Old 11-18-2008, 11:04 AM   #1
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Lightbulb What does it weigh?
My 07 Safari FB and GMC 3/4 ton diesel truck weighs in as follows..how about yours?
Steer Axle 4380 lbs
Drive Axle 4660 lbs
Trailer Axle 6140 lbs
Gross Wt. 15180 lbs
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-18-2008, 11:15 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
'95 3/4 ton Dodge Conversion Van - 360 CID Motor -
'78 Sovereign w/ "normal" fluids, cloths, and "stuff"
Reese Dual Cam Springs on Link #5 (4 links under, 4 links hanging)
Weights taken September of 2007
Steer (Front) axle - 2920 lbs
Drive (Rear) axle - 3400 lbs
Trailer axles - 6040 lbs
Total 12,360 lbs
On a separate weigh I found the tongue of the trailer carried 660 lbs.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-18-2008, 11:30 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Weights
Loaded for two weeks of dock'n.
str-3620
dr-4740
trlr-7580
tot-15940
Name:	PISECO LAKE CAMPING JULY 2008 031.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-18-2008, 04:24 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
keep in mind diesel engines are always heavier
Steering axles lbs will reflect that.
mustang is offline   Reply With Quote
Old 12-24-2008, 04:25 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The van listed below towing a 1997 Welcraft Express Cruiser (27' boat w/ 2 axle trailer) single engine boat and 3/4 full fuel tank
Steering axle 2560 #'s
Drive axle 3660 #'s
Trailer axles 6940 #'s
Total gross 13,160 #'s
My A/S was weighed with some one else's TV.
>>>>>>>>>>>>>>>>Action
Old 12-24-2008, 07:23 PM   #6
SteveH's Avatar
Common Sense , Texas
I had to weigh mine when I applied for Texas title because the out of state title it came with did not include the weight....go figure!
Anyway:
Truck front axle....3120
Truck rear axle.....3400
Airstream axles.....6080
Groose weight.....12600
'07 GMC EXT Cab 1/2 ton, and '01 25' Excella
Regards,
Steve
Wheel Weigh Pads, anyone try them ??? wagnerda Hitches, Couplers & Balls 20 10-23-2007 07:45 PM
What does your 1970s Airstream weigh when it's all loaded up? 72Blazerod Our Community 2 10-09-2006 08:26 PM
What does your Ambassador weigh when you have it loaded up? 72Blazerod 1974 - 1979 Ambassador 3 10-07-2006 07:23 PM
How much does a '76 - 31ft Sovereign REALLY weigh? 72Blazerod 1974 - 1979 Sovereign 11 05-16-2006 01:13 AM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
