I just read the other day on a thread here that once diesel cost is 80 cents MORE /gal than GAS that there is no way $$ wise you can justify a diesels over gas for a TV.
When I bought my Hemi in 05 it was 80 cents a gallon more the regular...I felt the sameway..
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of A/S and T.V. Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G.....WBCCI # 4201 Metro Detroit & 4CU
Very important consideration jimmini,
Although I am a gasser proponent, the margin of diesel to gas price is only one of the factors, but an important one. That said, the fuel economy decision is also dependent on the realized MPG of the diesel truck vs the gas truck. In my case, the diesel got 10.2 MPG average and the gasser is getting about the same, maybe a little lower if I drive a lot of hills, maybe 9 MPG. In my case, 80 cents made the fuel economy almost dead even, with the gasser just a bit more economical. Now if you have one of those gassers that gets 7 MPG and you compare it to a diesel that gets 14 MPG, then the diesel is still ahead on fuel economy. It all boils down to individual circumstances. The market is seeing more fuel efficient gassers with more HP and torque, while the diesels are also gaining HP and torque, but suffering a loss of fuel economy due to emission controls mostly derived from having to burn ultra low sulfer diesel fuel and meet strickter standards.
OK, maybe I am a bit wordy, but each case needs to be looked at carefully and it is important that we avoid broad or generalized guidelines.
__________________ Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
I don't understand, maybe if I took a bit longer to explain myself I would not be as confused.....so hold on just a bit...but wait, I was told by a moderator that a post has a 500 word maximum, hmmmm, maybe I will just call, thats it, I will conference call you and Bam, that way I can talk as long as I want....
Dang, can't believe that both of your telephones have vacation messages!
And dont forget the Diesel was $5500.00 more...That has to be figured in as well...We have not even touched upkeep costs...
Aw...can't we just talk about illumination for a few hours???
Granted, the swing in diesel vs regular has given me pause, but our Suburban got 10 mpg and the 08 Ford F250 diesel gets 14. Still makes sense.......for us.
Yes, alot depends on how much you drive...I have 30K on my Hemi and have had it 33 months..
All of you are right, notice how each of us have different results from similar TV, some due to the TV and the day it was made, and some due to the way we drive, and some results vary because how much (or not) we drive a year and what ratio is towing.
Goin, if I am not mistaken, your F250 rarely leaves the garage without the AS and you use it quite a bit, so the value of the extra torque, better mileage and long life pays off for you. I don't think you usually drive it to work, right?
altamont, your TV now gets 40% better fuel mileage that your Suburban, for you, that must be nice, if you use it enough, it will pay off.
Airboss, your like me, when I did have my F250 PSD, in 3 years I only had about 21,000 miles on it, one of the reasons I went with a Hemi gasser. I am probably driving the Hemi more because it is a much better daily driver.
ROBERSUNRUS, I know why you have a gasser, because you really like that luxury ride and feel of your Lincoln, even the best truck doesn't come close.
str8 and bam, remind me to slap both of your heads next time I see you.
time
