Old 04-20-2015, 10:57 PM   #29
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
New ceramic brake pads for the Kodiak calipers on my 34' Classic.
Whew, that's a lotta lug nuts!
Old 04-20-2015, 11:15 PM   #30
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . installed Banks cold air box on my EcoFord, & doing all service prior to heading for Alaska in May. Tranny fluid, brake pads, fuel filter & serpentine belt on the list. AS is already serviced & ready to go. . .I like the look of that Mag-Hytec diff cover, investigating. . . Regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 04-21-2015, 05:12 AM   #31
1973 31' Sovereign
Minneapolis , Minnesota
I am from Minnesota but I am currently in the chihuahuca desert, in west Texas (trying to get home) so I did the battery, alternator, fuel lines, brake lines, carb, fuel pump, headlights, tail lights, turn signals, basically all the lights, filters and horn. I am sure I am forgetting something here...
It's a 1976 Ford f100 flatbed I've been working on.
I reallllllly want to go home. lol.
fairtheewell is offline   Reply With Quote
Old 04-21-2015, 05:21 AM   #32
1973 31' Sovereign
This is the truck I've been working on.
Old 04-21-2015, 10:25 AM   #33
gdanderson's Avatar
1967 22' Safari
Monona , Wisconsin
New tow vehicle and accessory
Purchased at 2015 Chevrolet Colorado and added a bed slide.
Greg Anderson
Wisconsin
ID:	236749   Click image for larger version
gdanderson is offline   Reply With Quote
Old 04-21-2015, 01:10 PM   #34
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
added Prodigy brake controller and a 7 Pin hitch adaptor to my new to me 2006 Expedition 5.4 V8
Sucker tows like a dream.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 05-12-2015, 03:54 PM   #35
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Multi-Switch Replacement: Hazard Lights, Turn Signals, Cruise Control, etc.
I haven't made the repair yet but I've ordered the part - a new multi-function switch for the steering column of our 1996 GMC Suburban. The vehicle is 19 years old and has over 170,000 miles. However, this will be the 3rd time the multi-function switch has failed. Arrrggghhh!
I'll post a few pictures when I perform the repair later this week. The video below was very helpful in determining that I am capable of performing the repair. The internet can be a wonderful thing!
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 05-13-2015, 11:06 AM   #36
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
What Was Your Latest DIY Tow Vehicle Repair or Modification?
Setting the adjustable aftermarket stinger for the Hensley Arrow.
New breakaway switch, new tongue jack, and chain + 7-way extensions.
R&R the truck starter, a new pair of batteries, and a half mile of batt cabling with quite a few minor and major connections.
Going thru the water heater at present. 1989 Suburban. Will probably leave propane capped for now.
Brake and bearings, next. And new brake controller. Thinking of adding separate charge line to TT batts.
Dodging heavy rains or intermittent showers. The south side of town is under water.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 05-13-2015, 12:01 PM   #37
Tincampers's Avatar
Sneedville , Tennessee
2003 Suburban 2500 4WD. Replaced the rear bump stops. The originals were completely gone and I was getting a nasty rear axle kick in the butt when riding over touch terrain. I will also be replacing the ones for the front axle too. They are called lower control arm knuckle bumpers.
Tincampers is offline   Reply With Quote
Old 05-13-2015, 05:00 PM   #38
Tincampers's Avatar
Here's what those front bumpers look like old and new. It made a huge difference in the ride.
Old 05-13-2015, 08:32 PM   #39
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My last tow vehicle repair was to pull the 4.8 engine out of my wife's Tahoe and replace it with a "freshened" 5.3...
Then we pulled the trailer to NM and AZ on an extended trip.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 05-14-2015, 05:25 AM   #40
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
What are those and how did the old one burn up?
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 05-14-2015, 05:49 AM   #41
Tincampers's Avatar
They sit on top of the lower control arm and are mounted to the frame just behind the lower shock mount. Just age I guess. The other side had no rubber on it at all. I think they help absorb shock from the lower control arm movement. I'll get a picture posted so you can see them installed.
Old 05-14-2015, 10:55 AM   #42
Tincampers's Avatar
Here's a picture of the bumpers installed.
DIY Main Awning Arm Repair Trackers Awnings 5 09-12-2008 08:39 AM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 01:06 AM
Latest in 5th wheel tow rigs bkahler Tow Vehicles 15 07-14-2007 10:23 AM
Latest Modification for Tin Hut Tin Hut Exterior Restoration Forum 10 12-30-2003 09:06 AM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 11:38 AM
