Old 08-30-2015, 09:19 AM   #57
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
A passenger side step isn't available for the Tundra- I assume due to where the exhaust exits-
I replaced the serpentine accessory drive belt after hearing it squealing on a camping trip. Toyota really made it an easy DIY job the way they routed it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-21-2015, 08:24 PM   #58
m.hony's Avatar
2013 30' Classic
Front hitch receiver-
Looks like the front bumper was designed for it-
Name:	ImageUploadedByAirstream Forums1442888456.923916.jpg
Name:	ImageUploadedByAirstream Forums1442888480.308012.jpg
Name:	ImageUploadedByAirstream Forums1442888496.569607.jpg
Name:	ImageUploadedByAirstream Forums1442888516.272449.jpg
Literally a 10 minute install-
No extra hardware-
Remove 2 tow hooks, 2 bolts each, 4 bolts total-
Install receiver with mounting tabs between the frame and tow hooks using the same bolts-
Easy-
TAC #MS-10
Airforums #70955
Old 09-24-2015, 08:32 PM   #59
m.hony's Avatar
2013 30' Classic
Name:	ImageUploadedByAirstream Forums1443148353.981259.jpg
TAC #MS-10
Airforums #70955
Old 12-18-2015, 10:29 PM   #60
1973 31' Sovereign
Minneapolis , Minnesota
I repaired almost everything on this truck. It's a 1976 Ford F100 God I love her, she brought me home to Minnesota, a trip of almost 2500 miles.
fairtheewell is offline   Reply With Quote
Old 12-21-2015, 07:38 PM   #61
Rivets?
nvestysly's Avatar
1992 29' Excella
Van By The River , Georgia
Bedslide is Installed and Enhanced
In one of the earlier posts of this thread somebody showed a sliding bed tray made of wood and a series of roller bearings. I love that idea but decided to take a different approach for our 2005 Suburban.
We already had a used Extendo Bed in our 1996 Suburban and I love that thing! We bought it used, from a fire department, via eBay. Pictures of a similar product are found HERE.
When we purchased a used 2005 K2500 Suburban a few years ago I knew I wanted some sort of slide out tray option but the Extendo Bed, as cool as it is, is really heavy. The design of Extendo Bed allows the tray to slide out a full 110% so you can access everything from the rear and sides. As I said, it's way cool. But I wanted something lighter weight - the Extendo Bed probably weighs 500 pounds by itself - so I started looking for other options.
I found a used Bedslide on Craigslist and the price was right - I think I paid $225. I had a local welding shop make an aluminum shelf and that allowed me to put all my camping equipment as well as most of the tools I use for Habitat for Humanity on the modified Bedslide. I put another $300 into the aluminum frame, plywood and misc. hardware so for just over $500 I have a very workable solution for our needs.
Here are a couple pictures of the original Bedslide. Notice the original came with a 4" aluminum edge on three sides of the tray.
The second set of pictures shows the enhanced Bedslide. I removed the 4" aluminum sides and replaced it with aluminum angle that creates a 1" lip around the perimeter of the original tray. The shelf is slightly shorter (front to rear) than the bottom tray so allow for a few "tall" items such as a tool box, air compressor and water softener. The shelf is constructed of aluminum and creates a lip around the top shelf. I drilled a series of holes so I can use elastic cords to secure items.
By the way, the entire weight of the enhanced Bedslide is about 175 pounds. Consider that we removed about 75 pounds by taking out the 3rd row seat and the Bedslide only adds 75 pounds. The "stuff" on the Bedslide weighs 380 pounds.
The Bedslide only pulls out 70% so it's not quite as easy to access everything but we're saving several hundred pounds. We'll give it a try for a while and see how it compares to the Extendo Bed.
ID:	254302   Click image for larger version
ID:	254304   Click image for larger version
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-21-2015, 09:31 PM   #62
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Wow! That's a lot of stuff. Pretty awesome slide for sure!
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-22-2015, 06:31 AM   #63
Rivets?
nvestysly's Avatar
1992 29' Excella
Moderator, here's the new picture
Lucius and Danielle
Old 12-22-2015, 06:50 AM   #64
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Ball joint removal/replace
Last year I had a mechanic tell me that the ball joints were starting to get loose in the truck (Dodge 2500). Since I planned on getting new tires I thought this would be a good time to replace the ball joints, new tires and finish up with a front end alignment.
I plan on keeping my pickup for several more years so I decided that I would spend extra money and get some top shelf ball joints. These are greasable and warrantied for as long as I own the truck. I did this job back in November but I didn't take any pictures. I did snag a picture from the internet of the new ball joints. Probably not too exciting for you guys but the truck does track nicely with the new parts, tires and alignment. The ball joint change out was one of the physically harder jobs I have tackled in awhile. One thing that helped with installation is that I put the new ball joints in the freezer for two days before pressing them in.
Name:	ball joints.jpg
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-22-2015, 07:03 AM   #65
Rivets?
nvestysly's Avatar
1992 29' Excella
I like the freezer idea. That probably gains you a "thousandth" of an inch. I guess if needed, the opening in the A-arm could be heated and that would gain a few thousandths in the other direction.
What did you use for a press? Maybe you have a hydraulic or arbor press - in which case, I'm envious. Otherwise, I've seen something that resembles a large C-clamp for removing ball joints.
I suspect I need to replace the lower joints (press-in style) on my 1996 Suburban and as you said it looks like a physically demanding task.
Lucius and Danielle
Old 12-22-2015, 08:22 AM   #66
crispyboy's Avatar
1994 30' Excella
I had the large C-clamp tool along with 1/2" drive, 3/4" drive, cheater bars, penetrating fluid, smoke wrench, etc........
One of the hardest parts is trying to get the C-clamp in place with the various adapters - many days I should have been born with a few more arms.
WBCCI # 3072
Old 12-22-2015, 08:41 AM   #67
Tuco's Avatar
1988 32' Excella
Ojai , California
Attachment 254320
How many miles did you get out of the original ball joints?
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 245k+ (The Beast)
Tuco is offline   Reply With Quote
Old 12-22-2015, 09:37 AM   #68
crispyboy's Avatar
1994 30' Excella
62k miles though I think I could have milked more out of them. According to my dial indicator I was getting in the neighborhood. The factory specification actually allows for a lot of slop. I'm a stickler for good steering - or at least as much as a solid front axle will give you.
WBCCI # 3072
Old 02-17-2016, 08:35 AM   #69
Rivets?
nvestysly's Avatar
1992 29' Excella
Our 2005 Suburban had a water leak on the passenger side. After a heavy rain we would find the floor mat thoroughly soaked. However, the carpet (under the floor mat) was typically not wet and the Husky floor liner (on top of the floor mat) was not wet.
Why do we have a factory floor mat and a Husky floor liner. Who knows?
So somehow the water was making the center of the sandwich wet but not the top and bottom (bread) of the sandwich. I was finally annoyed to the point that I decided to investigate.
Danielle helped me to methodically apply water to the passenger side of the vehicle. We started near the front fender, slowly worked our way to the bottom edge of the windshield, moved up the edge of the windshield, then to the antenna mounted on the roof just above the windshield, then to the sun roof, then to the roof rack. We spend an hour or so and no evidence of water. Arggh!
We put all our investigatory tools away and I was discouraged that we hadn't found the leak.
Then I had a aha moment. The proverbial light bulb turned on. What if water had leaked in but it simply hadn't made its way to the carpet yet?
I removed the plastic cowl from the passenger side of the floor area and found a cup or so of water poured out. Hmmm. We began repeating the water test and quickly found water dripping from the HVAC blower motor.
Ultimately, water was entering in to the fresh air intake because of a poor/damaged gasket on a plastic cover. I removed the windshield wipers, removed the cowl grill and found the plastic cover was not very secure. The plastic cover was difficult to remove and I broke a few tabs during the removal process.
A new cover, gasket and some RTV and snapped the cover back into place. No problems after a month or so since the repair. We've had several heavy rains so seems to be fine for now.
The carpeted floor mat extended up near the blower motor. The Husky floor liner stopped short of that. So when water dripped down it landed on the carpeted floor mat and prevented water from reaching the carpet. Consequently, the middle of sandwich would get soaked but not the top and bottom.
ID:	257391   Click image for larger version
ID:	257393   Click image for larger version
Lucius and Danielle
Old 03-30-2016, 06:49 PM   #70
Nomadic , USA
New truck, new mods.
Getting this installed tomorrow or Friday, depending on how busy the shop is. And installed my new Air intake this afternoon:
DIY Main Awning Arm Repair Trackers Awnings 5 09-12-2008 07:39 AM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Latest in 5th wheel tow rigs bkahler Tow Vehicles 15 07-14-2007 09:23 AM
Latest Modification for Tin Hut Tin Hut Exterior Restoration Forum 10 12-30-2003 08:06 AM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
