Old 04-15-2011, 09:39 PM   #85
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by klattu View Post
Volkswagon towing capacity...dang I'm just too old to accept that phrase.
Or not old enough... it's not a new concept. There was a special travel trailer for Beetles in the '70s, that hooked to the top of the beetle 5th-wheel style.
— David
Old 04-16-2011, 09:30 AM   #86
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
It is a shame there was never a Herbie movie with that trailer.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 04-22-2011, 07:58 PM   #87
JFScheck's Avatar
Rockville , Maryland
Images: 33
And have both animated? Guess Herbie would be the boy and the trailer the girl?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-17-2011, 09:01 PM   #88
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Originally Posted by JFScheck View Post
Javier, keep an eye on your hitch to frame mounting points, fellow Cayenne owners (three now) and one T-Rex owners have found bent/deformed bolts observed from bottom of tow vehicles when on jacks.
Keep within your prescribed weights, keep an eye especially on your tongue weight and T-Rex max GVWR limitations and you should have many years of fun with your tv/Airstream package!
I'm searching for this evidence and haven't found it yet. Can you cite examples please?
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 07-12-2011, 04:11 PM   #89
1991 Excella 29' Polished
Timofeevich's Avatar
1991 29' Excella
Odessa , Ukraine
Originally Posted by johnroth View Post
The vehicle with factory hitch has a rated tongue weight of 770 lbs as stated in the manual. Some factory hitches have a label which VW has confirmed to me is erroneous. They have verified that the factory hitch meets the published specs and the label is incorrect. All my previous hitches were labeled as 770 and 7700 lbs as the published specs state.
I am facing a dilemma : friends are selling Airstream PanAmerica 34' (which I like very much), but my car is VW Touarge 2 with 7,716 lb.
Can the Touareg 2 V8 4.2TDI handle the Airstream PanAmerica 34' that has UBW (Unit Base Weight) 7,288lb ? I am not planning to carry any bikers in it over the long distance, but just move it empty from point A to point B. I have never towed any trailers before and also concerned about the tongue weight of Airstream PanAmerica, which is 1,260 (17% of the net weight of of PanAmerica)
Timofeevich is offline   Reply With Quote
Old 07-13-2011, 02:36 AM   #90
JFScheck's Avatar
Images: 33
Timofeevich
From a VW Touareg / Porsche Cayenne owner who has many miles of towing with these vehicles all over the country....
My answer is a strong - NO...
Westfalia
Sorry, I am not at will to provide VIN's, particular info, etc. - other instances continue to surface, I feel confident these folks too will be fairly quiet as their issues are worked out, quietly...
I only ask my fellow German SUV owners to inspect their hitch assemblies as part of periodical maintenance, same as I do with my F-350, Cayenne Turbo & Mercedes ML63 AMG....
I am no longer in procession of my Touareg TDI, nor do i desire to further discuss this issue.
All I'm suggesting to anyone who tows with any type tow vehicle is that they inspect their TV and all components that comprise of said systems, it's the smart thing to do...
All vehicles will have issues, especially when towing large trailers such as race car trailers & Airstreams, regardless of manufacture or type...
**I Love U.S.A.**
Old 07-13-2011, 10:12 AM   #91
Westfalia's Avatar
Images: 35
JFS, I'm am confused by your answer and a little put off with your response. I was not looking for VINs or other personally identifiable information. I wanted you to substantiate your claim by directing the readers or myself to some discussion, hopefully a technical one, discussing the stress cracking and bolt deformation on Cayenne/Touareg hitches since they are one and the same. I have done some cursory web searches and haven't found any specifics as of yet.
As you know, inspecting the hitch beyond the small cross section when the receiver is welded to the cross bar/bumper impact bar is difficult as it completely hidden from view behind the bumper shell. While I do intend on some day taking the rear bumper assembly off, it is not a casual affair to do semi-annually. I have installed my own hitches in the past, so I am fully aware of the work involved.
Keeping this kind of information a secret is just as bad a pretending that it could never happen. I understand the need for discretion, especially as it related to factory concessions or buy backs. YOU called into question the integrity of the hitch assembly and/or attachment point and you should quantify your statement.
Old 07-13-2011, 12:13 PM   #92
Westfalia's Avatar
Images: 35
Of note, I went out and inspected my Touareg hitch. You can inspect 1 1/2 bolts per side (out of four) by doing a visual inspections. There is a heat shield in the way partially obscuring the outer bolt. The top two bolts are not visible. A proper visual inspection cannot be performed from below.
I await your reply.
Old 07-13-2011, 12:20 PM   #93
Westfalia's Avatar
Images: 35
I will also qualify this answer as NO. Max stated tongue weight of the Touareg hitch is 770, which is WELL under 1260 stated. In reality, 1260 is probably a useless figure. Installed options almost ALWAYS increase the hitch weight, including propane, gear, WD hitch, panoramic windows, etc. My 27FB with a stated tongue weight of 750 is really more like 920.
Don't do it.
Old 07-13-2011, 12:57 PM   #94
1991 29' Excella
Odessa , Ukraine
Timofeevich
Don't do it.
Many thanks to JFScheck and Westfalia !
Old 07-13-2011, 01:50 PM   #95
JFScheck's Avatar
Images: 33
These vehicles are really great for towing - just need to make sure you have the proper setup and don't exceed the ratings as per VW/Porsche.
For that 34, I think the best Tow Vehicle would be some sort of 3/4 or 1 ton Pickup or SUV....
**I Love U.S.A.**
Old 07-14-2011, 06:58 AM   #96
Evergreen , Colorado
You absolutely should not tow that Pan America with your Touareg. Far too much tongue weight is one issue. But also remember trailer weight both for pulling and especially for stopping. We have all seen the heavy weigh lifters get a jumbo jet going pulling it by hand. Pulling is not necessarily the issue (on flat ground) - but ask that same lifter to stop the jet once it's moving. Now what if it's going downhill?
I pull a 23' airstream with my touareg V8 4.2. It pulls and it fine, and stops it fine with a good break controller. But I am well within the limits. JFS Check and a few others pulled a 25 with a very good hitch (proride) and by watching their weight. I would never recommend going over a 25 with a touareg.
Nightwatch is offline   Reply With Quote
Old 07-14-2011, 09:19 AM   #97
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
I'll disagree with the general public here. I would say your Touareg would do fine as long as you reinforced your hitch, and had the right w/d settings (very few do, even if they think they do).
Try calling Andy at CanAm RV. They reinforced my ML320 and it pulls fine!
Remember 98% of the people here think we're nuts; which leaves a tiny minority who think otherwise. Out of those 98%; 0% have ever tried a CanAm combination. Try finding one post from a CanAm client whose unhappy. There are none!
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 07-14-2011, 12:28 PM   #98
OrangeKid
2013 23' Flying Cloud
Portland , Oregon
2011/2012 Touareg TDI to tow 23' Safari
We are thinking of getting a 2011/2012 Touareg TDI to tow our 2007 23' Safari SE. We have been using a 2006 Sequoia 4.7L V-8 4WD SR5 to tow it. The Sequoia does fine using an Equalizer hitch. We recently downsized and moved into Condo in downtown Portland, OR and do not have a use for two autos any more.
We would like to sell our Sequoia, which is too large and ponderous for use on a daily basis in Portland, and our Honda C-RV EX and replace them with one auto to serve daily use and frequent towing.
The Touareg TDI seems to meet our requirements of a smaller vehicle with good mileage for use around Portland but also possessing a 7700 lb tow limit so we can tow our Safari. My one concern is that the actual hitch weight of our 23' Safari with two 30 lb Propane tanks and two glass mat batteries is 880 lbs. Can the Touareg safely tow our rig? Others have said that a 23' Safari towed with a Touareg is the perfect combination.
OrangeKid is offline   Reply With Quote
towing capacity, touareg
Towing with a Touareg ColdEspresso Tow Vehicles 33 07-21-2011 11:23 AM
How can you tell the towing capacity? Dreamnair Tow Vehicles 4 01-04-2009 07:40 AM
Towing Capacity streamlean Argosy Motorhomes 19 09-10-2007 07:38 PM
How much towing capacity do I need? altamont Tow Vehicles 19 02-25-2007 01:16 PM
Towing Capacity hwpeddie Member Introductions 11 05-28-2006 05:19 PM
