Old 11-03-2008, 12:57 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
What Diesel pickup truck has driven to the North Pole?
Ok Trivia question here... Does anyone here know What Diesel (because gas would freeze) Truck made it to the north pole.... (driving all the way) there was Three of them on the trip to help each other out...
They took Chain saws to to cut ice out of the way.... Any guess on which brand of chain saw that works at -42.
And it's all on a show... Very interesting... The trucks were modified a bit.. But then they would have had to been....
Anyone??
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 11-03-2008, 01:55 PM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
i'd guess Toyota Top Gear: Polar Special - Wikipedia, the free encyclopedia
truckasaurus is offline   Reply With Quote
Old 11-03-2008, 02:07 PM   #3
purman's Avatar
1968 28' Ambassador
BAD, Not suppose to Google search,,,
But yes you are right.....
Now Top Gear aside, it is pretty impressive to see...
Not a Ford, Dodge, or Chevy,, They choose a Toyota Tacoma, and sent it to Iceland to be decked out.... So there wasn't much Toyota left when they were done...
But all the way to the north pole..
You can watch clips on youtube if you would like to see it....
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 11-03-2008, 02:16 PM   #4
Certifiable
mistral blue's Avatar
Cool Your siggy gave it away
Ooo, I know!
a '89 Diesel Jaguar XJ6
What did I win?
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Old 11-03-2008, 02:30 PM   #5
Crusty's Avatar
1992 34' Excella
Actually gas will go to lower temps unaided than diesel because of the parafin in diesel which turns the diesel fuel into jello.
For diesel trucks like those that run the Montana outback during the winter where it can get to 40 below, they use insulated fuel tanks and fuel lines, engine coolant fuel tank heaters as well as electrical fuel tank heaters, battery heaters, radiator tarps (or fan disconnects) to stop the airflow through the radiator, custom mixtures of No.1 and No. 2 diesel fuel in the tanks, fuel additives, and more than one keeps a small tarp and a 50 bag of charcoal onboard to build a small fire underneath a tent over a fuel tank to turn 150 gallons of green jello back into diesel fuel.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 11-03-2008, 03:47 PM   #6
purman's Avatar
1968 28' Ambassador
Originally Posted by mistral blue View Post
Ooo, I know!
What did I win?
My jag is a gas job thank you,,,, Wish the heat worked in it... Got to rip the dash out and replace 2 heater fans.... my local garage said he wouldn't touch it... Don't blame him..
"O" Yeah,, My wife won't stop driving it for me to fix... She loves the dang thing for some reason.... Well I guess it does drive rather nicely...
4x4 Jag with a lift HUUUMM>... that could be cool..
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 11-03-2008, 04:58 PM   #7
Road Ruler's Avatar
Images: 38
There was a Jag sedan cruising around here for a while looking like Big Foot.
My guess is that he dropped the Jag body on a traditional 4X4 chassis and went nuts from there. It looked tough.
Old 11-03-2008, 05:01 PM   #8
1960 33' Custom
just to vindicate myself :-) I had seen the show a while back, Top Gear is one of the things I miss from home. I make do with reading Jeremy Clarkson's column in the Sunday Times (UK) online edition. You might like the episode where they tried to kill a small gas pickup, they tried drowning it in the sea, parking on top of a tower block being demolished with explosives and pretty much everything in between.
Old 11-03-2008, 05:37 PM   #9
Certifiable
Thumbs up Sweet!
For a long time now I've been interested in what robandzoe' has been doing to his '59 Buick Electra. It's sitting on a 1975 1/2 ton Trailering Special Suburban chassis and is gonna roar down the road with a 454 and 400 Turbo power plant.
Old 11-03-2008, 08:38 PM   #10
purman's Avatar
1968 28' Ambassador
Wasn't that a toyota too... and didn't it live? Or am I thinking of another episode...
Yeah, It's a year behind on the BBC, and they cut some out for commercials... I just down load it from uknova.com
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 11-08-2008, 06:17 PM   #11
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
The only Production diesel pick up up north that can handle that cold is the new Ford Super Duty. It is the only truck the B.P uses. Toyota doesnt even have a marketed diesel pick up truck??? The toyota had to be modified??? Guess it couldnt handle the cold after all.
I have to laugh, I havent had time to be on here and I see the same old rederict by the same old people. Now thats livin folks
mustang is offline   Reply With Quote
Old 11-08-2008, 06:31 PM   #12
1960 33' Custom
Mysteriously products from the shaking 3 don't rule the entire world. Welcome to Toyota GB
I guess toyota should have checked for all those Fords driving around the pole before they wasted their time but I'm pretty sure common rail diesel is std on Toyota trucks in some of their markets.
Old 11-08-2008, 08:10 PM   #13
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Land Cruiser...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 11-08-2008, 09:45 PM   #14
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Well I missed the truck make but I'd make a guess on the CHAINSAW
How about STHIL?
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Need help in selecting a Pickup Truck for a 34 SO DEO Tow Vehicles 53 11-20-2006 11:06 AM
Anyone driven from NY to Jackson Ctr? bluvalley General Repair Forum 11 05-02-2006 10:53 AM
Has anyone driven route 17 Ottawa to Sault Ste Marie?- Canada? Chaplain Kent On The Road... 3 09-14-2004 05:45 AM
diesel truck-----what to watch out for? Ghost Rider On The Road... 24 06-29-2004 06:51 PM
Diesel truck owners FrankR Off Topic Forum 3 11-23-2002 05:35 AM
