....oh well.
streaminwild is offline   Reply With Quote
DIY Main Awning Arm Repair Trackers Awnings 5 09-12-2008 07:39 AM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Latest in 5th wheel tow rigs bkahler Tow Vehicles 15 07-14-2007 09:23 AM
Latest Modification for Tin Hut Tin Hut Exterior Restoration Forum 10 12-30-2003 08:06 AM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
